Harbour MiniGUI Extended Edition build 21.01 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 21.01.
* Fixed: The symbol fonts were abandoned in the internal function
_DefineFont() (introduced in the build 16.12).
* Fixed: An Image index assigning was ignored in the Grid control
with 'ColumnControls' property defined as NIL
(introduced in the build 20.06).
* The command DEFINE FONT <font> FONTNAME <name> ... will delete
automatically a previous font definition instead of the error
message.
* Adaptation of MiniGUI core for compatibility with Borland/
Embarcadero C++ 7.20 64-bit compiler.
* Added the Harbour contrib library for Cabinet file (*.CAB)
compression and extraction.
* Added the binary of HMG IDE tool of Roberto Lopez.
* Updated HMGS-IDE v.1.4.4.3.
* Updated the Harbour compiler, SQLite3 library and some examples.
There is a last-minute improvement also:
* Fixed: Getbox VALID function not working if Getbox was placed
in the PANEL window.
Bug was reported by Hans Marc.
Contributed by Grigory Filatov <gfil...@inbox.ru>
A setup of the build 21.01 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 21.01 is published
Addendum
Please note that MiniGUI Ex supports currently the following additional C-compilers:
- MinGW GNU C 10.2.1 (32-bit);
- MinGW GNU C 10.2.0 (64-bit);
- MS Visual C++ 2019 (32-bit);
- MS Visual C++ 2019 (64-bit);
- Borland/Embarcadero C++ 7.4 (32-bit);
- Borland/Embarcadero C++ 7.4 (64-bit);
- Open Watcom C/C++ 2.0 (32-bit);
- Pelles ISO C 10.0 (32-bit);
- Pelles ISO C 10.0 (64-bit).
Hi Grigory
Thank you for new release
One question : Some time I am unable to Uninstall old version i.e. 20.04 before installing new version
The how to Uninstall old version
bpd2000 wrote: Sat Jan 23, 2021 4:25 am Hi Grigory
Hi Dave,
You can erase simply the old folder \MiniGUI before a new installation.
gfilatov wrote: Sat Jan 23, 2021 7:30 pm
Hi Dave,
Ok, but entry generated in Apps & Features
