HMG 2.9.3 (Forum Test II)
- HMG Founder
I've changed the denomination for report IMAGE to avoid conflicts with IMAGE control (Thanks to Luis Vazquez for the report).
Take a look to docs and samples.
- hmg293-2.rar
- (476.02 KiB) Downloaded 402 times
Re: HMG 2.9.3 (Forum Test II)
Nice. Thank you.
Great .. ! Thanks a lot Master.
Thanks master....
Hola Roberto,
Muy bueno el Generador de Reportes, Gracias. (esta parte de la lib me tenia preocupado, no podia lograr reportes con tanta facilidad.)
Pero, y siempre hay un pero: No se como poner encabezados a las columnas.
¿Se puede? o será para una próxima version.
Desde ya, nuevamente gracias.
Hello Roberto,
Very good Report Generator, Thanks. (this part of the lib I was concerned, no reports could achieve so easily.)
But, there's always a but: is not like putting the columns headed.
Is it possible? or will be for a next version.
We again thank you.
Walter
Hello Roberto,
We again thank you.
Walter
Hola Waltertave2009 wrote: But, there's always a but: is not like putting the columns headed.
Is it possible? or will be for a next version.![]()
Please look at attached demo11.prg.
It is slightly modified version of C:\hmg\SAMPLES\REPORT.ADVANCED\demo1.prg
- demo11.zip
- Modified version of report.adv\demo1.prg for column headers.
- (1.14 KiB) Downloaded 374 times
- HMG Founder
This report writer is 'band oriented' not 'column oriented' like Clipper's RL.tave2009 wrote:Hola Roberto,
¿Se puede? o será para una próxima version.![]()
Desde ya, nuevamente gracias.![]()
Hello Roberto,
We again thank you.
Walter
So, you must place the column headers in the 'header band' and column data in the detail band.
- HMG Founder
Thanks!esgici wrote:Hola Waltertave2009 wrote: But, there's always a but: is not like putting the columns headed.
This sample answer the Walter question perfectly.
Hola a todos.
Fue mi error.
Tengo que investigar más. Antes de decir. Esto no se puede hacer, jeje...
Hello everyone.
It was my mistake.
I've to investigate further. Before you say: this ca't be done.
Gracias, Esgici y Roberto.
Walter
Fue mi error.
Hello everyone.
It was my mistake.
Walter
