Harbour MiniGUI Extended Edition build 20.12 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 20.12.
* Fixed: A support of use the Harbour pcode DLL was broken in the
MiniGUI core (introduced in the build 16.12).
* Fixed: Possible program crash at releasing of the standard
'Image Button' control with NOXPSTYLE clause (introduced in the
build 16.03).
* Synchronized Extended HMG for compatibility with Official HMG:
- misc updates for a correct compiling of the HMG-IDE tool.
* 'HMG IDE' sample: code was modified to original source of utility.
Based upon a contribution of HMG Founder Roberto Lopez.
Thanks a lot for this GREAT contribution!
* Updated HMGS-IDE v.1.4.4.3, MPM tool, BosTaurus and Sqlite3
libraries.
* Added the new interesting samples and updated some examples.
* Added the ProcInfo and Selector libraries source code.
Note:
It is available in the mingw64-based donationware distribution
only.
A setup of the build 20.12 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
hmgaams57
Re: Harbour MiniGUI Extended Edition build 20.12 is published
Post by hmgaams57 »
Many thanks Grigory
quartz565
Post by quartz565 »
Thank you Grigory!
Nikos.
os: Windows Server 2019 - 64
Thanks !
Anand
Post by Anand »
Thank you for the update.
Anand
Anand
HMG IDE compiles perfect on HMG.3.4.4
HMG IDE in MINIGUI it does not compile
2020-12-12 11_25_59-C__WINDOWS_system32_cmd.exe.png (68.53 KiB) Viewed 5989 times
Pcmodula
Post by Pcmodula »
Hola Maximiliano,
Acabo de compilar HMG-IDE con minigui 20.12 descargado hoy y se compila perfectamente. :D
Vi que estás usando un viejo compilador Borland. (5.4!!!)
Las notas que se muestran en el Setup dicen
After installation, you will need of Borland C/C++ 5.8 compiler installed at your disk.
puede descargarlo del sitio web de Minigui Extended, pero para su comodidad, este es el enlace:
http://hmgextended.org/files/MISC/bcc582.zip
También tienes que usar el build.bat incluido, de lo contrario, ¡la responsabilidad del fallo es tuya! :roll:
Un abrazo
Pcmodula
