HMG IDE source code
HMG IDE source code
Hi all,
Roberto has decided to make public the source code of the HMG IDE.
Thanks to Roberto for this great work!
It's a great project, I hope you enjoy it!
HMG_IDE_SourceCode.zip
(305.04 KiB) Downloaded 826 times
Re: HMG IDE source code
Thanks to Roberto and Claudio !
I hope this will bring some new life into HMG !
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Muchisimas Gracias Sr. Roberto y Dr. Claudio...
Ahora podré reducir el ancho de la ventana main para tener más altura en el editor Notepad ++ que utlizo !
algo que deseaba desde que conocí HMG.
También se podrían agregar las nuevas propiedades a los controles, aunque eso seguro lo hará antes,
alguien que sepa mucho más que yo.
Thank You Very Much Sr. Roberto and Dr. Claudio...
Now i can reduce main window width and gain screen height for code edit !
Maybe any can add the new property's at the controls without manually edit the .fmg files
(IDE delete this add's when open .fmg file )
CalScot
Post by CalScot »
I applaud the source code becoming public, but I hope that there is some sort of central control or agreemnt as a mechanism to try to ensure that we don't end up with a whole lot of slightly incompatible versions. That could become a nightmare and do long term damage if it was to happen. Any thoughts on how that can be prevented?
Claudio Ricardo
Con una pequeña modificación tengo lo que tanto quería ! :P
HMG es genial !
This make me happy ! :P HMG is the best !
[image]https://drive.google.com/file/d/1FE2XdR ... sp=sharing[/image]
Estimados,
agradezco a Roberto Lopez nuevamente por lo generoso de compartir hasta lo ùltimo.
Gracias Claudio por tu participación y aporte.
saludos cordiales,
vlademiro
Post by vlademiro »
Obrigado pela contribuição.
Thank you Claudio for sharing the IDE source in the right time!
My sincere thanks to our HMG Guru Roberto Lopez for allowing to make public HMG IDE source code. Thank you sir!
