Page 1 of 2
Grid with multilines? Is it possible?
Posted: Thu Nov 05, 2020 5:59 pm
by mol
Hi guys!
Ihave an idea in my application to present grid of documents in multilines.
Main line contains header of document and subsequent lines contain order's position.
Something like TREE control with depth=1
Did somoene realize something similar?
Maybe any idea how to do it?
Re: Grid with multilines? Is it possible?
Posted: Sat Nov 07, 2020 9:29 pm
by martingz
Mol I don't quite understand what you want to do, but I did something like making a quote in a grid
In the first image in a grid they capture the data, and then with that data they generate the document
Posted: Sat Nov 07, 2020 9:40 pm
by mol
I have to create form containing 2-weeks calendar with orders and production results. Now, I'm trying with series of richeditbox
Posted: Mon Nov 09, 2020 6:49 am
by mol
I was looking solution for changing grid to display one cell i few lines (like a richeditbox).
I don't need formatting, I only want to display one cell splitted to few lines.
In control based on winapi ListView it's possible, but it's necessery to change one procedure - DrawItemProcedure.
I have a sample in basic, but I don't know how to translate it to HMG. Maybe some guru from C programming can help?
' ListView CustomDraw Multiline
' compile Windows - Allan
' Is to make the Details column multiline....where required
$include "windows.inc"
$include "commctrl.inc"
CONST STATIC_1 = 1
CONST EDIT_2 = 2
CONST STATIC_3 = 3
CONST EDIT_4 = 4
CONST LV_DISP = 5
CONST BTN_ADD = 6
UINT g_OldDlgProc
declare EBDLGPROC(HWND hwnd, UINT uMsg, WPARAM wParam, LPARAM lParam),LRESULT
const LBS_MULTILINE = WS_CHILD|WS_VISIBLE|WS_VSCROLL|LBS_OWNERDRAWVARIABLE|LBS_NOINTEGRALHEIGHT
const LISTITEMDATA_TIME_LEN = 10
TYPE LISTITEMDATA
	ISTRING time[LISTITEMDATA_TIME_LEN] ' up to 8 characters here: "10.00 AM"
	ISTRING text[1]  ' "Ring Head Office regards promotional campaign"
ENDTYPE
DIALOG d1
CREATEDIALOG d1,0,0,365,256,0x80CA0880,0,"ListView Custom Draw",&d1_handler
CONTROL d1,@STATIC,"Time",23,12,28,15,0x5000010B,STATIC_1
CONTROL d1,@EDIT,"",64,10,70,20,0x50810080,EDIT_2
CONTROL d1,@STATIC,"Details",23,45,35,14,0x5000010B,STATIC_3
CONTROL d1,@EDIT,"",62,42,276,39,0x50810044,EDIT_4
CONTROL d1,@BUTTON,"Add",264,11,70,20,0x50010000,BTN_ADD
CONTROL d1,@LISTBOX,"",19,92,325,148,0,LV_DISP
' Show the Dialog and Wait For it To close
DOMODAL d1
' End program
END
SUB d1_handler
	HWND hwndList
	SELECT @MESSAGE
		CASE @IDINITDIALOG
			hwndList = GetControlHandle(d1, LV_DISP)
			' call InitList to initialize the listbox.
			' NOTE: the variable 'hwndList' will change
			InitList(hwndList, 60)
			'SendMessage(hwndList, LB_DELETESTRING, 0, 0)
			'the first row item and sub items
			InsertListItem(hwndList,"10.00 AM", "Ring Head Office regards promotional campaign")
			'the second row item and sub items
			InsertListItem(hwndList,"11.30 AM","Appointment with Sales Team")
			'the third row item and sub items
			InsertListItem(hwndList,"1.30 PM","Meet Adrian from Calcat at Airport and hand over the Overseas Portfolio for next Seasons Promotional Campaign")
			'the fourth row item and sub items
			InsertListItem(hwndList,"3.30 PM","Advise Head Office on todays events")
			InsertListItem(hwndList,"00.00 AM","something")
			InsertListItem(hwndList,"00.01 AM","something")
			InsertListItem(hwndList,"00.02 AM","something")
			InsertListItem(hwndList,"00.03 AM","something")
		CASE @IDCLOSEWINDOW
			' remove memory-items
			RemoveAllListItems(hwndList)
			CLOSEDIALOG d1,@IDOK
		CASE @IDCONTROL
			SELECT @CONTROLID
				CASE EDIT_2
				/* respond to edit notifications here */
				CASE EDIT_4
				CASE BTN_ADD
					IF @NOTIFYCODE = 0
						/*button clicked*/
						InsertListItem(hwndList,GetControlText(d1, EDIT_2),GetControlText(d1, EDIT_4))
			ENDSELECT
	ENDSELECT
ENDSUB
sub InitList(HWND hwndList byref, int ColumnWidth)
	HWND hwndParent
	int  ListId
	HFONT hFont
	WINRECT rc
	hwndParent = GetParent(hwndList)
	ListId     = GetWindowLong(hwndList, GWL_ID)
	' hide the present listbox and create new one, without LBS_HASSTRINGS flag.
	' Emergence forces the LBS_HASSTRINGS flag, so we need to create a new box.
	' size and position
	GetWindowRect(hwndList, &rc)
	MapWindowPoints(0, d1.hwnd, &rc, 2)
	' also duplicate current font
	hFont = SendMessage(hwndList, WM_GETFONT, 0, 0)
	' this will resize all controls and remove gui font from all controls
	'DestroyWindow(hwndList)
	' so better is to hide the old listbox
	_ShowWindow(hwndList, SW_HIDE)
	' kill also listbox ID
	SetWindowLong(hwndList, GWL_ID, 0)
	' subclass the dialog, because we need WM_DRAWITEM
	g_OldDlgProc = SetWindowLong(d1.hwnd, GWL_WNDPROC, &ForwardDrawItemProc)
	' create new listbox
	hwndList = CreateWindow(WC_LISTBOX, NULL, LBS_MULTILINE, _
		rc.left, rc.top, rc.right-rc.left, rc.bottom-rc.top, _
		hwndParent, ListId, _hinstance, 0)
	' save first column width
	SetProp(hwndList, "colw", ColumnWidth)
	' restore font
	SendMessage(hwndList, WM_SETFONT, hFont, 0)
	return
endsub
sub MeasureListItem(HWND hwndList, int wParam, MEASUREITEMSTRUCT mis),BOOL
	' this is called once for every inserted listbox item.
	' we need to return width and height for current item;
	' TODO: remove the FirstColWidth parameter
	pointer itemdata
	pointer pText
	int FirstColWidth
	HDC hdc
	WINRECT rc
	HFONT font
	int maxWidth
	FirstColWidth = GetProp(hwndList, "colw")
	' pointer to LISTITEMDATA
	itemdata = SendMessage(hwndList, LB_GETITEMDATA, mis.itemID, 0)
	' get width and height of our listbox
	GetClientRect(hwndList, &rc)
	' item width = listbox width
	mis.itemWidth  = rc.right
	'remove first column from rectangle
'	rc.left = FirstColWidth
	rc.right -= FirstColWidth
	pText = "A"
	hdc = GetDC(hwndList)
	font = SelectObject(hdc, SendMessage(hwndList, WM_GETFONT, 0, 0))
	if (itemdata)
		pText = *<LISTITEMDATA>itemData.text
	' get text height
	maxWidth = rc.right
	mis.itemHeight = DrawText(hdc, pText, -1, &rc, DT_WORDBREAK|DT_CALCRECT) + 2
	SelectObject(hdc, font)
	ReleaseDC(hwndList, hdc)
	return true
endsub
sub DrawListItem(HWND hwndList, int wParam, DRAWITEMSTRUCT dis),BOOL
	pointer itemdata
	WINRECT rc
	COLORREF BkColor
	int FirstColWidth
	itemdata = SendMessage(hwndList, LB_GETITEMDATA, dis.itemID, 0)
	' draw selection background if the item is selected
	if (dis.itemAction & ODA_SELECT)
		BkColor = GetSysColorBrush(IIF(dis.itemState & ODS_SELECTED, COLOR_HIGHLIGHT, COLOR_WINDOW))
		CopyRect(&rc, &dis.rcItem)
		rc.top++
		FillRect(dis.hDC, &rc, BkColor)
	' do not draw text background in DrawText()
	SetBkMode(dis.hDC, TRANSPARENT)
	' draw first column aligned to right
	rc.top++
	rc.right = FirstColWidth - 4
	DrawText(dis.hDC, *<LISTITEMDATA>itemData.time, -1, &rc, DT_RIGHT)
	' draw second column
	rc.top++
	rc.left = FirstColWidth + 4
	DrawText(dis.hDC, *itemData.text, -1, &rc, DT_WORDBREAK)
	' draw grid lines
	HBRUSH hbr
	HPEN pen
	hbr = SelectObject(dis.hDC, GetStockObject(NULL_BRUSH))
	pen = SelectObject(dis.hDC, CreatePen(PS_SOLID, 1, rgb(128,128,198))) /*grid color*/
	' horizontal
	MoveToEx(dis.hDC, 0, rc.bottom, NULL)
	_LineTo(dis.hDC, rc.right, rc.bottom)
	' vertical
	MoveToEx(dis.hDC, FirstColWidth, rc.top, NULL)
	_LineTo(dis.hDC, FirstColWidth, rc.bottom)
	' vertical again
	MoveToEx(dis.hDC, dis.rcItem.right-1, rc.top, NULL)
	_LineTo(dis.hDC, dis.rcItem.right-1, rc.bottom)
	DeleteObject(SelectObject(dis.hDC, pen))
	SelectObject(dis.hDC, hbr)
	return true
endsub
sub InsertListItem(HWND hwndList, string time, string text)
	pointer itemdata
	itemdata = new(char, len(LISTITEMDATA) + len(text))
	if (itemdata)
		strncpy(*<LISTITEMDATA>itemdata.time, time, LISTITEMDATA_TIME_LEN)
		*<LISTITEMDATA>itemdata.time[8] = 0
		*<LISTITEMDATA>itemdata.text = text
		SendMessage(hwndList, LB_ADDSTRING, 0, itemdata)
	return
endsub
sub RemoveListItem(HWND hwndList, int index)
	pointer itemdata
	itemdata = SendMessage(hwndList, LB_GETITEMDATA, index, 0)
	delete itemdata
	return
endsub
sub RemoveAllListItems(HWND hwndList)
	int index
	index = SendMessage(hwndList, LB_GETCOUNT, 0, 0)
	while (index)
		index--
		RemoveListItem(hwndList, index)
	wend
	return
endsub
sub ForwardDrawItemProc(HWND hwnd, UINT uMsg, WPARAM wParam, LPARAM lParam),LRESULT
	if ((uMsg = WM_MEASUREITEM) and (*<MEASUREITEMSTRUCT>lParam.CtlType = ODT_LISTBOX))
		return MeasureListItem(GetDlgItem(hwnd, wParam), wParam, *<MEASUREITEMSTRUCT>lParam)
	if ((uMsg = WM_DRAWITEM) and (*<DRAWITEMSTRUCT>lParam.CtlType = ODT_LISTBOX))
		return DrawListItem(*<DRAWITEMSTRUCT>lParam.hwndItem, wParam, *<DRAWITEMSTRUCT>lParam)
	return !<EBDLGPROC>g_OldDlgProc(hwnd, uMsg, wParam, lParam)
endsub
Posted: Mon Nov 09, 2020 7:42 am
by dragancesu
https://www.youtube.com/watch?v=SoAYZ3iKGM0
not solution but for thinking
Posted: Mon Nov 09, 2020 8:55 am
by mol
It would be great to have such a control, even only for viewing data
Posted: Tue Nov 17, 2020 11:36 am
by AUGE_OHR
NOT using GRID ... under construction
Posted: Sun Nov 22, 2020 4:32 am
by AUGE_OHR
hi
i got Concept work :D
it is not ready but it seem a good Way
Posted: Sun Nov 22, 2020 2:05 pm
by fouednoomen
Posted: Sun Nov 22, 2020 6:56 pm
by mol
I don't use HMG Extended.
Few years ago Grigori Filatov published Tsbrowse for hmg official, but I can't compile it
