Harbour MiniGUI Extended Edition build 20.10 is published
Hi Friends,
Edition.
Here's a breakdown of some of the modifications in the build 20.10.
* Added the new functions for Windows GDI objects memory release.
It will activate the GDI objects recording and call CheckRes()
to generate the checkres.txt log file on the application quit.
Note: This feature will work after setting of debugging mode
via the Harbour command Set( _SET_DEBUG, .T. ) or AltD( 1 ).
* Fixed detected resource leakage of GDI objects at the release of
Main form with usage of the new MiniGUI Resources control system.
* Fixed: Alternate definition of SPLITBOX control overrides wrongly
a standard his definition (cannot be used simultaneously BOTTOM
and HORIZONTAL clauses). It exists in the official version too.
* Fixed: The TOOLBAR control with WRAP style was hidden in the
SplitBox with defined BOTTOM clause.
* TOOLBAR control: toolbuttons supports an optional ADJUST clause.
* Revised a hot mouse tracking in the ButtonEx control.
* Revised a releasing of the AniGif control.
* Synchronized Extended HMG for compatibility with Official HMG:
- COMBOBOXEX supports the optional clause NOTRANSPARENT;
- IMAGE CHECKBUTTON supports the optional clause NOTRANSPARENT;
- TAB control supports the optional clause NOTRANSPARENT;
- TREE control supports the optional clause NOTRANSPARENT.
* Added the optional color's constants to the header files
i_color.ch and i_wincolor.ch.
* Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- added the new variables :lFastDrawCell, :aFastDrawCell and
:lFastDrawClear, method :FastDrawClear() for high-speed
HASH-based data refreshing in the TSBrowse class;
Note: you should set :lFastDrawCell to .T. for switch ON
the above mode.
Thanks a lot to SergKis and Haz for this GREAT contribution!
* Updated Sqlite3 library.
* Added the new interesting samples and updated some examples.
A setup of the build 20.10 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
[MiniGUI Team]
Anand
Re: Harbour MiniGUI Extended Edition build 20.10 is published
Post by Anand »
Thanks Grigory
Anand
Anand
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Thank you very much for this new release Grigory !!
Salamandra, Brazil
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thanks Grigory!
Thanks. Best regards
I've uploaded the updated setup of the build 20.10 for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: Browse control without PICTURE option had a wrong formatting for
the fields with negative numbers (introduced in the build 20.05).
Bug was reported by Pablo Jalabert.
(see demo in folder \samples\Basic\Browse_4)
* Fixed: Correction in the Imagelist ADD IMAGE commands.
Syntax:
ADD IMAGE <image> [ MASK <mask> ] TO <control> OF <parent>
ADD MASKEDIMAGE <image> [ COLOR <aColor> ] TO <control> ;
OF <parent>
(see demo in folder \samples\Basic\TOOLBAR_3)
* Enhanced: TOOLBAR control: tool buttons respect the BALLOON style of
tooltips and the command SET TOOLTIP [ ACTIVATE ] <ON | OFF>.
Requested by Ivanil Marcelino <ivanil/at/linkbr.com.br>.
(see demo in folder \samples\Basic\TOOLBAR_2)
* Enhanced: ANIGIF control: added support of animated GIF from resources.
(see demo in folder \samples\Advanced\AniGIF)
* Enhanced: BtnTextBox and GetBox controls support Controls Context menu.
* Modified: Adding the new selected values to the multiple selection Grid
was significantly accelerated (noticeable for grids with more than
one hundred thousand items).
Suggested by HMG user Edward.
* New: 'Month Calendar control with the bold days and backcolor' sample.
Based upon a contribution of Kevin Carmody <i@kevincarmody.com>.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see demo3.prg in folder \samples\Basic\MONTHCAL)
* New: 'MiniGUI ToolBar ImageList Demo' sample.
(see in folder \samples\Basic\TOOLBAR_3)
Thanks for your attention and support.
[MiniGUI Team]
Please note that there are also the following private MiniGUI builds for the all donators:
:arrow: - MinGW GNU C 10.2.1 (32-bit);
Minigui Ex Package (build date: 28.10.2020)
Download links: http://hmgextended.com/files/PRIVATE
Components versions:
Harbour MiniGUI Extended Edition 20.10 (Update 1)
Harbour 3.2.0dev (r2008190002)
Harbour Make (hbmk2) 3.2.0dev (r2020-08-19 00:02)
gcc (GCC with MCF thread model, built by LH_Mouse.) 10.2.1 20201010
:arrow: - MinGW GNU C 10.2.0 (64-bit);
Minigui Ex 64 Package (build date: 27.10.2020)
Harbour 3.4.0dev (cf51c11) (2017-12-20 13:44)
Harbour Make (hbmk2) 3.4.0dev (cf51c11) (2017-12-20 13:44)
gcc (MinGW-W64 x86_64-posix-seh, built by Brecht Sanders) 10.2.0
Thanks for your attention.
Hi Grigory !
Thanks, but how can I get private MiniGUI builds?
The page gives forbidden 403.. :oops:
serge_girard wrote: Wed Oct 28, 2020 8:45 am Hi Grigory !
Hi Serge,
Please be so kind to send me e-mail with a requested tool.
I'll provide a confidential link to you in my answer e-mail. 8-)
Thanks for your interest :!:
Hi Grigory,
I have send an email to your buran19* address.
Did you receive it?
