How to change Interval in TIMER control?
Source code related resources
Hi guys!
can you help me how to change Interval in TIMER control?
I can't find it anywhere...
Paramvir
Re: How to change Interval in TIMER control?
Post by Paramvir »
Hello
I have found this code in Giovanni's HMG Tutorial:
FUNCTION Main()
DEFINE WINDOW Form_1 ;
AT 90,90 ;
WIDTH 250 ;
HEIGHT 150 ;
MAIN
DEFINE TIMER tempo ;
PARENT Form_1 ;
INTERVAL 1000 ;
ACTION print_clock()
Form_1.Activate
FUNCTION print_clock()
Form_1.title := time()
perhaps this may help you.
Hi Mol
	AT 0, 0                   ;
	WIDTH 405 HEIGHT 405      ;
	TITLE ""                  ;
        MAIN
        ON KEY ESCAPE ACTION  Form_1.Release )
        DEFINE TIMER Timer_1 INTERVAL 1000  ACTION (RELEASE MEMORY)
        DEFINE TIMER Timer_2 ;
              INTERVAL 100 ;
              ACTION { || thisWindow.Row := 175, thisWindow.Col := 480 }     // <==  Does not let the window move
Form_1.Timer_1.Value := nInterval //change timer's interval
You can only set new interval, can't read actual value by "Value"
You can read interval by: _HMG_SYSDATA [ 8 ] [ GetControlIndex (ControlName,ParentForm) ] => timer's interval current value
The sample:
		WIDTH 400 ;
		HEIGHT 400 ;
		TITLE 'Timer Test' ;
		MAIN
		DEFINE TIMER Timer_1 ;
		INTERVAL 3000 ;
		ACTION TimerTest()
	ACTIVATE WINDOW Form_1
Procedure TimerTest()
	Local nInterval := _HMG_SYSDATA [  8 ] [ GetControlIndex ( 'Timer_1', 'Form_1') ] 	// timer's interval current value
	Form_1.Timer_1.Enabled := .F.
	MsgInfo ('Timer ' + hb_ValToStr ( nInterval / 1000 ) + ' sec.')
	IF nInterval > 1000
		nInterval -= 1000
	Form_1.Timer_1.Enabled := .T.
