Is there any way to implement the feature in many web sites that let you click on an icon at right of the password
to show what you have typed so far without actually entering the password. On may log-ins it looks like an eyeball icon.
Thanks
Password eye-like icon for PW preview
Re: Password eye-like icon for PW preview
Hello everyone
I will use this. I hope it helps possibly serve as an inspiration.
DEFINE LABEL LBL_pswd
ROW 150
COL 190
WIDTH 180
VALUE Msg_004
FONTNAME "verdana"
FONTSIZE 9
FONTCOLOR BLACK
FONTBOLD .T.
END LABEL
DEFINE TEXTBOX Txt_Pswd
ROW 170
COL 190
WIDTH 180
PASSWORD .T.
BACKCOLOR WHITE
ONGOTFOCUS frm_Login.Txt_Pswd.BACKCOLOR:={255, 255, 128}
ONLOSTFOCUS frm_Login.Txt_Pswd.BACKCOLOR:={255,255,255}
MAXLENGTH 10
ONENTER Confirm_Login()
END TEXTBOX
DEFINE IMAGE IMG_spsw
ROW 170
COL 190+180+20
WIDTH 24
HEIGHT 24
ONCLICK ukaz_psw(.t.)
PICTURE "okoo"
TOOLTIP 'Show'
END IMAGE
DEFINE IMAGE IMG_hpsw
ROW 170
COL 190+180+20
WIDTH 24
HEIGHT 24
ONCLICK ukaz_psw(.f.)
PICTURE "okoz"
TOOLTIP 'Hide'
END IMAGE
DEFINE BUTTON BT_OK
ROW 220
COL 170
CAPTION "Ok"
PICTURE "KEYS02"
FLAT .T.
WIDTH 90+30
HEIGHT 40
FONTNAME "verdana"
FONTSIZE 9
FONTBOLD .T.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .T.
BACKCOLOR NIL
TOOLTIP Msg_005
ACTION Confirm_Login()
MULTILINE .F.
PICTALIGNMENT LEFT
END BUTTON
DEFINE BUTTON BT_ZRUS
ROW 220
COL 270+35
CAPTION Msg_006
PICTURE "logout"
FLAT .T.
WIDTH 120
HEIGHT 40
FONTNAME "verdana"
FONTSIZE 9
FONTBOLD .T.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .T.
BACKCOLOR NIL
TOOLTIP Msg_007
ACTION Cancel_Login()
MULTILINE .F.
PICTALIGNMENT LEFT
END BUTTON
frm_Login.IMG_hpsw.hide
if login_pri > 1 //prisnost prihlasenia
frm_Login.Txt_Login.SetFocus
frm_Login.Txt_pswd.SetFocus
CENTER WINDOW frm_Login
ACTIVATE WINDOW frm_Login
function ukaz_psw(ako)
LOCAL lShowPass := ako
if ako=.t.
frm_Login.IMG_hpsw.show
frm_Login.IMG_spsw.hide
//frm_Login.Txt_Pswd.REDRAW
//SendMessage(frm_Login.Txt_Pswd.HANDLE, 0x00CC /*EM_SETPASSWORDCHAR*/, If(lShowPass, 0, 0x25CF), 0)
//RedrawWindow(frm_Login.Txt_Pswd.HANDLE)
frm_Login.IMG_spsw.show
return
ROW 150
COL 190
WIDTH 180
VALUE Msg_004
FONTNAME "verdana"
FONTSIZE 9
FONTCOLOR BLACK
FONTBOLD .T.
END LABEL
ROW 170
COL 190
WIDTH 180
PASSWORD .T.
BACKCOLOR WHITE
MAXLENGTH 10
END TEXTBOX
ROW 170
COL 190+180+20
WIDTH 24
HEIGHT 24
PICTURE "okoo"
TOOLTIP 'Show'
END IMAGE
ROW 170
COL 190+180+20
WIDTH 24
HEIGHT 24
PICTURE "okoz"
TOOLTIP 'Hide'
END IMAGE
DEFINE BUTTON BT_OK
ROW 220
COL 170
CAPTION "Ok"
PICTURE "KEYS02"
FLAT .T.
WIDTH 90+30
HEIGHT 40
FONTNAME "verdana"
FONTSIZE 9
FONTBOLD .T.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .T.
BACKCOLOR NIL
TOOLTIP Msg_005
MULTILINE .F.
PICTALIGNMENT LEFT
END BUTTON
ROW 220
COL 270+35
CAPTION Msg_006
PICTURE "logout"
FLAT .T.
WIDTH 120
HEIGHT 40
FONTNAME "verdana"
FONTSIZE 9
FONTBOLD .T.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .T.
BACKCOLOR NIL
TOOLTIP Msg_007
MULTILINE .F.
PICTALIGNMENT LEFT
END BUTTON
if ako=.t.
return
- show_24.png (490 Bytes) Viewed 9616 times
- private_red24.png (1.02 KiB) Viewed 9616 times
- Screenshot_2.jpg (12.55 KiB) Viewed 9616 times
- Screenshot_1.jpg (13.77 KiB) Viewed 9616 times
- fouednoomen
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, Oracle, ODBC
Many thanks for sharing
I think this is what you mean
local view
window win_emp
define textbox text_12
password
define button
ACTION {|| {view:=win_emp.Text_12.value} ,{msgbox(view) }}
With this you have not hit enter to create a count of wrong password.
Franco
local view
window win_emp
password
define button
Franco
All The Best,
Franco
Canada
Franco
Canada
fouednoomen wrote: ↑Sun Aug 09, 2020 7:40 pm Please explain where you got lines:
Thank You
- mustafa
Hello friends
3 Samples
Sample_1.prg
Sample_2.prg
Sample_3.prg
Username = "admin"
Password = "admin"
3 Samples
Sample_1.prg
Sample_2.prg
Sample_3.prg
Username = "admin"
Password = "admin"
- Password_Eye.zip
- (61.87 KiB) Downloaded 397 times
