StrFile() doesn't seem to allow writing a string to the very beginning of a file
HGAutomator
Post by HGAutomator »
If we call StrFile as
STRFILE( "Initial Bytes", "File.dat", .T., 0 )
, then the string
Initial Bytes
is written to the end of the file.
If you write
STRFILE( "Initial Bytes", "File.dat", .T., 1 )
, then the string is written properly beginning with the second byte (byte 1).
But there doesn't seem to be any way to write a string starting with the first byte (byte 0).
Re: StrFile() doesn't seem to allow writing a string to the very beginning of a file
if you are right it is an error in the source code (C:\harbour-core-master\contrib\hbct\ctstrfil.c):
if( nOffset )
   hb_fsSeekLarge( hFile, nOffset, FS_SET );
the correct way would be:
if( nOffset >= 0 )
when the nOffset is zero the function write to the end of the file.
HGAutomator
Ok, thanks. I'll do it a different way.
srvet_claudio wrote: Sun Aug 02, 2020 2:53 pm Hi,
if( nOffset )
if( nOffset >= 0 )
