HMG New Version in GitHub
Re: HMG New Version in GitHub
Hello friends:
Thanks Mr Rathi and Dr Claudio
A question to install HMG-64 bit
I can't do it with HARBOR-64 and MinGw-64
As in the previous version already prepared to insert into HMG 3.4.4
https://www.hmgforum.com/viewtopic.php? ... ba0e6fd91b
that HARBOR-64 and MinGw-64 were directly accessed
For 64 Bit developers, you have to download and install Harbour64 and MingW64 from here (15 MB) and here (71 MB) respectively.
https://drive.google.com/file/d/0B3L0QM ... d3cU0/view == >> HARBOR-64 (nightly 2016-04-20) .rar
https://drive.google.com/file/d/0B3L0QM ... VUeEU/view == >> MinGW-64_Ver.5.3.0.rar
It is possible that a colleague can provide these folders already prepared to insert them in the HMG 3.4.4.
with the new versions Harbour64 and MingW64 ?
The solution provided by danielmaximiliano
For those of us who are not experts, I cannot solve
PD: how to fix the LIB-64 issue?
bpd2000 wrote: Tue Jul 14, 2020 4:30 am
AUGE_OHR wrote: Tue Jul 14, 2020 1:59 am hi,
i love e HMG and it is a good News when Source is available on Github.
now when compare with other Contribution like Extended Version it use MinGW instead of BCC
i does mean that HMG need MinGW LIB and can´t use BCC LIB
so i like to ask if it make Sense in next Release to switch from MinGW to BCC :idea:
BCC is commercial product and not under GPL
HMG is under GPL so we are not using BCC
fouednoomen
Post by fouednoomen »
quartz565
Post by quartz565 »
Thanks Rathi and Claudio !
Nikos
Nikos.
os: Windows Server 2019 - 64
apais
Post by apais »
HMG compilation should be done in GItHub by implementing "Actions".
This way users don't have to compile by themselves, only download binaries.
Angel Pais
apais wrote: Tue Jul 14, 2020 12:08 pm HMG compilation should be done in GItHub by implementing "Actions".
That will be great! Can you guide or help?
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Salamandra, Brazil
martingz
Post by martingz »
Thank you Dr. Claudio and Rathi
New HMG344-64bits Error Detected
I have detected the same error that was reported in version HMG. 3.4.2 Sep 29, 2015
In the Print the letters are fallen see the sample that at the time I contributed
https://www.hmgforum.com/viewtopic.php? ... INT#p42823
https://www.hmgforum.com/viewtopic.php? ... T&start=60
Solved by colleague tonton2
https://www.hmgforum.com/viewtopic.php? ... &start=140
Solution == >> in HMG344/SOURCE/h_HMG_HPDF.Prg
Edit ==> SOURCE/h_HMG_HPDF.Prg
line 312 (nyPost - = FontSize) in (// nyPost - = FontSize) and everything returns to normal
line 312 Ok ==>> // nyPos - = nFontSize
Compile
_BuildAllLib64.bat
_BuildLib64.bat
apais
Post by apais »
Rathinagiri wrote: Tue Jul 14, 2020 12:48 pm
Yes Rathi.
You can take this project as an example.
https://github.com/FiveTechSoft/mod_harbour
There you go to Actions and create all the workflows you like.
Each workflow generates an artifact ( a downloadable file ).
Dependencies are kept using chocolatey ( choco ), this is necessary for OpenSSL, curl, and others.
Angel Pais
