Harbour MiniGUI Extended Edition build 20.06 is published
quartz565
Re: Harbour MiniGUI Extended Edition build 20.06 is published
Post by quartz565 »
Thank you Grigory!
Nikos.
os: Windows Server 2019 - 64
I've uploaded the updated setup of the build 20.06 (Update 3) for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: Multiselect GRID: when you click again on only one of the previous
selected lines the 'OnChange' event is NOT called.
That's exists in the official version too.
Bug was reported by Hans Marc.
(see demo in folder \samples\Basic\Grid_2)
* Updated: Adaptation FiveWin Class TSBrowse 9.0 in HMG:
- minor correction of a phantom column's painting in the method
Enabled().
Contributed by Sergej Kiselev
(see demo6.prg in folder \samples\Advanced\Tsb_Basic_2)
* Updated: HbSQLite3 library:
- update for using SQLITE3 latest version 3.33.0dev.
Contributed by Grigory Filatov <gfilatov@inbox.ru>.
* New: 'Restore a working of the F12 hotkey' sample.
Based upon a contribution of Pablo Cesar Arrascaeta at HMGFORUM.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Basic\ON_KEY_F12)
* New: 'NetIO Server Test' sample with a client connection.
Based upon a contribution of Pete D. <pete_westg/at/yahoo.gr>.
Revised by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Advanced\NETIO_3)
* Updated: 'Folders syncronize - Backup Incremental' utility:
- added the possibility of syncronizing to and from the Leto server.
Based upon a contribution of Brunello Pulix at HMGFORUM.
(see in folder \Utils\HMG_MYSYNC)
[MiniGUI Team]
jorge_riv
DBs Used: DBF, MySQL,SQL SERVER, Oracle.
Post by jorge_riv »
Varia en algo usando BCC102??? Es con el cual compilo en esta version.
quartz565
Post by quartz565 »
Thank you Grigory!
Nikos.
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Thank you very much Grigory !!
Salamandra, Brazil
I've uploaded the updated setup of the build 20.06 (Update 4) for Borland C++ 5.8.2 at
There is also the updated donationware Minigui Ex build for the
Embarcadero C++ 10.2 ‘Tokyo’ compiler.
Whatsnew:
* Fixed: The transparent CHECKBOX and RADIOGROUP controls inside a Tab
depended from a FRAME with 'Opaque' property which set to ON.
Problem was reported by Marcal Vera.
* Modified: The minor optimizations for a MiniGUI core reducing in the
following functions:
- SetProperty();
- GetProperty();
- DoMethod().
* Updated: Synchronized Extended HMG for compatibility with Official HMG:
- the all controls (ButtonEx, Image CheckButton, ToolBar Button,
ComboBoxEx, Grid, Tab, Tree, Menu, etc) will loaded the images
in formats BMP, GIF, TIF, JPG and PNG.
It was a postponed user's request (slight chance of regression).
Based upon a contribution of Claudio Soto <srvet/at/adinet.com.uy>.
(see demo in folder \samples\Basic\Tab_4)
* New: 'Grid Image Index with the PNG images' sample by Claudio Soto.
(see in folder \samples\Basic\Grid_ImageIndex)
* Updated: 'Data-Bound Controls' sample:
- added the round rectangled edit controls with outline highlight
when gaining focus.
Requested by Sylvain Larche.
(see demo2.prg in folder \samples\Basic\DATA_BOUND)
* Updated: 'Tab pages with the PNG images' sample.
Borrowed from HMG 4 project.
Adapted by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Basic\Tab_4)
[MiniGUI Team]
salamandra
Thank you Grigory !!
Salamandra, Brazil
Steed
Post by Steed »
Thanks
I've uploaded the updated setup of the build 20.06 (Update 5) for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: Possible corruption after a memory allocation in the C-function
ListViewGetItem() (introduced in the build 19.04).
Reported and contributed by Fernando Yurisich.
* Fixed: When loads a Grid control and 'ColumnControls' property
is NIL then converts automatically any data type in a text type.
Problem was reported by Fernando Yurisich.
- minor correction at adding of a Selector in the method Paint().
Contributed by Sergej Kiselev.
- the function LoadImage() supports the additional parameters.
Syntax:
LoadImage( cFilename [, hWnd ][, nWidth ][, nHeight ] ;
[, nScale ][, nTransparent ][, nBackColor ][, Adjust ] ;
[, lAlpha ][, nAlphaConstant ] )
Requested by Verchenko Andrey.
- updated function DrawRR() for the round rectangled edit controls.
Syntax:
DrawRR( nRow, nCol, nHeight, nWidth ;
[, lFocus][, cWindowName][, nCurve] )
Requested by Paul Schlicher.
[MiniGUI Team]
Anand
Post by Anand »
Thanks for quick update.
Anand
Anand
