Row Refresh in a BROWSE
Red2
Post by Red2 »
In a (simple) BROWSE the ACTION of a right-click calls the following function.
function Browse_Field_Change( p_lPrint)
	if ( p_lPrint )		// TRUE
		if ( upper( By_State->MergeState ) != "Y" )
			replace By_State->MergeState with "Y"
	else			// FALSE
		if ( By_State->MergeState != " " )
			replace By_State->MergeState with " "
	// Refresh the current BROWSE row!!!
return Nil
The value of field MergeState is correctly changed.
PROBLEM: I have not been able to dynamically make this row's change appear in the BROWSE.
It does not appear in the BROWSE until I
1) exit the form
then
2) Re-open the form
QUESTION:
In HMG/Harbour how can I dynamically refresh the current BROWSE row (whose value(s) have changed)?
Thank you for your kind guidance and suggestions.
Red2
Anand
Re: Row Refresh in a BROWSE
Post by Anand »
I think you can call
brow_data:Refresh(.T.)
for it
Anand
Anand
Refresh causes refreshing whole BROWSE control and screen flickering
Anand
Post by Anand »
Then maybe
brow_data:Refresh(.f.)
I mixed up.
Anand
Anand
Refresh Method
Refresh Content For a Data-Bound Control
Syntax:
<WindowName>.<ControlName>.Refresh
Data-bound Grid supports an optional logical parameter. When set to .t., the selected logical records is preserved.
so when using Parameter .T. it only update Record (refreshCurrent) and not hole Display.
Anand
Post by Anand »
Sample c:\MiniGUI\SAMPLES\Advanced\Tsb_Basic\ of Harbour MiniGUI Extended Edition uses
oBrw:Refresh(.T., .T.)
so it is valid.
But do not know about HMG 3.4.4
Anand
Anand
Red2
Post by Red2 »
Thank you so much for your very kind help and the suggestion: brow_data:Refresh(.f.).
(Note: My BROWSE is a simple Browse, not a TBrowse or a GRID).
Unfortunately I remain UNsuccessful.
My BROWSE is defined (named) as "BrowseStates" so I tried the following syntax. Question: Is my syntax/implementation wrong?
BrowseStates:Refresh(.F.) // This generates the error "Error BASE/1003  Variable does not exist:  BROWSESTATES".
I notice that the sample PRGs in Harbour MiniGUI Extended Edition, c:\MiniGUI\SAMPLES\Advanced\Tsb_Basic\Demo.PRG, include the line
#include "TSBrowse.ch"
In HMG can a simple BROWSE actually be refreshed?????
Finally
The HMG .CHM help file shows a "Refresh Method", <WindowName>.<ControlName>.Refresh. It is described as "Refresh Content For a Data-Bound Control". My form/window is (named) "DataBrowse". However
DataBrowse.BrowseStates.Refresh(.T.) // Generates error "Error BASE/1003  Variable does not exist: DATABROWSE"
Can anyone suggest, in HMG, a way to code a REFRESH in a "normal" BROWSE? I would be very much appreciate your your expert advice.
Thanks again!
Red2
mlnr
Post by mlnr »
Please try this
DoMethod("DataBrowse","BrowseStates","Refresh")
But as Marek wrote screen flickering.
Gabor
