How to open form without project
vlademiro
Post by vlademiro »
Hi all
This is my first post in this group.
I'm using HMG.3.4.4 and would like be know how to open form only to addition without open project too.
E.g:
c:\myfolder\ide.exe form.fmg
Thanks all
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: How to open form without project
Post by dragancesu »
No this way
You have pair prg/fmg, from prg call fmg
look samples
vlademiro wrote: Thu Jun 04, 2020 6:57 pm I'm using HMG.3.4.4 and would like be know how to open form only to addition without open project too.
by default the IDE must be the project open, to do it autonomously it is necessary to use your preferred text editor
my HBFM Tool does create FMG from DBF which will be "accept" by HMG IDE Form-Designer
DBF2FMG.ZIP
(2.23 KiB) Downloaded 207 times
it include
FUNCTION Cre_Form( aSize )
FUNCTION Cre_Label( nNo, nRow, nCol, nWidth, nHeight, cValue )
FUNCTION Cre_Textbox( nNo, nRow, nCol, nWidth, nHeight, cField, cType, nLen, nDec )
FUNCTION Cre_CheckBox( nNo, nRow, nCol, nWidth, nHeight, cName )
as i can say you "full-Set" like IDE generate to fill Property Box else IDE will not accept it.
so make a Demo for all Controls you want to use and use that Code to "copy/paste" into your Source FMG
Anand
Post by Anand »
vlademiro wrote: Thu Jun 04, 2020 6:57 pm Hi all
E.g:
Thanks all
Your code will not work in HMG, but will work in HMG MiniGUI
I use MiniGUI and open form by this way always.
Anand
Anand
vlademiro
Post by vlademiro »
AUGE_OHR wrote: Thu Jun 04, 2020 10:45 pm hi,
DBF2FMG.ZIP
Thanks AUGE_OHR, I Will test
vlademiro
Post by vlademiro »
Anand wrote: Fri Jun 05, 2020 11:16 am
Anand
Is It a HMG Extend ? where do i download?
Thanks
vlademiro
Post by vlademiro »
Thanks all
vlademiro wrote: Fri Jun 05, 2020 4:31 pm
Thanks
http://hmgforum.com/viewtopic.php?f=15&t=6456
vlademiro
Post by vlademiro »
Thanks, ide.exe open fmg file now.
