Print rectangle Border
Pepe Ruano
Post by Pepe Ruano »
Hola a todos, me gustaría poder imprimir un rectángulo redondeado, pero sin pixelizar, ya que lo que hace no me gusta como queda, quisiera que fuése uniforme y sin borde alguno, o sea totalmente limpio. Aquí pongo una imágen de como lo hace ahora y no me gusta:
English: :roll:
Hello everyone, I would like to be able to print a rounded rectangle, but without pixelizing, since what I do does not like how it looks, I would like it to be uniform and without any border, that is, totally clean. Here I put an image of how he does it now and I don't like it:
Code:
///******************   PRUEBA DE IMPRESION     *********************
Func Main( )
Local  nL := 120 , cPrinter , cTitu := "Prueba" , cNif := "74.123.123-Q" , cDom := "San Adrián, nº 10", cPob := "Madrid" ,;
	   aAzul := {32,77,244} , aMarino := {13,29,138} , aRojo := {204,51,0}	, aBlanco := {255,255,255}
cPrinter := GetPrinter()
If Empty (cPrinter)
EndIf
	SELECT PRINTER cPrinter ;
		ORIENTATION	PRINTER_ORIENT_PORTRAIT  ;
		PAPERSIZE	PRINTER_PAPER_LETTER ;
		QUALITY		PRINTER_RES_HIGH ;
		PREVIEW
	START PRINTDOC
	START PRINTPAGE
		@ 20,20 PRINT RECTANGLE ;
	      	 TO 30,190 ;
			 PENWIDTH 0.1 COLOR aMarino FILLED ROUNDED
		@ 23,100 PRINT ALLTRIM(cTitu)   ;
			 FONT "Arial" ;
			 SIZE 12 ;
		     BOLD	   COLOR aBlanco CENTER
	@40,20  PRINT ALLTRIM(cDom) FONT "Arial"  SIZE 9
	@33,190  PRINT "N.I.F. : " + ALLTRIM(cNif) FONT "Arial" RIGHT SIZE 9
	@47,20  PRINT ALLTRIM(cPob) FONT "Arial"  SIZE 9
	@ 100,20 PRINT RECTANGLE ;
	    	 TO 255,190 ;
	@105,50 PRINT "Concepto" FONT "Arial"  SIZE 9  COLOR aMarino
	@105,100 PRINT "Cant." FONT "Arial"  SIZE 9 COLOR aMarino
	@105,120 PRINT "Precio" FONT "Arial"  SIZE 9 COLOR aMarino
	@105,142 PRINT "Dct %" FONT "Arial"  SIZE 9 COLOR aMarino
	@105,165 PRINT "Importe" FONT "Arial"  SIZE 9 COLOR aMarino
	@113,20 PRINT LINE TO 113,190 PENWIDTH 0.1 COLOR aMarino
	@ 222,140 PRINT RECTANGLE ;
	    	 TO 255,190  PENWIDTH 0.1 COLOR aMarino
	END PRINTPAGE
	END PRINTDOC
Si algún compañero puede decirme como hacerlo, se lo agradeceré.
Cuidaros todos mucho en esta desagradable situación.
Un abrazo 'virtual'
Mustafa, Salinetas24, Que tal os va por ahí. Aquí en Almansa hoy deberían haber empezado nuestras Fiestas Patronales y Moros y Cristianos, pero desgraciadamente nada de nada, a salir al balcón y poco más.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
Re: Print rectangle Border
Maybe use a JPG?
Hola amigo Pepe, veo que estas Bien !!!
has probado con Curve 5 y sustituyo PRINT con HPDFPRINT ?
cNombre := MiPrint.Pdf"
    SELECT HPDFDOC cNombre ORIENTATION HPDF_ORIENT_PORTRAIT PAPERSIZE HPDF_PAPER_A4
    SET HPDFDOC ENCODING TO "WinAnsiEncoding"
   START HPDFDOC
         START HPDFPAGE
        @ 20,20 HPDFPRINT  RECTANGLE TO 30,190 PENWIDTH 0.1 COLOR aMarino FILLED ROUNDED CURVE 5
       END HPDFPAGE
    END HPDFDOC
Saludos Virtuales
Pepe el Sample Completo
Func Main( )
   REQUEST HB_CODEPAGE_ESWIN
   HB_SETCODEPAGE("ESWIN")
   REQUEST HB_LANG_ES
   HB_LANGSELECT("ES")
  SET LANGUAGE TO SPANISH
  SET CODEPAGE TO SPANISH
  PRIVATE  nL := 120 , cPrinter , cTitu := "Prueba" , cNif := "74.123.123-Q" , cDom := "San Adrián, nº 10", cPob := "Madrid" ,;
 PRIVATE  cNombre :="Sample.pdf"
   DEFINE WINDOW Principal AT 0,0  WIDTH 400  HEIGHT 300  TITLE '' MAIN;
              NOSIZE NOMAXIMIZE ICON "" ;
              ON INIT PrintDoc()
              ON KEY ESCAPE ACTION Principal.Release
CENTER WINDOW Principal
ACTIVATE WINDOW Principal
FUNCTION PrintDoc()
    SELECT HPDFDOC cNombre ORIENTATION HPDF_ORIENT_PORTRAIT PAPERSIZE HPDF_PAPER_A4     // LANDSCAPE  Vertical
*-----------------------------  Código Caracteres ANSI (Latinos) -------------------------------*
*   SET HPDFDOC ENCODING TO "CP1252"
   START HPDFDOC
            START HPDFPAGE
*-------------------------------------- Cuadro General ----------------------------------------*
     @ 005,005  HPDFPRINT RECTANGLE TO 292, 206 PENWIDTH 1 ROUNDED CURVE 1     // Opcional ?
     @ 007,007  HPDFPRINT RECTANGLE TO 290, 204            ROUNDED CURVE 1           // Opcional ?
*-------------------------------------- Recuadro Empresa ---------------------------------------*
		@ 26,100 HPDFPRINT ALLTRIM(cTitu)   ;
			 FONT "Arial" ;
			 SIZE 12 ;
	@42,020  HPDFPRINT ALLTRIM(cDom) FONT "Arial"  SIZE 9
	@35,190 HPDFPRINT  "N.I.F. : " + ALLTRIM(cNif) FONT "Arial" RIGHT SIZE 9
	@49,020  HPDFPRINT  ALLTRIM(cPob) FONT "Arial"  SIZE 9
	@ 100,20 HPDFPRINT RECTANGLE ;
	    	 TO 255,190 ;
	@107,050 HPDFPRINT"Concepto" FONT "Arial"  SIZE 9  COLOR aMarino
	@107,100 HPDFPRINT"Cant." FONT "Arial"  SIZE 9 COLOR aMarino
	@107,120 HPDFPRINT "Precio" FONT "Arial"  SIZE 9 COLOR aMarino
	@107,142 HPDFPRINT "Dct %" FONT "Arial"  SIZE 9 COLOR aMarino
	@107,165 HPDFPRINT "Importe" FONT "Arial"  SIZE 9 COLOR aMarino
	@113,20 HPDFPRINT LINE TO 113,190 PENWIDTH 0.1 COLOR aMarino
	@ 222,140 HPDFPRINT  RECTANGLE ;
       END HPDFPAGE
    END HPDFDOC
 Execute File cNombre
 Principal.Release
Pepe Ruano
mustafa wrote: Fri May 01, 2020 2:12 pm Hola amigo Pepe, veo que estas Bien !!!
   START HPDFDOC
         START HPDFPAGE
       END HPDFPAGE
    END HPDFDOC
Saludos Virtuales
Gracias Mustafa, veo que tú también estás bien de lo cual me alegro mucho.
No logro entender tu código y lo he probado y no me funciona, se supone que tendría que tener un archivo previo Miprint.pdf, pero no quiero imprimir un PDF, sólo quiero que imprima el código que tengo puesto en el ejemplo, que lleva más variables y usa campos de bd. Si eres tan amable mira mi código a ver si puedes cambiar algo para que sin ningún pdf se imprima lo que hay en el mismo. O un pequeño ejemplo simple que haga el preview pero sin ninguna llamada a un pdf.
Un abrazo amigo.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
Pepe Ruano
serge_girard wrote: Fri May 01, 2020 1:46 pm Maybe use a JPG?
Thanks serge, I will try it maybe it is a solution.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
Hola Pepe
Luego te mande el Prg completo
No se imprime Sample.pdf ?
solo he sustituido si te fijas PRINT por HPDFPRINT
y CURVE 5 <---------- @ 20,20 HPDFPRINT RECTANGLE TO 30,190 PENWIDTH 0.1 COLOR aMarino FILLED ROUNDED CURVE 5
Temando Código Prg y Sample.Pdf
Print.zip
(56.75 KiB) Downloaded 148 times
Pepe Ruano
mustafa wrote: Fri May 01, 2020 2:57 pm Hola Pepe
¡Vaya Mustafa! eres más rápido que el viento, muchas gracias.
Así sale perfecto el rectángulo, pero no quiero generar un PDF, como te he comentado quiero que salga la opción normal del Preview, seleccione la impresora y si entonces se quiere que lo imprima, sino no hay que imprimir nada.
A ver si se te ocurre algo.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
Lo del Fichero sample.pdf es para ver como queda el Sample
creo que podria ser :
Una Pregunta
IF MsgYesNo('Desea Imprimirr ? ','Crear Impresión' )
......etc etc
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hola Pepe,
Spanish
A menos que el tamaño del rectangulo sea dinamico, creo que la mejor solucion (y mas rapida) es la que propone usar un archivo JPG.
English
Unless the size of the rectangle is dynamic, I believe that the best solution (and quickest) is the one that proposes to use a JPG file.
[]´s Salamandra - Brazil
