Harbour MiniGUI Extended Edition build 20.04 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 20.04.
* Fixed problem with assigning of the BKBRUSH clause at a form
definition (introduced in the build 19.12).
* A correction in the function _SetValue() for a conflict between
the Timer and AniGif controls handling.
* A correction for the font attributes handling in the SplitButton
control.
* The Label, HyperLink, CheckBox and RadioGroup controls support
changing the 'Transparent' property at runtime.
* The EDIT controls family (TEXTBOX & EDITBOX) support changing
the 'CaseConvert' property at runtime.
It was a postponed user's request.
* The MONTHCAL control supports the BackColor, FontColor and
others color clauses in the THEMED Operating Systems.
* Improved user type of control in INPLACE EDIT of GRID control.
DYNAMIC type is defined as { cControlType, bCodeBlock [, bChange] }
where cControlType = 'DYNAMIC' (Required)
bCodeBlock = CodeBlock that return array with normal type control
(Required)
bChange = CodeBlock with ON CHANGE action (Optional)
to above CodeBlock is passed one param - a current control value.
Added a new control type 'CODEBLOCK' for using with 'DYNAMIC' type.
* The ANIMATEBOX control supports now an optional INVISIBLE clause.
* The FONT clause in the POPUP and MENUITEM commands supports
a font name for the fonts which were defined by the command
DEFINE FONT <font> FONTNAME <name>.
* Limited the height of the dialog box in the function HMG_Alert()
to be able to output more than 20 strings in the EditBox control.
* The HMG Debugger resources were moved from the sample DBG_TEST
to the application resources.
* Updated Harbour Compiler 3.2.0dev to a recent Git-version.
* Updated TSBrowse and Sqlite3 libraries.
* Added the new interesting samples and updated the some Basic and
Advanced samples.
A setup of the build 20.04 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra Minigui Ex build for the Embarcadero C++ 10.2
‘Tokyo’ compiler. Note: it is a donationware distribution.
[MiniGUI Team]
JALMAG
DBs Used: DBF, MariaDB
Re: Harbour MiniGUI Extended Edition build 20.04 is published
Post by JALMAG »
Thank "maestro Grigory"
Donation made
Steed
Post by Steed »
Thanks
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Thank you Grigory !!
[]´s Salamandra - Brazil
JALMAG wrote: Fri May 01, 2020 10:53 am Thank "maestro Grigory"
Donation made
Hello Jose Adolfo,
Thank you VERY MUCH for your support :!:
I'm very appreciate this.
