FTP PC to Mobile
FTP PC to Mobile
Hello everyone:
implement an application to read the content of our mobile in a good option, very few cell phones deliver a connection like F: others "Internal storage" and "SDcard", the only thing I see as bad is being tied to the PC By means of the USB cable and its length, that receiving msg, calls or / or other form of communication becomes cumbersome.
Let's give freedom to our mobile to go free through an FTP connection.
Download an app that supports FTP on our phone. FileZilla, file manager+, etc.etc, etc
[/centre]
We can access our mobile through an application Harbor / HMG, Filezilla or Windows Explorer, Etc.
in windows file explorer type
ftp://192.168.1.2:8556 or the assigned IP address with or without username and password (do not leave insecure connections in WIFI connections, it is not recommended).
2020-04-04 09_14_41-Window.png (13.42 KiB) Viewed 1185 times
[/centre]
Simple File Navigator form friend / collaborator EDK http://hmgforum.com/download/file.php?id=8699
To properly compile you should have the HMG 3.4.4 version installed
Then, from this package: http://hmgforum.com/download/file.php?id=8685 copy all files from the "lib" folder to "c:\hmg.3.4.4\HARBOUR\lib\win\mingw"
You compile by running "build_SFTP.bat" (we compile sftp.hbp not sftp.prg)
The hbcurl.ch file should be in "c:\hmg.3.4.4\HARBOUR\contrib\hbcurl\"
this info was taken from http://hmgforum.com/viewtopic.php?f=24&t=5820
Re: FTP PC to Mobile
Thanks Daniel !
I will try as soon as possible.
there are many Ways to connect a Handy with PC
older Handy most had a Software "just" for a special Model or USB-Cable which you need for Transfer :roll:
Apple Hardware just work with Apple iTunes so i was surprise when Windows 10 show it as Device. :o
it seems me now the Way to transfer Image from SmartPhone -> PC as Explorer show that Option.
it work with my iPhone and also with an old Nokia Lumia 550 using Windows Mobile which i got for Test.
p.s. have Problem to "find" Image on Lumia while it have so much Folder ... Window 10 seems to "know" which Folder to transfer ... hm :idea:
