MY CLIPPER 5.2 APPLICATION HAS 15 DBF FILES AND 32 INDEX FILES.WHILE I RUN IT , THERE IS RUN TIME ERROR DBFNTX 1001/ DOS ERROR 4 .
I INCREASED FILE ENV. VARIABLE AS FILE=100 IN CONFIG. SYS BUT STILL SAME PROBLEM,
I AM USING WINDOWS VISTA.
HOWEVER , IF I CLOSE SOME OPEN DBFS, THEN NO ERROR.
FELLOW MEMBERS , PL. SUGGEST SOLUTION.
IC JINDAL
DBFNTX/1001 DOS ERROR 4
- HMG Founder
Re: DBFNTX/1001 DOS ERROR 4
Please, try make modifications in \windows\system32\config.nt file instead \consig.sys.icjindal wrote:MY CLIPPER 5.2 APPLICATION HAS 15 DBF FILES AND 32 INDEX FILES.WHILE I RUN IT , THERE IS RUN TIME ERROR DBFNTX 1001/ DOS ERROR 4 .
IC JINDAL
And, in \Windows\System32\Autoexec.nt add
SET CLIPPER=F100
BTW, why don't you convert to Harbour from Clipper. It is very easy and need very small changes. But, your program needs no setup in config.nt and autoexec.nt
And then convert to HMG
(Regarding harbour conversion you may personally mail me)
Regards.
SET CLIPPER=F100
Regards.
THANK TO ALL OF YOU.
IC JINDAL
IC JINDAL
