path to iPhone DCIM Directory
Re: path to iPhone DCIM Directory
I get "get folder" window as on the picture attached
- AUGE_OHR
i mean : what do you get with GETFOLDER()
does it return a "valid" Path so you can use DIR and get Result
there is a Button "Get Folder" and it show APPLE Device but you will get no Result when try it.
i can use it on "real" Folder but not on Device Folder which are "virtual" like a ZIP Folder which Windows open when Dblclick on ZIP.
i don´t know if your Handy will work that Windows Way.
You have ask for Source, now you have it and can use Debugger to "see" what is going on.
it might be that "internal" Name is different from Explorer Name e.g. UPPER() so this Line fail
IF cName = cPhone
I'm trying what goes wrong with my phone.
Thereis different structure of folders.
But, problem occurs in GetDevicePath function.
oDCIMFile can be a directory or a file.
When it becomes file - it generates runtime error.
We should test if it's file or directory
oAppleFolder := oDCIMFile:GetFolder:Items
- AUGE_OHR
you are right that we have to test if file or folder.
Property are found here
https://docs.microsoft.com/en-us/window ... folderitem
aha ... now we get Step on.
Marku sprawdź tę wersję:
Nie wnikałem w strukturę folderów, jakie przyjął Jimmy. Myślę, że trzebaby tu zrobić rekurencję a nie na sztywno jak jest teraz.
Dodałem sprawdzanie czy element jest plikiem czy folderem, zrobiłem też listę rozwijaną urządzeń przenośnych z możliwością odświerzenia - nie trzeba wpisywać ręcznie nazwy urządzenia
Edward.
@Jimmy.
I am so sorry, Jimmy, that I violated your "Copyright(C) 1983-2020 by Auge & Ohr"
*+ Source Module => c:\hmg.3.4.4\0\IPHONE\\HBIPHONE.PRG
*+ Copyright(C) 1983-2020 by Auge & Ohr
*+ Functions: Procedure MAIN()
*+ Static Procedure GetTargetFolder()
*+ Static Procedure SearchDevice()
*+ Static Function GetDevicePath()
*+ Static Procedure SayList()
*+ Static Function CutLine()
*+ Static Procedure DoCopyHere()
*+ Static Procedure DoCopySingle()
*+ Function CalcPos()
*+ Reformatted by Click! 2.05.30 on Mar-30-2020 at 9:18 am
#include "HMG.CH"
#include "Common.CH"
#define FOF_SIMPLEPROGRESS 0x0100a
MEMVAR _HMG_SYSDATA
*+ Procedure MAIN()
PROCEDURE MAIN
LOCAL aDevices := GetHandy()
LOCAL cTarget := "F:\IPHONE\"
LOCAL afiles := {}
PUBLIC _HMG_SYSDATA
SET DATE GERMAN
SET EPOCH TO YEAR( DATE() )
SET CENTURY ON
DEFINE WINDOW IPHONE ;
AT 0, 0 ;
WIDTH 1000 ;
HEIGHT 768 ;
TITLE "HMG_GetImage_from_iPhone_DCIM" ;
ICON "A1MAIN" ;
ON INIT Nil ;
ON RELEASE Nil ;
NOSIZE ;
NOMAXIMIZE ;
NOMINIMIZE ;
ON PAINT Nil ;
BACKCOLOR Nil
DEFINE EDITBOX Loglist
ROW 20
COL 10
WIDTH 710
HEIGHT 90
VALUE ""
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
TABSTOP .T.
VISIBLE .T.
READONLY .F.
HSCROLLBAR .T.
VSCROLLBAR .T.
END EDITBOX
DEFINE TEXTBOX cDevice
ROW 20
COL 731
WIDTH 260
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 9
TABSTOP .T.
VISIBLE .T.
READONLY .F.
CASECONVERT NONE
VALUE ""
END TEXTBOX
@ 20, 731 COMBOBOX cbDevice ITEMS aDevices VALUE 1 WIDTH 200;
ON CHANGE { || IPHONE.Button_Search.Enabled := aDevices [ IPHONE.cbDevice.Value ] <> "- No devices -" }
@ 20, 936 BUTTON bRefresh PICTURE "_REFRESH" ON CLICK { || ( aDevices := GetHandy(), ComboRefresh(aDevices) ) } ;
WIDTH 50 HEIGHT 24
DEFINE TEXTBOX cTarget
ROW 50
COL 731
WIDTH 260
HEIGHT 30
FONTNAME "Arial"
FONTSIZE 9
TABSTOP .T.
VISIBLE .T.
READONLY .F.
CASECONVERT NONE
VALUE ""
END TEXTBOX
DEFINE BUTTON Button_GetDir
ROW 80
COL 730
WIDTH 100
HEIGHT 30
ACTION GetTargetFolder()
CAPTION "&Get Folder"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP "select Target Folder"
TABSTOP .T.
VISIBLE .T.
END BUTTON
DEFINE BUTTON Button_Search
ROW 80
COL 890
WIDTH 100
HEIGHT 30
ACTION SearchDevice( aDevices [ IPHONE.cbDevice.Value ], .F. )
CAPTION "&search Device"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP "search for Device and files"
TABSTOP .T.
VISIBLE .T.
END BUTTON
DEFINE BUTTON Button_GetSelect
ROW 80
COL 890
WIDTH 100
HEIGHT 30
ACTION SearchDevice( aDevices [ IPHONE.cbDevice.Value ], .T. )
CAPTION "&Transfer files"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP "Transfer files to Target Folder"
TABSTOP .T.
VISIBLE .F.
END BUTTON
DEFINE GRID Grid_1
ROW 120
COL 10
WIDTH 980
HEIGHT 580
ITEMS afiles
VALUE Nil
WIDTHS { 200, 100, 100, 500 }
HEADERS { 'Name', 'Size', 'Date', 'Type' }
FONTNAME "Arial"
FONTSIZE 9
ONDBLCLICK Nil
MULTISELECT .T.
SHOWHEADERS .T.
ITEMCOUNT Nil
END GRID
DEFINE PROGRESSBAR ProgressBar_1
ROW 710
COL 10
WIDTH 980
HEIGHT 20
RANGEMIN 1
RANGEMAX 100
VALUE 0
VISIBLE .T.
SMOOTH .F.
VERTICAL .F.
END PROGRESSBAR
IPHONE.ProgressBar_1.Value := 0
IPHONE.cTarget.Value := cTarget
//IPHONE.cDevice.Value := cDevice
IPHONE.Grid_1.CheckBoxEnabled := .T.
ON KEY ESCAPE OF IPHONE ACTION IPHONE.Release
CENTER WINDOW IPHONE
IPHONE.Button_Search.setfocus()
ACTIVATE WINDOW IPHONE
*+ Called from ( hbiphone.prg ) 1 - procedure main()
STATIC PROCEDURE GetTargetFolder()
LOCAL cFolder := GETFOLDER()
IF !EMPTY( cFolder )
IPHONE.cTarget.Value := cFolder + "\"
*+ Called from ( hbiphone.prg ) 2 - procedure main()
STATIC PROCEDURE SearchDevice( cDevice, lTransfer )
//LOCAL cDevice := UPPER( TRIM( IPHONE.cDevice.Value ) )
LOCAL cTarget := UPPER( TRIM( IPHONE.cTarget.Value ) )
LOCAL i, iMax, hGrid, aGridfiles
IF !EMPTY( cDevice ) .AND. !EMPTY( cTarget )
IF lTransfer = .T.
aGridfiles := GetDevicePath( cDevice, cTarget, lTransfer )
IPHONE.Button_GetSelect.hide()
IPHONE.Button_Search.Show()
aGridfiles := GetDevicePath( cDevice, cTarget )
IF !EMPTY( aGridfiles )
Domethod( "IPHONE", "Grid_1", "DisableUpdate" )
Domethod( "IPHONE", "Grid_1", "DeleteAllItems" )
iMax := LEN( aGridfiles )
FOR i := 1 TO iMax
Domethod( "IPHONE", "Grid_1", "addItem", aGridfiles[ i ] )
IPHONE.Grid_1.CheckBoxAllItems := .T.
Domethod( "IPHONE", "Grid_1", "EnableUpdate" )
Domethod( "IPHONE", "Grid_1", "Refresh" )
Domethod( "IPHONE", "Grid_1", "SetFocus" )
hGrid := GetControlHandle( "Grid_1", "IPHONE" )
IPHONE.Button_Search.hide()
IPHONE.Button_GetSelect.Show()
IF cDevice <> "- No devices -"
MsgInfo( "no items on Device " + cDevice + " found" )
*+ Called from ( hbiphone.prg ) 2 - static procedure searchdevice()
STATIC FUNCTION GetDevicePath( cDevice, cTarget, lAction )
LOCAL oShell, oFolder, oStorageFolder, aFiles := {}
LOCAL cName, oItems, oItem, aResult := {}
LOCAL i, iMax, j, jMax, cThis, oStorageFile, cPath, cSrcP, oFiles, oFile, n, nMax
LOCAL oDCIMFolder, k, kMax, oDCIMFile, l, lMax, oAppleFolder, oAppleFile, oDirFolder
LOCAL c_Name, c_Size, c_Date, c_Attr, c_Type, aGridfiles := {}
DEFAULT lAction TO .F.
oShell := CreateObject( "shell.application" )
IF NIL <> oShell
oFolder := oShell:NameSpace( CSIDL_DRIVES ) // 0x0011 // My Computer
IF NIL <> oFolder
oItems := oFolder:Items()
iMax := oItems:Count
FOR i := 1 TO iMax
oItem := oItems:Item( i - 1 )
IF !EMPTY( oItem )
//cName := UPPER( oItem:name )
cName := oItem:name
SayList( cName )
IF cName = cDevice // "APPLE IPHONE"
cPath := oItem:path // GUID ?
// "Internal Storage"
oStorageFolder := oItem:GetFolder:items
IF !EMPTY( oStorageFolder )
jMax := oStorageFolder:Count
FOR j := 1 TO jMax
DO EVENTS
oStorageFile := oStorageFolder:Item( j - 1 )
IF !EMPTY( oStorageFile )
cThis := UPPER( oStorageFile:name ) // "Internal Storage"
cSrcP := oStorageFile:Path // Path ?
AADD( aResult, { cThis, cPath, cSrcP } )
SayList( cThis )
if !oStorageFile:IsFolder
loop
// "DCIM"
oDCIMFolder := oStorageFile:GetFolder:Items
kMax := oDCIMFolder:Count
FOR k := 1 TO kMax
DO EVENTS
oDCIMFile := oDCIMFolder:Item( k - 1 )
cThis := oDCIMFile:name
cSrcP := oDCIMFile:Path
SayList( cThis )
if !oDCIMFile:IsFolder
loop
// 103APPLE
lMax := oAppleFolder:Count
FOR l := 1 TO lMax
DO EVENTS
oAppleFile := oAppleFolder:Item( l - 1 )
cThis := oAppleFile:name
cSrcP := oAppleFile:Path
SayList( cThis )
#IFDEF Hole_Folder
// this copy hole Folder to Target
DoCopyHere( oAppleFile, cTarget )
#ENDIF
// Media files
if !oAppleFile:IsFolder
loop
oDirFolder := oAppleFile:GetFolder:Items
IF lAction = .T.
DoCopySingle( oDirFolder, cTarget )
nMax := oDirFolder:Count
SayList( "found " + LTRIM( STR( nMax ) ) + " files" )
FOR n := 1 TO nMax
DO EVENTS
oFile := oDirFolder:Item( n - 1 )
cThis := oFile:name
cSrcP := oFile:Path
AADD( aFiles, { cThis, cPath, cSrcP } )
c_Name := oFile:name
c_Size := oFile:Size
c_Date := oFile:ModifyDate
c_Type := oFile:Type
AADD( aGridfiles, { c_Name, c_Size, c_Date, c_Type } )
EXIT
IF hb_isNil ( cPath )
MsgInfo( "no Device " + cDevice + " found" )
oFolder := NIL
oShell := NIL
RETURN aGridfiles
*+ Called from ( hbiphone.prg ) 5 - static function getdevicepath()
STATIC PROCEDURE SayList( cText )
STATIC cLast := ""
cLast += cText + CRLF
IPHONE.Loglist.Value := CutLine( cLast )
*+ Called from ( hbiphone.prg ) 1 - static procedure saylist()
STATIC FUNCTION CutLine( cIn )
LOCAL cOut := ""
LOCAL i, iMax
LOCAL nLines := 4
iMax := MLCOUNT( cIn, 80 )
IF iMax > nLines
FOR i := iMax - nLines TO iMax
cOut += TRIM( MEMOLINE( cIn, 80, i ) ) + CRLF
cOut := cIn + CRLF
RETURN cOut
*+ Called from ( hbiphone.prg ) 1 - static function getdevicepath()
STATIC PROCEDURE DoCopyHere( oAppleFile, cTarget )
LOCAL obj := CreateObject( "Shell.Application" )
LOCAL oFolder := obj:NameSpace( cTarget )
oFolder:CopyHere( oAppleFile )
STATIC PROCEDURE DoCopySingle( oDirFolder, cTarget )
LOCAL oTarget := obj:NameSpace( cTarget )
LOCAL xFlag := FOF_SIMPLEPROGRESS
LOCAL aFiles := {}
LOCAL oFile, cFile, xCount, nCount
LOCAL i, iMax, nSkip := 0
iMax := oDirFolder:Count
FOR i := 1 TO iMax
DO EVENTS
// if Checkbox is marked
IF IPHONE.Grid_1.CheckBoxItem( i ) = .T.
// get Item Object
oFile := oDirFolder:Item( i - 1 )
// copy single Object file
oTarget:CopyHere( oFile, xFlag )
// wait until all files are written
xCount := 0
DO WHILE .T.
DO EVENTS
// compare if file is written
nCount := oTarget:items() :Count()
IF nCount + nSkip >= i
EXIT
SLEEP( 10 )
xCount ++
IF xCount > 50
EXIT
ENDDO
// Skip un-maked
nSkip ++
IPHONE.ProgressBar_1.Value := CalcPos( iMax, i )
// clean up
oTarget := NIL
obj := NIL
*+ Called from ( hbiphone.prg ) 1 - static procedure docopysingle()
STATIC FUNCTION CalcPos( nValue, iMax )
LOCAL nRet := 0
LOCAL nEvery
LOCAL xScale
IF iMax < 100
nEvery := INT( 100 / iMax )
xScale := iMax / nEvery // Scale to 100%
nRet := iMax / xScale * nValue
nEvery := INT( iMax / 100 )
xScale := iMax * nEvery // Scale to 100%
RETURN INT( nRet )
FUNCTION GetHandy()
Local aDev:={}, oDev, oItem, i
Local oShell := CreateObject( "shell.application" )
IF hb_isObject( oShell )
oDev := oShell:NameSpace( CSIDL_DRIVES ) // 0x0011 // My Computer
IF hb_isObject ( oDev )
FOR i := 1 TO oDev:Items():Count
oItem := oDev:Items():Item( i - 1 )
IF !EMPTY( oItem ) .AND. !oItem:isFileSystem
AADD (aDev, oItem:Name)
IF EMPTY ( aDev )
aDev := { "- No devices -" }
RETURN aDev
FUNCTION ComboRefresh(aDevices)
Local i
IPHONE.cbDevice.Enabled:=.F.
IPHONE.cbDevice.DeleteAllItems
FOR i =1 TO Len( aDevices )
IPHONE.cbDevice.AddItem (aDevices [i])
NEXT i
IPHONE.cbDevice.Value:=1
IPHONE.cbDevice.Enabled:=.T.
RETURN Nil
// EOF: HBIPHONE.PRG
Edward.
@Jimmy.
I'm building solution with tree and recursion. I have a problem with mark items in the tree.
- AUGE_OHR
have made a new Concept for PhoneTransfer
i have to make more test to make it stable ... and add "Thumbs Pre-View"
had the same Idee ...
LOCAL nItem := IPHONE.Tree_1.Value
LOCAL cPhone := TRIM( IPHONE.Tree_1.Item(nItem) )
Fabuloso !, la primera prueba OK.
Pregunta:
Cual es la intención de los controles EDITBOX Loglist y TEXTBOX cTarget ?
(porque yo ya tengo asignada la unidad F:)
Fabulous !, the first test OK.
Question:
What is the intent of the EDITBOX Loglist and TEXTBOX cTarget controls?
(because I already have drive F assigned
Pregunta:
Question:
- AUGE_OHR
EDITBOX was just for Debug ... now i use a Tree instead
cTarget is the Folder where files goes to using COPYHERE()
p.s. i just saw you have DCIM -> 2 x Sub-Folder ... "last" Code will only work with 1st Folder ...
ok have to made some Video to simulate it ... are there "more" Folder
Hi ....
Something I never saw in apps that copy content is the ability to display only content that has not been copied to the destination folder.
It would be an option to compare the 2 directories and generate the Tree with those files that were not copied.
Algo que nunca vi en aplicaciones que copian contenido es la posibilidad de mostrar solo el contenido que no haya sido copiado en la carpeta de destino.
seria una opcion de comparar los 2 directorios y generar el Tree con aquellos archivos que no fueron copiados.
