path to iPhone DCIM Directory
when connect my iPhone to Windows 10 via USB i go a new Device "Apple iPhone"
i can open Folder with Explorer and get to "This PC\Apple iPhone\Internal Storage\DCIM"
Question : how get to that Folder with harbour / HMG :idea:
iPhone is not shown as Storage only as
Apple Mobile Device USB Composite Device
Re: path to iPhone DCIM Directory
hi
thx for Link, i will study it
i have work on link
https://stackoverflow.com/questions/110 ... n-windows
and i got "full-path" and file-Name
   cItem := "APPLE IPHONE"
   oShell := CreateObject( "shell.application" )
   IF NIL <> oShell
      oFolder := oShell:NameSpace(CSIDL_DRIVES ) // 0x0011 // My Computer
      IF NIL <> oFolder
         oItems := oFolder:Items()
         iMax := oItems:Count
         FOR i := 1 TO iMax
            oItem := oItems:Item( i - 1 )
            IF !EMPTY( oItem )
               cName := UPPER( oItem:name )
               IF cName = cItem                  // "APPLE IPHONE"
                  cPath := oItem:path            // GUID ?
next was Sub-Folder to get to folder with Image
 oFolderItem := oItem:GetFolder:items  // "APPLE IPHONE"
  objFolder := oThis:GetFolder:Items   // "Internal Storage"
   oItemL := oItemF:GetFolder:Items    // "DCIM"
    oItemN := oItemM:GetFolder:Items   // "103APPLE"
    nMax := oItemN:Count
    FOR n := 1 TO nMax
      oFile := oItemN:Item( n - 1 )
      cThis := oFile:name
      cSrcP := oFile:Path
      AADD(aFiles,{cThis,cPath,cSrcP})
now i have try to use CopyFile API ...
https://docs.microsoft.com/en-us/previo ... dfrom=MSDN
   IF !EMPTY(aFiles)
      fso := CreateObject("Scripting.FileSystemObject")
      iMax := LEN(aFiles)
      FOR i := 1 TO iMax
         cFile := aFiles[i][3]
         cFile += "\"
         cFile += aFiles[i][1]
         fso:CopyFile(cFile,cTarget)
      fso := NIL
but something is going wrong
i "think" something in "Path" (cSrcP) is wrong ... or is it my Syntax :idea:
IPHONE01.ZIP
(1.01 KiB) Downloaded 144 times
Hi Jimmy:
I do not have Ihpone, I have Motorola G8 plus that also delivers a Virtual unit like MotoG8 inside the unit: Internal storage and SD card, I see that it is well on track with its source code, my point of view is how to work with FileCopy in virtual drives since I did not fully read the link I sent you or the Harbor code, nor did I know how to find out the virtual drives on your PC.
Hola Jimmy : no tengo Ihpone, tengo Motorola G8 plus que tambien entrega una unidad Virtual como MotoG8 dentro la unidad: Almacenamiento interno y SD card, veo que va bien encaminado con su codigo fuente, mi punto de vista es como trabajar con FileCopy en las unidades virtuales ya que no lei completamente el enlace que le envie ni el codigo Harbour, tampoco se como hizo para averiguar las unidades virtuales en su PC.
AUGE_OHR wrote: Sun Mar 29, 2020 7:16 am hi
   IF !EMPTY(aFiles)
      iMax := LEN(aFiles)
      FOR i := 1 TO iMax
         cFile += "\"
      fso := NIL
IPHONE01.ZIP
https://docs.microsoft.com/en-us/window ... e-copyfile
it seems more complicate
   fsMyStream = System.IO.File.Open(taregetFullFileName, IO.FileMode.Open, IO.FileAccess.ReadWrite)
   fsMyStream.Close()
i have to create a Stream to "Copy" ... :roll:
go it :D
after get "Folder" 103APPLE i use this to copy hole Folder
PROCEDURE DoCopyHere(oAppleFile, cTarget )
LOCAL obj := CreateObject( "Shell.Application" )
LOCAL oFolder := obj:NameSpace(  cTarget )
   oFolder:CopyHere(oAppleFile)
i guess it work also for "other" Device when display under "My Computer"
will make a full Demo ...
have try next Step to select wanted Images
but i have to figure out how to "transfer" with COPYHERE()
https://docs.microsoft.com/en-us/window ... r-copyhere
p.s. Size 0 and funny Date ... hm
i "remember" that i have use COPYHERE before ... to ZIP Files :D
Problem was : COPYHERE work Asynchrone so it need a "Trick"
PROCEDURE DoCopySingle( oDirFolder, cTarget )
LOCAL oTarget := obj:NameSpace( cTarget )
LOCAL xFlag   := FOF_SIMPLEPROGRESS
LOCAL aFiles  := {}
LOCAL oFile, cFile, xCount, nCount, i, iMax, nSkip := 0
   iMax := oDirFolder:Count
   FOR i := 1 TO iMax
      // if Checkbox is marked
      IF IPHONE.Grid_1.CheckBoxItem( i ) = .T.
         // get Item Object
         oFile := oDirFolder:Item( i - 1 )
         // copy / stram single Object file
         oTarget:CopyHere( oFile, xFlag )
         // wait until all files are written
         xCount := 0
         DO WHILE .T.
            // compare if file is written
            nCount := oTarget:items() :Count()
            IF nCount + nSkip >= i
               EXIT
            SLEEP( 10 )
            xCount ++
            IF xCount > 50
               EXIT
         ENDDO
         // Skip un-marked
         nSkip ++
      IPHONE.ProgressBar_1.Value := CalcPos(i, iMax )
   // clean up
   IPHONE.ProgressBar_1.Value := 0
   oTarget := NIL
   obj := NIL
