files on external drives
Templar
Post by Templar »
Can you "USE" a data file off a different drive?
eg: ( If my installation is on C:\ drive )
A command like USE E:\BOOKS\AUTHORS.dbf
will not actually open the file. It can find it okay, so:
IF FILE("E:\BOOKS\AUTHORS.dbf")
< Display some error message >
does not display the error message, but it does nothing!!
Any suggestions how to get round this?
Templar
Re: files on external drives
Porque utilizar la letra de la unidad ?
Cuando ejecutas tu programa, asume que tus bases de datos se encuentran
en la carpeta (o tu le indicas las subcarpetas ) de donde está arrancando.
Si te fijas, todos los ejemplos de HMG,
NO UTILIZAN la letra de la unidad.
USE AUTHORS
Debería de ser suficiente.
Why use the drive letter?
When you run your program, assume that your databases are
in the folder (or you indicate the subfolders) where it is booting from.
If you look, all the HMG examples,
DO NOT USE the drive letter.
USE AUTHORS
It should be enough.
try to use
SET PATH TO E:\BOOKS
you can also use list of your locations separated by semicolon
You can also use SET DEFAULT TO [xcPatspec]
Sample from Clipper 5 manual:
set default to e:\books
? file("authors.dbf")    //result: .T.
Templar wrote: Wed Mar 25, 2020 5:12 pm Can you "USE" a data file off a different drive?
Templar
The simplest way is to use DbUseArea("e:\books\authors.dbf")
you talk about external Drive ... is it a USB-Drive or Network-Drive :?:
if USB-Drive : check Attribut if File have "R"eadonly Flag
can you open that DBF when copy to your Home-Directory. :?:
SALINETAS24
Post by SALINETAS24 »
Hola Auge.., igual es esto lo que buscas.
cFile:="E:\BOOKS\AUTHORS.dbf"
	USE (cFile)
Abrazos virtuales.., y vamos con la cervecita....
Templar
Post by Templar »
Thanks to everyone for suggestions. Let me explain more.
I am writing a program to install my main package elsewhere. So first I copy all the necessary files from the C:\ drive onto the flashdrive at E:\. Then I want to open one of those files off the flashdrive.
Andyglezl: thanks, but I can't change the default, because I am still using files off C:\ as well.
Mol: Thanks but same thing. I need to use files off two different drives
Auge_ohr: Nope! Checked the Read Only flag. It isn't set
Salenitas24: Thanks, but actually I am enfolding it in a variable. I just simplified it for my example!
The file is certainly there: I can see it in File Explorer and the program checks it is there before trying to open it. So what happens is that it goes through "USE books.dbf" with no error message, but then "GO TOP" produces an error message: "Workarea not in use"
It's odd!
Templar
Templar,
File is maybe corrupt?
Try another file.
Try to prepare working sample producing error.
Some of us have a lot of time now...
RPC
Post by RPC »
mol wrote: Sun Mar 29, 2020 5:46 pm Some of us have a lot of time now...
Hi mol
Maybe you can help in my memory problem which I posted here ;)
Rajeev
