Save and restore arrays
RPC
Post by RPC »
I am trying to save and restore check box state in arrays.
There is a check box which can check/uncheck all remaining check boxes. What I want is if I check one or more of the remaining check boxes(in the enclosed example 3), I should be able to save the state of these check boxes and when the program is run again the same state be restored. For eg to check 2nd box I will first uncheck all(by clicking on Sel/Unsel all check box and then click 2nd check box. After this I will press Save & Exit button.
When I start my program again I expect to have only 2nd check box checked, but I find all the boxes unchecked because Sel/Unsel all check box was unchecked.
Is there a way to have the state of check boxes restored as it was when saved.
It seems when ACTIVATE WINDOW ... is executed it executes function SelectAll() which causes this.
Please help.
Thanks
Re: Save and restore arrays
Hello,
I suggust to use an INI file from where you restore and save to. I have a sample but cannot find it right now.
      FOR A = 1 TO 10
         c1 := 'C' + ALLTRIM(STR(A))
         SET SECTION c1          ENTRY c1       TO ''
// and GET
      FOR A = 1 TO 10
         GET c1 SECTION c1          ENTRY c1
         AADD(aCONTR_AD, c1 )
This way !
RPC
Post by RPC »
Thanks Serge
I will try your suggestion.
I think problem is not with restoring array values as such. The problem is SelAll() function gets executed when window is activated which causes all the check boxes to be set to .f. since Sel/Unsel check box was set to .f. when saved.
Still I will try INI file method and see if it helps.
Thanks
PS:Sorry I forgot to enclose my program earlier. Perhaps this will help to understand my problem better.
testmemvar.zip
(2.56 KiB) Downloaded 145 times
what Type is your Array where your try to save "State" of Checkbox :?:
i use a Field-Wide STATIC on Top of Form to hold last Result
STATIC cSeek := ""
Function Blabla()
   DEFINE WINDOW ...
      // Code
next Time when call Function Blabla() i still have cSeek.
same Technique can be done with Array so that i a possible Way
you say "next time" and want "same Screen" ... so what about hide() / show() it :idea:
if those Window are Part of a Form i "o.Release" before Form.Release.
i´m not sure how harbour / HMG will "clean up" when Create/Release.
i might be a Problem when App run 24/7 with Resource Handle
RPC wrote: Fri Feb 14, 2020 10:34 am Thanks Serge
Thanks
Please try the updated working sample below:
#include "HMG.CH"
FUNCTION main()
PRIVATE cVars, aVars := {}, cSetFile1, cSetFile2, lInit := .F.
aVars := array( 4, 2 )
DEFINE WINDOW TESTMEMVAR MAIN AT 20,20 WIDTH 200 HEIGHT 200
       DEFINE CHECKBOX checkbox_0
	          ROW 10
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE .t.
			  CAPTION "Select/Unselect All"
			  ONCHANGE iif(!lInit,SelectAll(),)
        END CHECKBOX
       DEFINE CHECKBOX checkbox_1
	          ROW 30
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE .t.
			  CAPTION "Check 1"
        END CHECKBOX
       DEFINE CHECKBOX checkbox_2
	          ROW 50
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE .t.
			  CAPTION "Check 2"
        END CHECKBOX
       DEFINE CHECKBOX checkbox_3
	          ROW 70
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE .t.
			  CAPTION "Check 3"
        END CHECKBOX
		DEFINE BUTTON button_1
		      ROW 100
			  COL 30
			  WIDTH 120
			  HEIGHT 30
			  CAPTION "SAVE && EXIT"
              ACTION saveVars()
			  PICTURE "save"
			  PICTALIGNMENT LEFT
		END BUTTON
RESTVARS()
CENTER WINDOW TESTMEMVAR
ACTIVATE WINDOW TESTMEMVAR
FUNCTION saveVars()
MEMVAR aVars, cVSel, cSetFile1
fillvars()
cSetFile1 := getstartupfolder()+'\memvarfile1.mem'
cVars := HB_Serialize(aVars)
HB_MvSave(cSetFile1, "cVars")
thiswindow.release
RETURN nil
FUNCTION restvars()
MEMVAR cSetFile1, cVars, aVars
if file(cSetFile1)
   HB_MvRestore(cSetFile1, .t.)
   aVars := HB_DeSerialize( cVars )
lInit := .T.
   TESTMEMVAR.checkBOX_1.value := aVars[ 1, 2 ]
   TESTMEMVAR.checkBOX_2.value := aVars[ 2, 2 ]
   TESTMEMVAR.checkBOX_3.value := aVars[ 3, 2 ]
   TESTMEMVAR.checkBOX_0.value := aVars[ 4, 2 ]
lInit := .F.
RETURN nil
FUNCTION fillvars()
    aVars[ 1, 1 ] := "CHECK1"
	aVars[ 2, 1 ] := "CHECK2"
	aVars[ 3, 1 ] := "CHECK3"
	aVars[ 4, 1 ] := "Sel/Unsel"
    aVars[ 1, 2 ] := testmemvar.checkbox_1.value
    aVars[ 2, 2 ] := testmemvar.checkbox_2.value
    aVars[ 3, 2 ] := testmemvar.checkbox_3.value
	aVars[ 4, 2 ] := testmemvar.checkbox_0.value
FUNCTION SelectAll()
MEMVAR aVars
if testmemvar.checkbox_0.value == .t.
   testmemvar.checkbox_1.value := .t.
   testmemvar.checkbox_2.value := .t.
   testmemvar.checkbox_3.value := .t.
   for i = 1 to 3
       aVars[ i, 2 ] := .t.
   Next
elseif testmemvar.checkbox_0.value == .f.
   testmemvar.checkbox_1.value := .f.
   testmemvar.checkbox_2.value := .f.
   testmemvar.checkbox_3.value := .f.
if !lInit
   for i = 1 to 3
       aVars[ i, 2 ] := .f.
   Next
RETURN nil
Hope that helps :idea:
Hello friends:
Another option based on the sample of Master Grigory
working with the files -> "mem"
#include "HMG.CH"
FUNCTION main()
  PRIVATE xeck0 ,  xeck1 ,  xeck2 ,  xeck3
  IF !FILE('xeckyn.mem')
     xeck0  := .T.
     xeck1  := .T.
     xeck2  := .T.
     xeck3  := .T.
     SAVE TO xeckyn.mem ALL LIKE  xeck*
 DEFINE WINDOW Form_1 MAIN AT 20,20 WIDTH 200 HEIGHT 200 NOSIZE NOMAXIMIZE
  RESTORE FROM xeckyn.mem ADDITIVE
	                  ROW 10
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE xeck0  //.t.
                          ONCHANGE ReverseCheck()
                   END CHECKBOX
	                  ROW 30
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE  xeck1  //.t.
			  CAPTION "Check 1"
                   END CHECKBOX
	                  ROW 50
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE  xeck2  //.t.
			  CAPTION "Check 2"
                   END CHECKBOX
	                  ROW 70
			  COL 30
			  WIDTH 120
			  HEIGHT 20
			  VALUE  xeck3  //.t.
			  CAPTION "Check 3"
                   END CHECKBOX
		          ROW 100
			  COL 30
			  WIDTH 120
			  HEIGHT 30
                          ACTION SaveXecky()
			  PICTURE "save"
			  PICTALIGNMENT LEFT
		   END BUTTON
  CENTER WINDOW Form_1
  ACTIVATE WINDOW Form_1
  FUNCTION ReverseCheck()
  LOCAL aChecboQ , i
   aChecboQ  := ( IIF( Form_1.checkbox_0.Value,"True","False") )
   IF aChecboQ = "True"
     Form_1.checkbox_0.Value := .T.
     Form_1.checkbox_1.Value := .T.
     Form_1.checkbox_2.Value := .T.
     Form_1.checkbox_3.Value := .T.
     xeck0  :=   .T.
     xeck1  :=   .T.
     xeck2  :=   .T.
     xeck3  :=   .T.
     Form_1.checkbox_0.Value := .F.
     Form_1.checkbox_1.Value := .F.
     Form_1.checkbox_2.Value := .F.
     Form_1.checkbox_3.Value := .F.
     xeck0  :=   .F.
     xeck1  :=   .F.
     xeck2  :=   .F.
     xeck3  :=   .F.
  FUNCTION SaveXecky()
   LOCAL bChec00 , bChec01 , bChec02 , bChec03
   bChec00 := ( IIF( Form_1.checkbox_0.Value,"True","False") )
   IF bChec00= "True"
      xeck0  :=   .T.
      xeck0  :=   .F.
   bChec01 := ( IIF( Form_1.checkbox_1.Value,"True","False") )
   IF bChec01= "True"
      xeck1  :=   .T.
      xeck1  :=   .F.
  bChec02 := ( IIF( Form_1.checkbox_2.Value,"True","False") )
   IF bChec02= "True"
      xeck2  :=   .T.
      xeck2  :=   .F.
  bChec03 := ( IIF( Form_1.checkbox_3.Value,"True","False") )
   IF bChec03= "True"
      xeck3  :=   .T.
      xeck3  :=   .F.
    Form_1.Release
Mustafa :oops: :D
RPC
Post by RPC »
Hi Jimmy
Thanks for the reply.
My problem was maintaining the state of check boxes after I exit the program altogether and then when I again start the program say after sometime.
Static variables are useful when you are still in the program, when you exit the program they are gone.
RPC
Post by RPC »
Hi Grigory
You have really provided an elegant solution for which I was breaking my head for last 2 days.
Many many thanks.
There is just one more little problem. I am not getting the "save" bitmap image on the "Save & Exit" button, though I have mentioned it in the resource window of IDE. Can you please have a look at it ?
Many thanks again for the great help you are providing.
RPC
Post by RPC »
Hi Mustafa
Great to have your solution. Many thanks.
Perhaps you can also help with "save" bitmap image problem I have mentioned above.
Thanks
