calculate GRID height
i try to calculate Size of GRID ... but something is wrong with my calculation
i use Arial 11 and this line
   nHeight := ( iMax + 1 ) * 22.3
+1 is need for GRID Header and 22.3 ...
it seem to work when have < 10 Fields but than GRID is bigger than need :(
so i need a better Way for "calculation" height of GRID.
please help, thx
MODISTRU.ZIP
(1.09 KiB) Downloaded 166 times
Re: calculate GRID height
Jimmy,
This works with my W7 machine, but when more than 30 or 40 the form height doesn't fit on the screen so the last records can not be seen.
serge_girard wrote: Tue Feb 04, 2020 8:17 am ... but when more than 30 or 40 the form height doesn't fit on the screen so the last records can not be seen.
that is exact what i wonder when it does not fit any more ... :o
i found
HB_FUNC( GETTEXTHEIGHT )  // returns the Height of a string in pixels
have to try if other Way for calculation
AUGE_OHR wrote: Tue Feb 04, 2020 10:34 am hi,
Hi Jimmy,
Please try the updated sample below: :arrow:
*+ Source Module => c:\hmg.3.4.4\0\GRIDHIGH\\MODISTRU.PRG
*+    Copyright(C) 1983-2020 by Auge & Ohr
*+    Functions: Procedure main()
*+               Static Procedure SaveCreate()
*+               Static Procedure CloseForm2()
*+       Tables: USE ( cDbf )
*+    Reformatted by Click! 2.05.30 on Feb-4-2020 at  8:34 am
#include "HMG.CH"
#include "Dbstruct.ch"
*+    Procedure main()
PROCEDURE main( cDbf )
LOCAL aStruc, i, iMax
LOCAL aCaption  := { "Name", "Type", "Len", "Dec" }
LOCAL aWide     := { 110, 50, 60, 60 }
LOCAL aItems    := {}
LOCAL nHeight   := 0
LOCAL nTitlebar := GETTITLEHEIGHT()
   default cDBF := "TEST.dbf"
   IF !FILE( cDbf )
      msginfo( "need DBF" )
   ALTD()
   USE ( cDbf )
   aStruc := DBSTRUCT()
   iMax := LEN( aStruc )
   FOR i := 1 TO iMax
      AADD( aItems, { aStruc[ i ] [ DBS_NAME ], ;
                      aStruc[ i ] [ DBS_TYPE ], ;
                      aStruc[ i ] [ DBS_LEN ], ;
                      aStruc[ i ] [ DBS_DEC ] } )
   DEFINE WINDOW Form_2 ;
              AT 0, 0 ;
              WIDTH 330 ;
              HEIGHT nHeight + nTitlebar + 40 + 50 ;
              TITLE cDbf ;
              MAIN ;
              ON RELEASE CloseForm2() ;
              FONT "Arial" ;
              SIZE 11 ;
              NOMINIMIZE ;
              NOMAXIMIZE ;
              NOSIZE
      DEFINE TOOLBAR oTOOLBAR BUTTONSIZE 50, 50 FLAT BORDER
         BUTTON oBtSave ;
                 TOOLTIP "F5: create DBF" ;
                 ACTION SaveCreate()
      END TOOLBAR
      DEFINE GRID Brow_2
         PARENT Form_2
         ROW 10 + 50
         COL 10
         WIDTH 290
         HEIGHT nHeight
         HEADERS aCaption
         WIDTHS aWide
         ITEMS aItems
         FONTNAME "Arial"
         FONTSIZE 11
         VALUE 1
      END GRID
   Form_2.Brow_2.height := GetHeght_ListView(Form_2.Brow_2.HANDLE, iMax)
   Form_2.height := Form_2.Brow_2.row + Form_2.Brow_2.height + GetTitleHeight() + 2*GetBorderHeight() + 10
   Form_2.Title := (Form_2.Title) + ' -> # visible rows: ' + hb_ntos(GetNumOfVisibleRows('Brow_2', 'Form_2'))
   ON KEY F5 OF Form_2 ACTION SaveCreate()
   ON KEY ESCAPE OF Form_2 ACTION Form_2.Release
//   Form_2.Brow_2.setfocus
   CENTER WINDOW Form_2
   ACTIVATE WINDOW Form_2
Function GetNumOfVisibleRows ( ControlName , ParentForm )
   LOCAL i
   i := GetControlIndex ( ControlName , ParentForm )
Return ListviewGetCountPerPage ( GetControlHandleByIndex( i ) )
FUNCTION GetHeght_ListView( hBrw, nRows )  // height Grid \ Browse on the number of rows
   LOCAL a
   a    := ListViewApproximateViewRect( hBrw, nRows - 1 )  // { Width, Height }
   a[1] += Round( GetBorderWidth () / 2, 0 )               // Width
   a[2] += Round( GetBorderHeight() / 2, 0 )               // Height
RETURN a[2]
#pragma BEGINDUMP
#include <mgdefs.h>
#include <commctrl.h>
HB_FUNC( LISTVIEWAPPROXIMATEVIEWRECT )
  int iCount = hb_parni( 2 );
  DWORD Rc;
  Rc = ListView_ApproximateViewRect( ( HWND ) hb_parnl( 1 ), -1, -1, iCount );
  hb_reta( 2 );
  HB_STORNI( LOWORD( Rc ), -1, 1 );
  HB_STORNI( HIWORD( Rc ), -1, 2 );
#pragma ENDDUMP
*+    Called from ( modistru.prg )   2 - procedure main()
STATIC PROCEDURE SaveCreate( cOutPutDBF, aNew, aHead, nRowStart, nRowEnd, nColEnd, lDone, aType )
*+    Called from ( modistru.prg )   1 - procedure main()
STATIC PROCEDURE CloseForm2()
*+ EOF: MODISTRU.PRG
The above code works fine for a DBF with the 32 fields. :idea:
gfilatov wrote: Tue Feb 04, 2020 10:40 am Please try the updated sample below: :arrow:
THX for your Solution.
but i wonder that i need so much Code for a "simple" Problem ...
AUGE_OHR wrote: Tue Feb 04, 2020 10:58 am hi,
Hi Jimmy,
I had revised the above code and added the two new clauses:
AUTOSIZEHEIGHT <nRow> and AUTOSIZEWIDTH <.T.|.F.>
to a standard Grid control in MiniguiEx. 8-)
The updated program code and a result's screen are below: :arrow:
#include "HMG.CH"
*+    Procedure main()
LOCAL aItems    := {}
LOCAL nHeight   := 0
   IF !FILE( cDbf )
   ALTD()
   USE ( cDbf )
   FOR i := 1 TO iMax
              AT 0, 0 ;
              WIDTH 330 ;
              TITLE cDbf ;
              MAIN ;
              FONT "Arial" ;
              SIZE 11 ;
              NOMINIMIZE ;
              NOMAXIMIZE ;
              NOSIZE
      DEFINE TOOLBAR oTOOLBAR BUTTONSIZE 40, 40 FLAT BORDER
         BUTTON oBtSave ;
                 ACTION SaveCreate()
      END TOOLBAR
      DEFINE GRID Brow_2
         PARENT Form_2
         ROW 10 + 50
         COL 10
         AUTOSIZEWIDTH .T.
         AUTOSIZEHEIGHT iMax
         HEADERS aCaption
         WIDTHS aWide
         ITEMS aItems
         FONTNAME "Arial"
         FONTSIZE 11
         VALUE 1
      END GRID
   Form_2.height := Form_2.Brow_2.row + Form_2.Brow_2.height + nTitlebar + 2*GetBorderHeight()
   Form_2.width := Form_2.Brow_2.col + Form_2.Brow_2.width + 2*GetBorderWidth()
   LOCAL i
gfilatov wrote: Fri Feb 14, 2020 9:15 am I had revised the above code and added the two new clauses:
that looks fine, THX
i have try to compile your HB_FUNC( ListViewApproximateViewRect ) with HMG include mgdefs.h.
it give me some Error ... about Reference ... :(
Question : can i use those HB_FUNC with HMG :?:
