Two or more hyperlinks in a window - not working
Please verify whether it is only for me or for you too!
# include "minigui.ch"
function main
define window x at 0,0 width 200 height 100 main
   DEFINE hyperlink email1
      row 10
      col 10
      value "http://www.rathinagiri.in"
      width 130
      handcursor .t.
      address "http://www.rathinagiri.in"
   END hyperlink
      row 40
      col 10
      value "E-Mail me"
      width 130
      handcursor .t.
      address "srgiri@dataone.in"
   END hyperlink
end window
x.center
x.activate
return nil
If I compile the above, only the second hyperlink is working. :(
Re: Two or more hyperlinks in a window - not working
rathinagiri wrote: Please verify whether it is only for me or for you too!
I confirm this problem too :?
BTW It works fine in the HMG Extended Edition. 8-)
rathinagiri wrote:Hi,
function main
      row 10
      col 10
      width 130
      handcursor .t.
   END hyperlink
      row 40
      col 10
      value "E-Mail me"
      width 130
      handcursor .t.
   END hyperlink
end window
x.center
x.activate
return nil
Thanks for reporting.
I'll review it ASAP.
gfilatov wrote:BTW It works fine in the HMG Extended Edition. 8-)
:lol:
Regardz,
Rovertu.
Thanks Roberto
Thanks Roberto
This will be another funny to fix bug :)
I confirmed and starting test and discovered something interesting: Inverting the order of links both works fine :)
It's attached to this message.
I'll still testing...
test2.rar
(342 Bytes) Downloaded 901 times
Thanks Roberto
I've found the cause. It will need some little design change in the control.
It will be take some time to test prior to publish.
Thank you Roberto. :)
rathinagiri wrote:Thank you Roberto. :)
Fixed!
Please, replace the attached files and recompile the library.
The problem only affected alternate syntax.
fix.rar
(10.36 KiB) Downloaded 869 times
Yes! It is working fine now Roberto! Thanks a LOT.
