App as Ruler
App as Ruler
i'm searching for Ruler as App using harbour / HMG like this
do some one have made it an can share some Code :?:
Carlos Britos
Re: App as Ruler
Post by Carlos Britos »
hope this can help you.
source code.C is in zip
ruler.zip
(36.06 KiB) Downloaded 236 times
Re: App as Ruler
Carlos Britos wrote: Thu Jan 09, 2020 12:51 pm hope this can help you.
OK, Thx i will try it
Re: App as Ruler
ruler.zip
Grigory or any master in C can adopt in HMG
Re: App as Ruler
AUGE_OHR wrote: i'm searching for Ruler as App using harbour / HMG like this
Refer GridPlus,you will find Function DrawScale
http://hmgforum.com/viewtopic.php?f=10& ... s&start=20
Re: App as Ruler
bpd2000 wrote: Fri Jan 10, 2020 6:41 am Refer GridPlus,you will find Function DrawScale
have made simple "pure" HMG_Ruler
include Source and Icon as Resource.
please have a look at this Snapshot. Explorer does not show EXE Icon :?:
and why in Tasklist vertical Icon is not shown :?:
HMG_RULER.ZIP
(3.43 KiB) Downloaded 193 times
as the vertical is only 120 wide i can't use Titlebar to move it ... and it have a Artifact left of it.
how can i get ride of of Min/Max Button Space (!) under HMG :?:
/* Toggle window properties
   Example:
   A. To turn off (disable) the Maximise button:
       SetWindowPropertyOff( oDlg, WS_MAXIMIZEBOX )
   B. To turn off (disable) the Minimise button:
       SetWindowPropertyOff( oDlg, WS_MINIMIZEBOX )
   C. To turn off the max and min buttons:
       SetWindowPropertyOff( oDlg, WS_MAXIMIZEBOX+WS_MINIMIZEBOX )
   Notes:
   Sample A only disables the maximise button.
   Sample B only disables the minimise button.
   Sample C actually removes the minimise and maximise buttons.
   The inference here is that one cannot exist without the other.
Function SetWindowPropertyOff( oWin, nProperties, lOnOff )
   local nPtr
   local i
   DEFAULT lOnOff to FALSE // toggle=off
   nPtr := GetWindowLongA( oWin:getHWnd(), GWL_STYLE )
   for i := 1 to 32
      if nProperties[i]
         nPtr[i] := lOnOff
   next
   SetWindowLongA( oWin:getHWnd(), GWL_STYLE, nPtr )
   return Nil
DLLFUNCTION GetWindowLongA( nHwnd, nStyle ) USING STDCALL FROM User32.dll
DLLFUNCTION SetWindowLongA( nHwnd, nStyle, nPtr ) USING STDCALL FROM User32.dll
Re: App as Ruler
new Version :
5 Point mark
Context Menu for Transparency
NOMAXIMIZE NOMINIMIZE -> no Artefact
now vertical Ruler can be moved using Titlebar
here is the Source
HMG_RULER2.ZIP
(3.83 KiB) Downloaded 210 times
