About the date of the messages
jparada
Post by jparada »
Hello Rathinagiri, there is a way around that in my browser display messages from previous days with the current date.
This happens to me, whether I am a member of the forum or as a visitor
Thank you
Greetings
Javier
Re: About the date of the messages
I don't understand. :(
Can you please give with an example?
jparada
Post by jparada »
Hi, Rathinagiri, I annex a few images to give it a look please, I do not know if this is a problem in my configuration or just a very poor assessment on my part.
Thanks
Greetings
Javier
imgs.zip
(470.11 KiB) Downloaded 822 times
IMHO, it is neither. :)
My small doubt is, had you logged in when you captured test4.jpg?
I had attached two images here with BLUE marking. That shows the difference.
jparada
Post by jparada »
Hi Rathinagiri, I think I was logged in, I do not remember, I have confirmed what you told me about that show different times when I'm logged in and when not, as you say.
Thank you
Greetings
Javier
Yes. That should be the reason for the differences. Your time zone is set to UTC - 8 hours. Server's time zone is at UTC. Therefore, there would be 8 hours difference between before logging in and after logging in.
To avoid this, you can save the cookie using the browser preferences, so that you need not log in every time.
jparada
Post by jparada »
Thanks Rathinagiri, then I will do so.
Greetings
Javier
