set HB_COMPAT_XPP
set HB_COMPAT_XPP
i just have read this
This function is only visible if source/rtl/browdb.prg was compiled with the HB_COMPAT_XPP flag
em. aaah ... how to set HB_COMPAT_XPP at compile time :?:
under Cl*pper / Xbase++ i can use /D ... how with harbour :?:
Re: set HB_COMPAT_XPP
AUGE_OHR wrote: Sat Dec 14, 2019 7:34 am hi,
Check difference with : hbmk2 test.prg /dTEST
and hbmk2 test.prg
Also check after comment //#define SECOND with hbmk2 test.prg /dTEST
#ifndef TEST
#warning Warning: This sample must be tested using /dTEST compiler flag
#endif
#define FIRST
#define SECOND
#define THIRD
PROCEDURE Main()
   ? "testing Harbour /d compiler flag"
   #ifdef TEST
      ? "Fine, you have just tested the /d compiler flag"
   #else
      ? "Please use /dTEST compiler flag"
      ? "Or run 'set HB_USER_PRGFLAGS=/dTEST' if you are using the GNU Make System"
   #endif
   #ifdef FIRST
      ? "FIRST is defined"
      #ifdef SECOND
         ? "FIRST and SECOND are defined"
         #ifdef THIRD
            ? "FIRST, SECOND and THIRD are defined"
         #else
            ? "THIRD is not defined"
         #endif
      #else
         ? "SECOND is not defined"
      #endif
   #else
      ? "FIRST is not defined"
   #endif
THX
