view Email Body "DOCTYPE html"
i can send / receive Email with hbTIP but there is still a Question : how to view / Print a Email Body :?:
   cBody := aEmail:getBody()
   DO CASE
      CASE "DOCTYPE html" $ cBody
         STRFILE(cBody,cFileName)
         RUN myView(cFileName)
as i don't know Email Structure my Question is : can i show a Body with "DOCTYPE html" in a HTML Viewer :?:
Re: view Email Body "DOCTYPE html"
My code
#define CRLF  INetCRLF()
#require "hbtip"
REQUEST __HBEXTERN__HBSSL__
Procedure Email_GetBody()
   lResetServer      := oPopServer:Reset()
   cMail             := oPopServer:retrieve( Incomming.Messages.Value  )
   If oPopServer:lastErrorCode() != 0
      MsgInfo( 'The message does not exist or was deleted ' + Chr( 10 ) +;
               'Server responds : ' + oPopServer:lastErrorMessage() ,;
               ' Attention Message  ' )
        oPopServer:Close()
        lOpen                       := .F.
        Incomming.Connect.Enabled   := .T.
        Incomming.ReadTray.Enabled  := .F.
        Incomming.Messages.DeleteAllItems
        Incomming.LabelServer.Hide
        Incomming.LabelReply.Hide
        Incomming.Server.Show
        Incomming.cPass.Show
        Incomming.cUser.Show
        Incomming.User_1.Show
        Incomming.Pass_1.Show
   Endif
   aEmail    := TIPMail():new()
   oEmail    := aEmail:fromString( cMail )
   IF aEmail:isMultiPart()
      // Retrieve all parts of a multipart message
      aParts := aEmail:getMultiParts( )
           /* through all parts of the eMail */
       FOR EACH oPart IN aParts
           IF .NOT. Empty( oPart:getFileName() )
              If MsgYesNo(' download the attachment : ' + oPart:getFileName() , ;
                          ' Select Y / N ' )
                // This is a file attachment. Store it in the TMP folder.
                IF .NOT. oPart:detachFile( cCurrentFolder+'\Attachment' )
                  MsgExclamation('Could not save the file : ' + oPart:getFileName() , ' !! Warning Message ¡¡ ' )
              Endif
               CreateHtml(oPart:getBody() , oPart:GetFieldPart( "Content-Type" ))
           Endif
   ELSE  // Is simple eMail message
       CreateHtml(aEmail:getBody() , aEmail:GetFieldPart( "Content-Type" ))
   Endif
Function CreateHtml( cStringBody , cEmailType )
   LOCAL oHTML := THtml():New()
   oHTML:SetTitle( 'HBTIP' )
   oHTML:AddPara( cStringBody , "LEFT" )
   oHTML:Generate()
   oHTML:SaveToFile( cCurrentFolder + '/Html/email.html' )
   Incomming.oBody.Object:Navigate('file:///' + cCurrentFolder + '/Html/email.html')
danielmaximiliano wrote: Sun Nov 24, 2019 1:38 am My code
WOW ... so "easy" if know how :D
THX
Question about THTML() : is it from HMG :?:
when search in HMG DOC it have other Syntax :o
Description
THtml() is a class that creates an .html file of the same name you pass to the constructor.
The class methods are as follows:
New(<cFile>) Create a new instance of the THtml class
Close() Close the created file
WriteTitle(<cTitle>) Write the file title
WritePar(<cPar>) Writes a paragraph
WriteParBold(<cPar>) Same as WritePar(), but the text is
WriteLink(<cLink>,<cName>) Write a link to another topic
WriteText(<cText>) Write any text
so none of your Method exist :(
   oHTML:Generate()
so where is your CLASS Thtml() come from :?:
thx for help
i have test it with QHTM() ... it work general but to much empty "frame" (did not download Images)
have to make more test to get "only" text to read
i get Email where Body is empty ... hm
than i saw this in Email Source
Content-Type: multipart/related;
boundary="----=_Part_54615146_1810148544.1574637521787"
------=_Part_54615146_1810148544.1574637521787
Content-Type: text/html; charset=UTF-8;
Content-Transfer-Encoding: quoted-printable
so how get that Part :?:
here is the EML File
MAIL_EML.ZIP
(18.62 KiB) Downloaded 153 times
               // odczytanie wszystkich cze˜ci wiadomo˜ci
               // reading all parts of the message
               aParts := aEmail:getMultiParts()
               nPart := 0
i got in aParts[1]:cBody what i want but i can't access it.
Error BASE/41 Scope violation (hidden): TIPMAIL:CBODY
Called from TIPMAIL:CBODY(0)
Called from GETEMAIL(436)
Called from (b)MAIN(81)
Called from _PROCESSINITPROCEDURE(5876)
Called from _ACTIVATEWINDOW(5627)
Called from MAIN(172)
who can help please.
AUGE_OHR wrote: Mon Nov 25, 2019 8:06 am i have test it with QHTM() ... it work general but to much empty "frame" (did not download Images)
#include "hbclass.ch"
CREATE CLASS THTML
   VAR cTitle                             // Page Title
   VAR cBody                              // HTML Body Handler
   VAR cBGColor                           // Background Color
   VAR cLinkColor                         // Link Color
   VAR cvLinkColor                        // Visited Link Color
   VAR cContent                           // Page Content Handler
   METHOD New()                           // New Method
   METHOD SetTitle( cTitle )              // Set Page Title
   METHOD AddLink( cLinkTo, cLinkName )   // Add <H1> Header
   METHOD AddHead( cDescr )               // Add Hyperlink
   METHOD AddPara( cPara, cAlign )        // Add Paragraph
   METHOD Generate()                      // Generate HTML
   METHOD SaveToFile( cFile )             // Show Result
END CLASS
METHOD New() CLASS THTML
   ::cTitle      := "Untitled"
   ::cBGColor    := "#FFFFFF"
   ::cLinkColor  := "#0000FF"
   ::cvLinkColor := "#FF0000"
   ::cContent    := ""
   ::cBody       := ""
   RETURN Self
METHOD SetTitle( cTitle ) CLASS THTML
   ::cTitle := cTitle
   RETURN Self
METHOD AddLink( cLinkTo, cLinkName ) CLASS THTML
   ::cBody := ::cBody + ;
      "<a href='" + cLinkTo + "'>" + cLinkName + "</a>"
   RETURN Self
METHOD AddHead( cDescr ) CLASS THTML
   // Why this doesn't work?
   // ::cBody += ...
      "<h1>" + cDescr + "</h1>"
METHOD AddPara( cPara, cAlign ) CLASS THTML
   cAlign := iif( cAlign == NIL, "Left", cAlign ) // Added Patrick Mast 2000-06-17
      "<p align='" + cAlign + "'>" + hb_eol() + ;
      cPara + hb_eol() + ;
      "</p>"
   RETURN Self
METHOD Generate() CLASS THTML
   ::cContent :=                                                           ;
      "<html><head>"                                          + hb_eol() + ;
      "<title>"      + ::cTitle + "</title>"                  + hb_eol() + ;
      "<body link='" + ::cLinkColor + "' " +                               ;
      "vlink='"      + ::cvLinkColor + "'>" +                 + hb_eol() + ;
                       ::cBody                                + hb_eol() + ;
      "</body></html>"
   RETURN Self
METHOD SaveToFile( cFile ) CLASS THTML
   LOCAL hFile := FCreate( cFile )
   FWrite( hFile, ::cContent )
   FClose( hFile )
   RETURN Self
your CLASS Thtml work much better for what i want, THX
