resize BMP with harbour / HMG
under Xbase++ i have this Code
FUNCTION BMP2BMP( oBMP, aXbpSize )
LOCAL oHuge, oTiny, oPS, oRet, nBits, nPlanes
   IF aXbpSize[ 2 ] > 0
      oHuge := oBMP
      nBits := oBMP:bits
      nPlanes := oBMP:planes
      oPS := XBPPRESSPACE() :new() :Create()            // Xbase++ Style
      //Create a new empty bitmap
      oTiny := XBPBITMAP() :New() :Create()
      oTiny:Make( aXbpSize[ 1 ], aXbpSize[ 2 ], nPlanes, nBits )
      oTiny:presSpace( oPS )                            // Xbase++ Style
      //Copie and resize the huge bitmap to the small bitmap
      oHuge:Draw( oPS, { 0, 0, aXbpSize[ 1 ], aXbpSize[ 2 ] },,, 4 )
      oRet := oTiny
      oRet := oBMP
RETURN oRet
i create a empty Bitmap with new Size.
than a "Draw" old Bildmap into new Bitmap
how to do it with harbour HMG :?:
Re: resize BMP with harbour / HMG
if i have a Line like this
     @ 0, 0 IMAGE Image_1 PICTURE xxx ON CLICK MsgInfo ("Splash Image")
what Type can xxx be :?:
i'm not a C User so it is only to show how it "might" look under harbour what i mean
HB_FUNC (BMP2BMP) // LPCTSTR BmpRes, INT nWidth, INT nHeight
  BmpRes    = (LPCTSTR) hb_parnl(1)
  nWidth    = (INT) hb_parnl(2)
  nHeight   = (INT) hb_parnl(3)
  hdcSource = CreateCompatibleDC(hdc);
  hBitmap1 = LoadImage(GetModuleHandle(NULL), BmpRes, IMAGE_BITMAP, nWidth, nHeight, LR_DEFAULTCOLOR);
  SelectObject(hdcSource, hBitmap1);
  hdcTarget = CreateCompatibleDC(hdc);
  hBitmap2 = CreateCompatibleBitmap(hdcSource, iExpWidth, iExpHeight);
  SelectObject(hdcTarget, hBitmap2);
  bResult = StretchBlt( hdcTarget, 0, 0, iExpWidth, iExpHeight, hdcSource, 0, 0, iWidth, iHeight, SRCCOPY );
* return bResult;
  return hBitmap2;
what i like to have are
     @ 0, 0 IMAGE Image_1 PICTURE BMP2BMP(xxx,aSize[1],aSize[2]) ON CLICK MsgInfo ("Splash Image")
who can help to write HB_FUNC (BMP2BMP)
We have BosTaurus library for manipulating bitmaps. Try to search
image_1 can be filenamr of your bitmap or appintment to resource, eg:
Image_1 BITMAP C:\PICTURES\BLABLA.BMP
hi
mol wrote: Fri Nov 01, 2019 1:28 pm We have BosTaurus library for manipulating bitmaps. Try to search
i have look into
c:\hmg.3.4.4\SOURCE\BosTaurus\c_BosTaurus.c
bt_bmp_convert_to_24bpp (hBitmap, IsDelete_hBitmap_Original) ---> Return New_hBitmap
c:\hmg.3.4.4\SOURCE\BosTaurus\h_BosTaurus.prg
BT_BitmapCopyAndResize (hBitmap, New_Width, New_Height, Mode_Stretch, Algorithm)
these both Function "might" do what i want.
i do not want to change/delete Original Image when create a New "resize" Image.
new hBitmap i need to pass to 3-PP API Function
thx for Help.
i made a (typical) Xbase++ Error ... we are on Windows ;)
Windows have LoadImageA
https://docs.microsoft.com/en-us/window ... loadimagea
HANDLE LoadImageA(
  HINSTANCE hInst,
  LPCSTR    name,
  UINT      type,
  int       cx,
  int       cy,
  UINT      fuLoad
so i can load it with Size cx and cy
have found in c:\hmg.3.4.4\INCLUDE\i_image.ch
#xcommand @ <row>,<col> IMAGE <name> ;
   [ <dummy1: OF, PARENT> <parent> ] ;
   PICTURE <filename> ;
   [ <dummy2: ACTION,ON CLICK,ONCLICK> <action> ];
   [ WIDTH <w> ] ;
   [ HEIGHT <h> ] ;
   [ <stretch: STRETCH> ] ;
   [ HELPID <helpid> ] ;
   [ <invisible: INVISIBLE> ] ;
   [ <transparent: TRANSPARENT> ] ;
   [ BACKGROUNDCOLOR <backgroundcolor> ];
   [ <adjustimage: ADJUSTIMAGE>];
   [ TRANSPARENTCOLOR <transparentcolor> ];
   [ TOOLTIP <tooltip> ];
so i change my Code to
      @ 0, 0 IMAGE Image_1 PICTURE cFileName ;
                           WIDTH 500 HEIGHT 150 ;
and it seems to work :D
Question : how to use [ <stretch: STRETCH> ] :?:
hm ...
i now see some Artefact
i have now use small Bitmap which i have normal in Resoure
when use F8 in Debugger i got this result
so Image does not fill hole Area :(
  DEFINE WINDOW Form_Splash ;
attached Code and BMP Sample
SetRegion_2.zip
(27.75 KiB) Downloaded 175 times
can someone confirm the Problem :?:
AUGE_OHR wrote: Sat Nov 02, 2019 8:44 pm hi,
I don't understanding your problem. :o
BTW Please take a look for my result below :arrow:
and with an updated code
                           WIDTH 500 HEIGHT 150 STRETCH
it seems normally
gfilatov wrote: Mon Nov 04, 2019 9:22 am and with an updated code
it seems normally
yes, now it work with this Syntax. Thx
the Question is why it does not work when only use
OR
STRETCH
does not work :?:
