Top Menu
Top Menu
i try to find a Sample where i have a "Top" Menu ... i just found PopUp-Menu.
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Top Menu
Post by dragancesu »
What do you mean when you say "Top Menu"?
Re: Top Menu
dragancesu wrote: Wed Oct 30, 2019 12:07 pm What do you mean when you say "Top Menu"?
i just mean a normal Windows App Menu under Titlebar.
Re: Top Menu
i saw in Demo "Own Button"
    DEFINE MAINMENU
      DEFINE POPUP "BTN &1"
so that horizontal Menu are what i mean with "Top Menu" ... but it is "xcommand Syntax"
i found c:\hmg.3.4.4\SOURCE\c_menu.c
HB_FUNC ( CREATEMENU )
	HMG_retnl ((LONG_PTR) CreateMenu() );
HB_FUNC ( CREATEPOPUPMENU )
	HMG_retnl ((LONG_PTR) CreatePopupMenu() );
and in h_menu.prg
   _HMG_SYSDATA [ 172 ] := CreateMenu()
	_HMG_SYSDATA [ 335 ] [ _HMG_SYSDATA [ 174 ] ] := CreatePopupMenu()
		_HMG_SYSDATA [1] [k] :=  "POPUP"
		_HMG_SYSDATA [3]  [k] :=  _HMG_SYSDATA [ 172 ]   // Main Menu Handle   // Dr. Claudio Soto (July 2013)  Controlhandle   // This Not a Handle, this is lBoolean value
		_HMG_SYSDATA [4]  [k] :=  _HMG_SYSDATA [ 173 ]   // Form Parent Handle
		_HMG_SYSDATA [  7 ]  [k] :=  _HMG_SYSDATA [ 335 ] [_HMG_SYSDATA [ 174 ] ]   // Popup Menu Handle
		_HMG_SYSDATA [ 22 ]  [k] :=  _HMG_SYSDATA [ 335 ] [ _HMG_SYSDATA [ 174 ] ]   // Popup Menu Handle
		_HMG_SYSDATA [1] [k] := "MENU"
		_HMG_SYSDATA [  3 ]  [k] :=   _HMG_SYSDATA [ 175 ]   // Popup Menu Handle  // Dr. Claudio Soto (July 2013)   Controlhandle   // This Not a Handle, this is lBoolean value
		_HMG_SYSDATA [  4 ]  [k] :=   _HMG_SYSDATA [ 176 ]   // _HMG_SYSDATA [ 176 ] := GetFormHandle ( Parent )   // Form Parent Handle
		_HMG_SYSDATA [  7 ]  [k] :=   _HMG_SYSDATA [ 175 ]   //_HMG_SYSDATA [ 175 ] := CreatePopupMenu()   // Popup Menu Handle
		_HMG_SYSDATA [ 22 ]  [k] :=  0
so that seem the different Style "POPUP" and "MENU"
in c:\hmg.3.4.4\SOURCE\c_menu.c i found
HB_FUNC ( MENUITEM_SETBITMAPS )
   HMENU hMenu       = (HMENU)   HMG_parnl (1);
   INT   nID         = (INT)     hb_parni  (2);
   TCHAR *FileName1  = (TCHAR *) HMG_parc  (3);
   TCHAR *FileName2  = (TCHAR *) HMG_parc  (4);
   int   Transparent = hb_parl (5) ? 0 : 1;
                                                          //    ScaleStretch, Transparent, BackgroundColor,  AdjustImage,   TransparentColor
   HBITMAP hBitmap1 = HMG_LoadPicture (FileName1, -1, -1, NULL,            0, Transparent,              -1,            0,                 -1 );
   HBITMAP hBitmap2 = HMG_LoadPicture (FileName2, -1, -1, NULL,            0, Transparent,              -1,            0,                 -1 );
   SetMenuItemBitmaps (hMenu, nID, MF_BYCOMMAND, hBitmap1, hBitmap2);
so how to implement a Bitmap in MenuItem ( HMG Syntax) :?:
