DLL Call Question
DLL Call Question
i have this Code which work with Xbase++ and ot4xb from Pablo Botella (www.xbwin.com)
#IFDEF __XPP__
   nColor := AutomationTranslateColor(GRA_CLR_PINK,.F.)
   nRet := @User32:SetSysColors(1, {COLOR_SCROLLBAR}, {nColor}) // this Work !
#ELSE
//  AutomationTranslateColor(GRA_CLR_PINK,.F.) -> 16711935
    nRet := DLLcall("USER32.DLL",DLL_OSAPI,"SetSysColors",1,{COLOR_SCROLLBAR}, {16711935})
#ENDIF
it does NOT work with Xbase++ "pure" ... and i can't get it work with harbour :(
who can make it work with harbour :idea:
SCROLLBA.ZIP
(567 Bytes) Downloaded 167 times
! Note : you can "see" these Color only when use NO "XP Manifest" :!:
SetSysColors function
https://docs.microsoft.com/en-us/window ... tsyscolors
Re: DLL Call Question
As I remember, the problem is with 'themed' windows.
In Win Xp it was possible, in newer version not
thx for Answer.
the Problem with this API Call are Array as Parameter where "pure" Xbase++ fail. it work with 3-PP Ot4XB LIB
so my Question is how to pass Array Parameter in DLL Call with harbour :?:
KDJ
Post by KDJ »
You can use SetSysColors function from HMG:
HB_FUNC (SETSYSCOLORS)
   int ID         = (int)      hb_parni (1);
   COLORREF Color = (COLORREF) hb_parnl (2);
   hb_retl (SetSysColors (1, &ID, &Color));
Usage:
lSuccess := SetSysColors(COLOR_SCROLLBAR, COLORREF)
KDJ wrote: Sun Oct 27, 2019 10:07 pm You can use SetSysColors function from HMG:
Usage:
Aha ... THX
em, äh ... have try
   nRet := SETSYSCOLORS(1,{COLOR_SCROLLBAR}, {nColor})
   nRet := SETSYSCOLORS(1,COLOR_SCROLLBAR, nColor)
   nRet := SETSYSCOLORS(1,COLOR_SCROLLBAR, aRGB )
   nRet := SETSYSCOLORS(1,COLOR_SCROLLBAR, 0xc8fde3 )
but none of them work like expect. :(
can you please show me a working Example for harbour / HMG.
i found this working Code
nRet := clrtest( CLR_YELLOW, CLR_HRED )
HB_FUNC( CLRTEST )
   int aElements[2] = { COLOR_CAPTIONTEXT, COLOR_SCROLLBAR };
   DWORD aColors[2];
   aColors[ 0 ] = hb_parnl( 1 );
   aColors[ 1 ] = hb_parnl( 2 );
   hb_retl (SetSysColors( 2, aElements, aColors ));
now i try this code with modify Function and it work :)
nRet := SETSYSCOLORSEX(COLOR_SCROLLBAR, CLR_HMAGENTA)
nRet := SETSYSCOLORSEX(COLOR_CAPTIONTEXT,CLR_HBLUE)
   #pragma BEGINDUMP
   #include "item.api"
   #include <hbapi.h>
   #include <windows.h>
HB_FUNC( SETSYSCOLORSEX )
   int aElements[1];
   DWORD aColors[1];
   aElements[ 0 ] = hb_parnl( 1 );
   aColors[ 0 ]   = hb_parnl( 2 );
   hb_retl (SetSysColors( 1, aElements, aColors ));
   #pragma ENDDUMP
but this function have only 2 Parameter and it start with Array.
what i like to have are 3 Parameter where 2nd and 3rd are test for "VALTYPE" = "C" or "A"
who can help me to write a SETSYSCOLORSEX or show me how HMG SETSYSCOLORS work :?:
Usage:
Hi Krzysztof!
Do you know the way how to change parametrs of scroolbar? Is it possible to make it wider with bigger arrow buttons?
KDJ
Post by KDJ »
mol wrote: Mon Oct 28, 2019 2:22 pm Do you know the way how to change parametrs of scroolbar? Is it possible to make it wider with bigger arrow buttons?
Hi Marek
I guess you mean the build-in scrollbars in ListView control.
Theoretically it is possible, but quite difficult to realize.
And it seems to me that in HMG it is even impossible.
KDJ
Post by KDJ »
AUGE_OHR wrote: Mon Oct 28, 2019 3:03 am now i try this code with modify Function and it work :)
Your SETSYSCOLORSEX function and HMG SETSYSCOLORS function works identically.
So why you say that one works and the other does not work?
