Read array Harbour from C
jparada
Post by jparada »
I am trying to read a harbour array from a function in C, but I have problems trying to read the strings, the function in C is displaying rare characters when the data type is a string.
I also need to know and display the string length,
I don't know how to do it either.
This is the code:
#pragma -w2
PROCEDURE Main()
    LOCAL aValues := { .F., 'string 1', .T., .F., 5689, 6.593, 'text', 126, 0.3,9 }
    CLS
    TestArray( aValues )
#pragma BEGINDUMP
#include "hbapi.h"
HB_FUNC_STATIC( TESTARRAY )
    #define btoa(x) ((x)?"true":"false")
    PHB_ITEM aValues = hb_param( 1, HB_IT_ARRAY );
    HB_ULONG size = hb_arrayLen( aValues );
    HB_ULONG i;
    int *tmpInt;
    long *tmpLong;
    float *tmpFloat;
    char *tmpString;
    HB_BOOL *tmpBool;
    for( i = 1; i <= size; ++i )
        switch ( hb_arrayGetType( aValues, i ) )
            case HB_IT_STRING:
                tmpString = ( char* ) malloc( sizeof( char ) );
                *tmpString = hb_arrayGetC( aValues, i );      // hb_arrayGetC - Retrieves the string contained on an array element
                                                              // hb_arrayGetCPtr - Retrieves the string pointer on an array element
                printf( "valor cadena %c\n", *tmpString );
                //printf( "valor cadena \n" );
                break;
            case HB_IT_INTEGER:
                tmpInt = ( int* ) malloc( sizeof( int ) );
                *tmpInt = hb_arrayGetNI( aValues, i );
                printf( "valor entero %d\n", *tmpInt );
                free( ( int* ) *tmpInt );
                break;
            case HB_IT_LONG:
                tmpLong = ( long* ) malloc( sizeof( long ) );
                *tmpLong = hb_arrayGetNL( aValues, i );
                printf( "valor entero largo");
                break;
            case HB_IT_DOUBLE:
                tmpFloat = ( float* ) malloc( sizeof( float ) );
                *tmpFloat = ( float ) hb_arrayGetND( aValues, i );
                printf( "valor double %f\n", *tmpFloat );  // decimal
                break;
            case HB_IT_LOGICAL:
                tmpBool = ( HB_BOOL* ) malloc( sizeof( HB_BOOL ) );
                *tmpBool = hb_arrayGetL( aValues, i );
                free( ( HB_BOOL* ) *tmpBool );
                //printf("%s\n", btoa( *tmpBool ));             // it works
                printf("%s\n", *tmpBool ? "verdadero" : "falso");
                break;
            default: break;
#pragma ENDDUMP
Any idea?, I appreciate your help.
Javier
Re: Read array Harbour from C
i'm not a C Guru so forgive me if i'm wrong.
it seems me you want to "transfer" Data "direct" :?:
i just know when try to access a C Function from xBase it most use a Windows Structure.
as harbour seems to be able to create Windows Structure i would try to store Array (convert to BIN ?) into a Member of that Structure. close Structure and send your own User Event to your C App to get data.
KDJ
Post by KDJ »
Javier
Try in this way:
            case HB_IT_STRING:
                printf( "valor cadena: \"%s\", length: %i\n", hb_arrayGetCPtr(aValues, i), (int) hb_arrayGetCLen(aValues, i) );
                break;
jparada
Post by jparada »
Hi Krzysztof,
Thanks for answering, I did the test and it works, one question, does the length also include the null character?
Javier
KDJ
Post by KDJ »
Javier
String length returned by hb_arrayGetCLen() is without NUL terminator.
jparada
Post by jparada »
Hi Krzysztof,
Thanks for the info.
Javier
