AT() with 3 Parameter.
under Xbase++ i have 3 Parameter where 3rd is optional
   At( <cSubString>, <cString>, [<nStartPos>] ) --> nPosition
here i search how often a sign is in a String
FUNCTION Countat( cString, cSign )
LOCAL nRet  := 0
LOCAL nPosi := 1
LOCAL nMax  := LEN( cString )
   DO WHILE nPosi > 0
      nPosi := AT( cSign, cString, nPosi + 1 )
      IF nPosi > 0
         nRet ++
         EXIT
   ENDDO
RETURN nRet
now i got this Error Message
C:\hmg.3.4.4\HARBOUR\contrib\gtwvg\WMP\WM9TOOLS.PRG(2057) Error E0021 Incorrect number of arguments in AT
Passed: 3, expected: 2
hm ... Clipper have only 2 Parameter
so how to add 3rd Parameter <nStartPos> :?:
Greetings Jimmy
Red2
Re: AT() with 3 Parameter.
Post by Red2 »
I believe you are correct, AT() has only 2 parameters in HMG.
(I come from VFP. VFP has its own 3rd parameter: AT(cSearchExpression, cExpressionSearched [, nOccurrence]))
I also have had to work-around this in HMG.
Red2
Tal vez de esta manera...
Maybe this way ...
   DO WHILE nPosi > 0
      nPosi := AT( cSign, cString )
      cString := SUBSTR( cString, nPosi )
      IF nPosi > 0
         nRet ++
         EXIT
   ENDDO
Or
FOR i1 = 1 TO LEN( cString )
	IF SUBSTR( cString, i1, 1 ) == "x"
		nRet ++
Or
nLen1 := LEN( cString )
cString := CharRem( "x", cString )
nLen2 := LEN( cString )
nRet := nLen1 - nLen2
Or
nRet := LEN( cString ) - LEN( CharRem( "x", cString ) )
Thx for Answer.
andyglezl wrote: Wed Oct 23, 2019 3:32 am Tal vez de esta manera...
Maybe this way ...
i did wrote a Function like you recommend but i got this
C:\hmg.3.4.4\HARBOUR\contrib\gtwvg\WMP\WM9.PRG(350) Error E0008 Redefinition of predefined function AT as 'AT'
it seems i can't "override Core" Function under harbour :?:
Greetings Jimmy
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
AUGE_OHR wrote: Wed Oct 23, 2019 5:57 am it seems i can't "override Core" Function under harbour :?:
:idea:
#xtranslate AT(<cSeek>,<cString>[, <nStartPos>]) => hb_Ati( <cSeek>,<cString>, <nStartPos>)
PROCEDURE MAIN
	msgdebug ( AT('x', 'xabcxdef', 3) )
	msgdebug ( AT('x', 'xabcxdef') )
AUGE_OHR wrote: Wed Oct 23, 2019 2:00 am here i search how often a sign is in a String
#xtranslate CountAt( <cString>, <cSign> ) => hb_TokenCount( <cString>, <cSign> ) - 1
PROCEDURE MAIN
	msgdebug ( CountAT('xabcxdef', 'x') )
	msgdebug ( CountAT('xabcxdef', 'i') )
	msgdebug ( CountAT('xabcxxdefx', 'x') )
SALINETAS24
Post by SALINETAS24 »
Maybe this way ...
   DO WHILE nPosi > 0
      IF nPosi > 0
         nRet ++
         EXIT
   ENDDO
solo una pequeña corrección
   DO WHILE nPosi > 0
      cString := SUBSTR( cString, nPosi+1 )   //Sumar 1 a nPos, en caso contrario estará en bucle
      IF nPosi > 0
         nRet ++
         EXIT
   ENDDO
Anand
Post by Anand »
edk wrote: Wed Oct 23, 2019 7:20 am
:idea:
PROCEDURE MAIN
PROCEDURE MAIN
Wow Edward !
You gave a solution I was also looking for as I too have Xbase++ codes. Now both HMG and Xbase++ functions will work.
Thanks a lot.
Anand
Anand
:idea:
AHA :idea:
Perfect :D
Question : is hb_Ati() harbour or HMG :?:
ok
i saw hb_AtI() is a harbour function so i wonder why AT() will only accept 2 Parameter :?:
Question ; what is the Difference between hb_At() vs. hb_Ati() :?:
i have read Description
This function has same functionality as hb_At() with the significant difference that it's case Insensitive.
Optionally, with nStart can be defined the position into main string from where the search of cSearch must begin and with nEnd the position where it must stop. If neither of them is defined, nStart is 1st position and nEnd the ending of cString.
but i still "see" no Difference.
can someone please show me a sample where hb_At() fail while hb_Ati() work :?:
