Harbour MiniGUI Extended Edition build 19.10 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 19.10.
* Added the new commands for managing of the Splash Windows:
INIT SPLASH WINDOW
SHOW SPLASH WINDOW PICTURE <image> ;
[ DELAY <delay> ] ;
[ ON INIT <InitProcedure> ] ;
[ ON RELEASE <ReleaseProcedure> ]
where <image> may be BMP, JPG, PNG, GIF or TIF image
from application's resources or from a disk file.
* Added the new commands for tuning of the Status Items
properties at runtime:
SET STATUSITEM <nItem> OF <Form> ;
[ FONTCOLOR | BACKCOLOR | ALIGN | ACTION ] [ TO ] <xValue>
* Added the useful pseudo-function HMG_SysWait( [ <nSeconds> ] )
which is based upon the Harbour function hb_idleSleep().
* The first code refactoring attempt was made using of the
individual modules for:
- the extended and owner-draw controls;
- the filenames management functions;
- the nonclient C-functions;
- the databases conversion auxiliary functions.
* The normal stringify result markers <""> was changed to smart
stringify result markers <()>. It allows to define the forms and
controls from a variable without using of a macro operator, i.e.
(cVar) instead of &cVar. It was a postponed user's request.
Don't miss these new features!
* Adaptation of MiniGUI core for compatibility with BCC 5.8.2
compiler. It is a preferable C-compiler now instead of BCC 5.5.1.
* The ButtonEX control supports now an optional clause
HOTKEY <KeyName>, the 'ImageWidth' and 'ImageHeight' properties.
* The 'Icon' property in ButtonEX control may accept an icon handle.
* Synchronized Extended HMG for compatibility with Official HMG:
- New: function IsContextMenuDefined ( cFormName );
- New: function IsNotifyMenuDefined ( cFormName ).
* Updated Harbour Compiler 3.2.0dev to a recent Git-version.
(ChangeLog Last Entry: 2019-09-11 10:16)
* Updated the TSBrowse, Curl and Sqlite3 libraries.
* Added the new interesting samples and updated some Basic and
Advanced samples.
A setup of the build 19.10 for Borland C++ 5.8.2 is published at
the following URL:
[MiniGUI Team]
Anand
Re: Harbour MiniGUI Extended Edition build 19.10 is published
Post by Anand »
Thanks Grigory for MG ver 19.10.
Anand
Anand
Big applause and thanks!
Thanks Grigory
quartz565
Post by quartz565 »
Thanks Grigory!
Nikos.
os: Windows Server 2019 - 64
I've uploaded the updated setup of the build 19.10 for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: Problem with a handling of 'Transparent' property of a label
which was placed on top of an image (introduced in the build 19.10).
Bug was reported by Valtecom Jose Martins.
* Modified: ButtonEx: using of the Harbour function hb_tokenCount()
instead of a local implementation.
(see demo3.prg in folder \samples\Basic\ButtonEx)
* Enhanced: Added the Metro color's constants to the header file
include\i_color.ch.
* Updated: HBPrinter library v.2.48:
- modified toolbar buttons placing in the Preview form and a look
of Options dialog;
- updated Greek language translation.
Based upon a contribution of Pete D. <pete_westg/at/yahoo.gr>.
Revised by Grigory Filatov <gfilatov@inbox.ru>
(see demo in folder \samples\Advanced\HBPrinter)
* Updated: Harbour Compiler 3.2.0dev (SVN 2019-09-11 10:16):
* Updated: OpenSSL wrapper for using of the version 1.0.2t.
(look at ReadMe.txt in folder \harbour)
* New: 'Circle Progress Animation' sample.
(see in folder \samples\Basic\CircleProgressAnimation)
Please note that there are also the private MiniGUI builds for the following
well-known free C-compilers:
- MinGW GNU C 9.2.1 (32-bit);
- MinGW GNU C 8.2.0 (64-bit);
- MS Visual C++ 2019 (32-bit);
- MS Visual C++ 2019 (64-bit).
Thanks for your attention.
[MiniGUI Team]
Whatsnew:
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.31.0dev (from 3.30.1).
* the hbrdd and hbrtl core libraries were compiled with the default
switch -l for a smallest size.
Note: the minimal supported platform is Windows XP now.
The recommended platforms are Windows 7 and later.
* Updated: HMGS-IDE v.1.4.3.7 Project Manager and Two-Way Visual Form Designer:
* Changed: the default C-compiler is BCC 5.8 now instead of BCC 5.5.
* Updated: in mpmc.prg use Harbour contrib hbziparc library instead
of obsolete ziparchive library.
(see demo in folder \Ide\Samples\Zip)
* Updated: MPM and MPMC utilities will use Harbour contrib hbziparc library.
(see in folders \Utils\MPM and \Utils\MPMC)
The upgrade to this build is recommended if you had used the IDE or MPM tools.
[MiniGUI Team]
i got a Virus Message :o
i guess it is a Mismatch from my Antivirus Software ...
sorry when i ask ... but i don't understand "which" Version to use now :?:
i understand that MiniGui is Part of HMG but this enhance Version is installed in different Directory :o
as HMG 3.4.4 was configure for MinGW ... did i have to switch to BCC :?:
Question : can i use BCC32 v7.x 32 Bit too :?:
i try to start IDE with
c:\MiniGUI\IDE\ide.exe c:\MiniGUI\IDE\ide.exe
but it does not work :o
but it work with HPJ :!:
i have read about
c:\MiniGUI\BATCH\Compile.Bat
c:\MiniGUI\BATCH\minigui.cfg
and change BCC to my Path
MG_BCC=c:\BCC582
now when load a HBP file it create a INI ... but all Value are "default"
my Request : create new INI from c:\MiniGUI\IDE\ide.ini with all Value under [wPreferences]
AUGE_OHR wrote: Thu Nov 07, 2019 12:20 am i understand that MiniGui is Part of HMG...
Wrong guessing... :oops:
AUGE_OHR wrote: Thu Nov 07, 2019 12:20 am Question : can i use BCC32 v7.x 32 Bit too :?:
Sure.
You can use the MiniGUI Ex library with the following C-compilers:
- MS Visual C++ 2019 (64-bit);
- Borland/Embarcadero C++ 7.4 (32-bit);
- Open Watcom C/C++ 2.0 (32-bit);
- Pelles ISO C 9.0 (32-bit);
- Pelles ISO C 9.0 (64-bit).
HTH :idea:
