OnChange Event Question
Red2
Post by Red2 »
In the IDE when I select a form's TEXTBOX control, click its “Events” tab to add code to its OnChange event then an “OnChange” .PRG is added. However, this .PRG is specific to that control. If I attempt to add it to another TEXTBOX control I get error, “Module Already in Project. Aborted”.
The issue: I have a form with over 20 TEXTBOX controls. I want one single (generic) function called by the OnChange event in all of these TEXTBOX controls. That is, I want to avoid 20 duplicate “OnChange” .PRGs unnecessarily cluttering the project.
Question: Is there a simply way to generically handle all of these OnChange events using one single function?
I would appreciate your kind guidance on how this is best accomplished in HMG.
Thank you, Red2
Re: OnChange Event Question
You can assign this defined function to this event without creating new .prg. Don't use plus button, simply type your function name with parameters
Red2
Post by Red2 »
Hi mol,
Thank you very much. That was so obvious and simple but I missed it.
Thanks again!
Red2
