Xbase++ to harbour / HMG Question
i have some Question when migrate Xbase++ Code to harbour / HMG
how to use DEFAULT :?:
FUNCTION ABCD(xValue)
// how to use DEFAULT with harbour / HMG Question
DEFAULT xValue TO "Hello world"
ist there a ConfirmBox :?:
FUNCTION DXE_ConfirmBox(oOwner, cMessage, cTitle, nButtons,nStyle,nStartBtn)
   // https://docs.microsoft.com/en-us/windows/desktop/api/winuser/nf-winuser-messageboxa
   nRet := @User32:MessageBoxA(hWnd,cMessage,cTitle,uType)
how to convert BIN to HEX :?:
// Store Bitmap in HEX Format using cBin2Hex()
LOCAL cSql    := "UPDATE " + ::_cTable + " SET "
   // Bin to HEX Format using ot4xb
   cSql += ::_aBroFields[ nCol ] [ DBS_NAME ] + "= '\x" + cBin2Hex( cBuffer ) + "' "
how to convert HEX to BIN :?:
// read Bitmap in HEX Format using cHex2Bin()
   // Hex to Bin Format using ot4xb
   oBMP:setBuffer( cHex2Bin( cBuffer ) )
how to choise CPU :?:
FUNCTION SmpGetCPU()
LOCAL i
    i := DllCall("Xpprt1.dll",DLL_CDECL, "_sysGetCPU")
RETURN i
FUNCTION SmpSetCPU(nCpuMask)
LOCAL rc
    rc := DllCall("Xpprt1.dll",DLL_CDECL, "_sysSetCPU", nCpuMask)
RETURN rc
how to use Thread ( with different CPU ) :?:
now to use GRID (c:\hmg.3.4.4\SOURCE\h_grid.prg) :?:
need help please
ROBROS
Re: Xbase++ to harbour / HMG Question
Post by ROBROS »
Hi Jimmy,
if you install IDE and choose References you will find a description of all controls, methods and so on. Very useful the external guides and tutorials.
In the folder C:\hmg.3.4.4\SAMPLES\ you will find a lot source codes. And in this forum you will find useful sources.
I'm just working on a prog with toolbar and grid, but I can't publish it here, for the personal data are real existing.The grid is already working, the buttons have yet to be filled with functions.
Robert
PS: If you are interested I could anonymize the personal data (name and city), so I could publish the dbf.
jairpinho
Post by jairpinho »
AUGE_OHR wrote: Tue Aug 27, 2019 5:48 pm hi,
LOCAL i
RETURN i
LOCAL rc
RETURN rc
need help please
hello follow some documentation links that contain all your initial doubts in hmg and harbour, in case you can't find what you're looking for put your question again
HMG
hmgdoc/data/
HARBOUR
http://www.marinas-gui.org/projects/harbour_manual/
http://www.elektrosoft.it/tutorials/Har ... -guide.htm
https://harbour.github.io/doc/
https://vouch.info/harbour/index.html?vm.htm
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
IMATECH
Post by IMATECH »
cData := hb_DefaultValue( cData, "Default Value" )
MsgYesNo( "MessageBox Test", "MsgYesNo", bDefult )
how to convert BIN to HEX :?: how to convert HEX to BIN :?:
*** hbmk2 -find hex
hbmisc.hbc
   DecToHexa()
   HexaToDec()
   IsHexa()
hbnf.hbc (instalado):
   ft_Byt2Hex()
   ft_Hex2Dec()
xhb.hbc
   HexToNum()
   HexToStr()
   NumToHex()
   StrToHex()
Harbour Core ***
   hb_HexToNum()
   hb_HexToStr()
   hb_NumToHex()
   hb_StrToHex()
*** hbmk2 -find bin
hbmisc.hbc
   BinToDec()
   DecToBin()
   IsBin()
hbnf.hbc
   ft_Dec2Bin()
Harbour Core ***  Return -> Int <- Param
   Bin2I()
   Bin2L()
   Bin2W()
   I2Bin()
   L2Bin()
how to use GRID (c:\hmg.3.4.4\SOURCE\h_grid.prg) :?:
\hmge\SAMPLES
M., Ronaldo
By: IMATECH
Imation Tecnologia
THX all for Answer
for Newbie it always the Problem "where" to search "what" as i don't know Xbase++ Parts Name is in Harbour / HMB
Confirmbox() -> MsgYesNo() -> c:\hmg.3.4.4\SOURCE\h_msgbox.prg
about Thread i found
 Hb_ThreadStart( {|| func() } )
Question : is there a "Starttime" for Thread :?:
   oThread1:setStartTime( SECONDS()+1 )
   oThread1:start( {|| PostAppEvent(xbeE_Start,{0,0}) } )
about CPU i don't find something like "SetProcessAffinityMask" or "SMP" :?:
//*-------------------   GetAffinity   --------------------
// find the current active processor (bit position)
function GetAffinity
  local ProcMask := 0
  local SysMask := 0
  local t :=
@kernel32:GetProcessAffinityMask(@kernel32:GetCurrentProcess(),@ProcMask,@SysMask)
return ProcMask
//*-------------------   SetAffinity   --------------------
// set the current active processor
function SetAffinity(nProc)
   @kernel32:SetProcessAffinityMask(@kernel32:GetCurrentProcess(),2^nProc)
return nil
about GRID ( c:\hmg.3.4.4\SOURCE\h_grid.prg)
is it a WC_LISTVIEW (SysListView32) :?:
i'm not sure about Syntax : does "ALIAS Test" work with ROWSOURCE "Test" ... how can i check if "PGRDD" ist working :?:
   USE "SELECT * FROM "+cTable+" ;" ALIAS Test NEW VIA "pgrdd" CONNECTION nConnectionHandle
   // Check it
    ? USED()
    ? ALIAS()
    // how in harbour / HMG
    ? DBINFO( DBO_DBENAME )  // RDD Name
   DEFINE WINDOW Form_1 ;
   // hm ... why is it empty
      @ 10,10 GRID Grid_1 ;
         WIDTH 770 ;
         HEIGHT 440 ;
         HEADERS aField
         WIDTHS aWidth
         ROWSOURCE "Test"
i got the GRID with Header but no Data :o
Table have create before and i can access it with PgAdmin.
Anand
Post by Anand »
Hi Jimmy,
I see, you are trying to convert your Xbase++ codes to HMG.
Best would be, if you post whatever code you have made and we can check and suggest correction to it.
There are many ways a similar Xbase++ logic can be converted to HMG. Note, I said "logic" and not "code". There are many functions in HMG which will simplify logic and which does not exist in Xbase++. So if you try converting "code-by-code" it will be difficult for both you and us to guide.
Anand
Anand
i have modify SMP Sample to run under harbour / HMG
i need to use
libs=hbxpp
to use Xbase++ Syntax for DLL Call ... but it crash with harbour / HMG :?
   rc := dllcall( "Kernel32.dll", DLL_STDCALL, "SetProcessAffinityMask",ip,nProc)
   rc := dllcall( "Kernel32.dll", DLL_STDCALL, "GetProcessAffinityMask",ip,@ProcMask,@SysMask)
i saw DLL Call with User32
c:\hmg.3.4.4\HARBOUR\contrib\hbxpp\tests\dllcall.prg
 ? "MsgBox:", DllCall( "user32.dll", DLL_OSAPI, "MessageBoxA", 0, "Hello world!", "Harbour sez", hb_bitOr( MB_OKCANCEL, MB_ICONEXCLAMATION, MB_HELP ) )
c:\hb30\tests\testdyn.prg
 ? "MsgBox:", hb_dynCall( { "MessageBoxA", "user32.dll", HB_DYN_CALLCONV_STDCALL }, 0, "Hello world!", "Harbour sez", hb_bitOr( MB_OKCANCEL, MB_ICONEXCLAMATION, MB_HELP ) )
but do not know what to use with Kernel32 :?:
about SMPRUN
it will assign a CPU Core to App while running using a BitMask (2^n)
Core 0   1
Core 1   2
Core 2   4
Core 3   8
have use HMG_CallDLL ( ) now an App start ... but i can not change CPU :(
SMPRUN.ZIP
(3.39 KiB) Downloaded 253 times
AUGE_OHR wrote: Thu Aug 29, 2019 1:30 am hi,
about SMPRUN
Core 0   1
Core 1   2
Core 2   4
Core 3   8
Hi Jimmy,
Thanks for your sample code :!:
I was succeed with changing of a CPU core on my PC (after many wrong times).
Please take a look for the updated working sample below: :arrow:
#include "dll.ch"
#include "inkey.ch"
#include "common.ch"
#define MB_OK                       0x00000000
#define MB_ICONEXCLAMATION          0x00000030
 * Einfache Test-Schleife zum Abfragen/Setzen der CPU
 * 0 - Beendet Beispiel
 * 1 = Nur Erste CPU, 2 = 2. CPU, 4 = 3. CPU, 16 = 8. CPU
PROCEDURE Main
LOCAL nCpu := 1 , nMax := 0
LOCAL aCPU := {1,2,4,8,16,32,64,128,256,512}
LOCAL ProcMask := 0
LOCAL SysMask := 0
#IFDEF __XPP__
   Thread():new():start("stress")
#ELSE
   REQUEST HB_GT_WIN_DEFAULT
   Hb_ThreadStart({|| Stress() } )
#ENDIF
   CLS
   nMax := CHECKCPU()
   ? "CPU have "+ STR(nMax) + " Core"
   DO WHILE .T.
       nCpu := SmpGetCPU(@ProcMask,@SysMask)
       IF EMPTY(nCpu)
         nCpu := 1
       ? "Apps run under CPU(s): " + STR(nCpu)
       INPUT "New CPU-Mask: (0 => End)" TO nCpu
       IF nCpu = 0
          EXIT
       IF ASCAN(aCPU, {|e| e = nCpu }) > 0
          IF SmpSetCPU(nCpu) = 0
             ? "Error CPU-Mask :" + STR(nCpu)
   ENDDO
FUNCTION SmpGetCPU(ProcMask,SysMask)
LOCAL i
*#IFDEF __XPP__
*    i := DllCall("Xpprt1.dll",DLL_CDECL, "_sysGetCPU")
*#ELSE
   GetProcessAffinityMask(@ProcMask,@SysMask)
   i := Mask2CPU(ProcMask)
*#ENDIF
RETURN --i
LOCAL rc
*#IFDEF __XPP__
*    rc := DllCall("Xpprt1.dll",DLL_CDECL, "_sysSetCPU", nCpuMask)
*#ELSE
    rc := SetProcessAffinityMask(nCpuMask)
*#ENDIF
RETURN rc
PROCEDURE Stress()
LOCAL a:= {3,2,1,0}
    DO WHILE .T.
        ASort(a)
    ENDDO
// Syntax need libs=hbxpp
FUNCTION GetCurrentProcess()
LOCAL rc := 0
   rc := dllcall( "Kernel32.dll", DLL_OSAPI, "GetCurrentProcess" )
RETURN rc
FUNCTION GetProcessAffinityMask(ProcMask,SysMask)
LOCAL rc := 0
LOCAL ip := 0
LOCAL bOldError
   bOldError := ERRORBLOCK( { | e | BREAK( e ) } )
   BEGIN SEQUENCE
      ip := GetCurrentProcess()
      rc := dllcall( "Kernel32.dll", DLL_OSAPI, "GetProcessAffinityMask",ip,@ProcMask,@SysMask)
   END SEQUENCE
   ERRORBLOCK( bOldError )
   IF EMPTY(rc)
      DllCall( "user32.dll", DLL_OSAPI, "MessageBoxA", 0, "Error GetProcessAffinityMask"+STR(ProcMask)+STR(GetLastError()), "Invalid parameter", hb_bitOr( MB_OK, MB_ICONEXCLAMATION ) )
      rc := 0
RETURN rc
FUNCTION SetProcessAffinityMask(nProc)
LOCAL rc := 0
LOCAL ip := 0
LOCAL bOldError
   BEGIN SEQUENCE
      rc := dllcall( "Kernel32.dll", DLL_OSAPI, "SetProcessAffinityMask",ip,nProc)
   END SEQUENCE
   IF EMPTY(rc)
      DllCall( "user32.dll", DLL_OSAPI, "MessageBoxA", 0, "Error SetProcessAffinityMask"+STR(nProc)+STR(GetLastError()), "Invalid parameter", hb_bitOr( MB_OK, MB_ICONEXCLAMATION ) )
      rc := 0
RETURN rc
*#IFDEF __XPP__
FUNCTION GetLastError()
LOCAL rc := 0
   rc := dllcall( "Kernel32.dll", DLL_OSAPI, "GetLastError")
RETURN rc
*#ENDIF
FUNCTION switchcpu( nMax )
LOCAL nWorkCPU
LOCAL nStep
   DEFAULT nMax TO 1
#IFDEF __XPP__
   IF nMax > 1
      nStep := RandomInt( 2, nMax )
      nStep := RandomInt( 1, nMax )
#ELSE
   IF nMax > 1
      nStep := Int(Random( 2, nMax ))
      nStep := Int(Random( 1, nMax ))
#ENDIF
   IF nStep = 1
      SmpSetCPU( 1 )
      nWorkCPU := 2 ^ INT( nStep - 1 )
      IF SmpSetCPU( nWorkCPU ) = 0
         SmpSetCPU( 1 )
   nWorkCPU := SmpGetCPU()
RETURN nStep
FUNCTION CHECKCPU()
LOCAL nStep
LOCAL nMaxCPU
   nStep := 1
   DO WHILE .T.
      nMaxCPU := 2 ^ nStep
//      IF SmpSetCPU( nMaxCPU ) = 0
         EXIT
//      ENDIF
      nStep ++
   ENDDO
   nStep := Mask2CPU(nStep)
RETURN nStep
FUNCTION Mask2CPU(nMask)
LOCAL nCPU := 1
LOCAL nRest := nMask
   DO WHILE nRest >= 1
      nRest := nRest / 2
      nCPU++
   ENDDO
RETURN nCPU
Please note that I should set the multithread switch in my link script for correct work of above application.
Hope that helps :idea:
gfilatov wrote: Thu Aug 29, 2019 6:39 pm I was succeed with changing of a CPU core on my PC (after many wrong times).
THX for your Time and working Sample.
gfilatov wrote: Please take a look for the updated working sample below: :arrow:
as i can see you change Constant DLL_STDCALL to DLL_OSAPI.
i have test your Sample with Xbase++ and it still run with DLL_OSAPI
so i have to check my Xbase++ Code where i used DLL_STDCALL and try DLL_OSAPI instead
while i want to learn harbour / HMG i like to ask how it look like
#IFDEF __XPP__
#ELSE
*  rc := hb_dynCall( "GetCurrentProcess", "Kernel32.dll", HB_DYN_CALLCONV_SYSCALL  )
   rc := HMG_CallDLL ( "Kernel32.dll", HB_DYN_CALLCONV_SYSCALL, "GetCurrentProcess" )
#ENDIF
gfilatov wrote: Please note that I should set the multithread switch in my link script for correct work of above application.
is this in *.HBC :?:
libs=hbxpp
mt=yes
i do not know about harbour / HMG Multithread. can i use more than 1 x Core for harbour / HMG :?:
as Xbase++ can only use 1 x Core i have ASCAN() in Demo Code to validate if it is 2^n
with harbour / HMG you can try other combination of e.g.
(2^1) + (2^2) + (2^3) + (2^4)
to run on 4 x CPU
SetProcessAffinityMask() is for hole App. for Thread is a SetThreadAffinityMask() API Function
https://docs.microsoft.com/de-de/window ... finitymask
but it need an Pointer so i add Variable pThread
   pThread := Hb_ThreadStart({|| Stress() } )
and HMG Debugger show me pThread as Pointer but no Value :?:
what is used in harbour / HMG for
PeekWord(<pMem>,[[@]<nShift>]) -> <nWord>
PeekWord(<pMem>,[[@]<nShift>], <nItems>) -> <aWords>
Retrieve the value of one or more WORDs from the memory buffer pointed by <pMem> starting at the position <nShift>.
attach Sample is to detect if DLL is for 32 Bit or 64 Bit
DLL6432.ZIP
(617 Bytes) Downloaded 248 times
#include "Fileio.ch"
#include "ot4xb.ch" // this include Ot4Xb.LIB which have PeekWord()
#define IMAGE_FILE_MACHINE_I386  0x14c
#define IMAGE_FILE_MACHINE_IA64  0x200
#define IMAGE_FILE_MACHINE_AMD64 0x8664
PROCEDURE Main(cDLL)
LOCAL cBuffer, nHandle, nBytes, nPointer
LOCAL cMachineType
LOCAL hHex
LOCAL cText := ""
   IF !FILE(cDLL)
      ALERT("Dll Name missing")
      QUIT
   nHandle  := FOpen( cDLL , FO_READ )
   cBuffer  := Space(512)
   nBytes   := FRead(nHandle, @cBuffer, 512)
   FClose( nHandle )
   nPointer := AT("PE"+CHR(0)+CHR(0),cBuffer)
   IF nPointer > 0
      cMachineType := ( SUBSTR(cBuffer,nPointer+4,2) )
 // this line
      hHex := PeekWord(cMachineType)
      DO CASE
         CASE hHex = IMAGE_FILE_MACHINE_I386
            cText := "for 32bit Machine"
         CASE hHex = IMAGE_FILE_MACHINE_IA64 .OR. ;
                   hHex = IMAGE_FILE_MACHINE_AMD64
            cText := "for 64bit Machine"
      OTHERWISE
            cText := "unknown Machine"
      ENDCASE
   ALERT(cText)
