Why Are So Many Developers Hating on Object-Oriented Programming?
Nice observation on OOP(s)...
https://thenewstack.io/why-are-so-many- ... ogramming/
Re: Why Are So Many Developers Hating on Object-Oriented Programming?
Anand
Post by Anand »
OOP is like using a knife.
If you do not know how to use it, you will cut yourself. But if you know, you will complete your cutting job smoothly.
I got to know about OOP while using Clipper 5 in using TBrowse. Though I liked the idea I had lots of problem in handling and understanding it. At present, XBase++ also uses OOP extensively, so I had to get in depth of it.
Now I mostly use OOP in my development and can say it increased my efficiency. The entire flagship product of our company is based on OOP and is developed and maintained by yours truly alone.
Thanks to OOP I am able to accomplish it :)
Anand
Anand
Anand wrote: Thu Aug 22, 2019 11:45 am OOP is like using a knife.
Anand
Hello Anand,
Thanks for your observation and the nice words!
Please take a look for the following Minigui test application based on a freeware class which was borrowed and adapted by me from the FiveWin library.
Application screenshot
TestMP3Info.zip
Test application along with the souces
(1.19 MiB) Downloaded 163 times
Anand
Post by Anand »
Thank you Grigory.
Yes, my report class viewtopic.php?p=51251#p51251 is also based on OPP (Class Y of Clipper).
Anand
Anand
