Harbour MiniGUI Extended Edition build 19.08 is published
Posted: Wed Aug 21, 2019 6:14 am
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
It is a regularly scheduled maintenance and bugfix release.
Here's a breakdown of some of the modifications in the build 19.08.
For the full list, please see the changelog.
* Fixed missed hiding of all controls on a FOCUSED deleted TabPage in the
function _DeleteTabPage().
It exists in the official version too.
* Added possibility to modify the following Windows events at runtime:
- OnInit
- OnRelease
- OnInteractiveClose
- OnGotFocus
- OnLostFocus
- OnNotifyClick
- OnMouseclick
- OnMouseDrag
- OnMouseMove
- OnMove
- OnSize
- OnMaximize
- OnMinimize
- OnPaint
- OnRestore
- OnDropFiles
* Added the useful pseudo-functions HMG_RGB2n( n1 [, n2] [, n3] ) and
HMG_n2RGB( n ) for converting of a color array.
* Added the useful pseudo-functions GetFontWidth( FontName, nLen ) and
GetFontHeight( FontName ) for receiving of the font's parameters.
Note that a font should be defined by command
DEFINE FONT <FontName> FONTNAME <sysfont> ...
* The 'Cursor' property is supported in the function GetProperty()
for the Forms.
* Added possibility to modify of 'OnEnter' event for the controls
at runtime.
* Added possibility to modify of the 'OnListDisplay/OnDropDown' and
'OnListClose/OnCloseUp' events for ComboBox control at runtime.
* The Spinner control supports now a changing of the INCREMENT
property at runtime.
* The Timer control supports now a changing of the INTERVAL and
ONCE properties at runtime.
* The BTNTEXTBOX control supports now a changing of the separated
TOOLTIPs for the edit box and buttons at runtime.
* The GETBOX control supports now a changing of the separated
* The global fonts which were defined by the command DEFINE FONT
<font> FONTNAME <name> ... will preserved after closing of a form.
* A 'Value' property will changed to a first available item in the
RadioGroup control if a focused item was disabled with a putting of
'ReadOnly' property.
* Updated the TSBrowse, HBPrinter, SDDsqlt3 and Sqlite3 libraries.
* Updated the auxiliary add-on binary archive for using of
PageScript DLL ver. 3.0.4.124 (from 3.0.4.119).
* Added the new interesting samples and updated some Basic and
Advanced samples.
A setup of the build 19.08 for Borland C++ 5.5.1 is published at
the following URL:
The upgrade to this build is highly recommended.
PLEASE DONATE IF YOU WOULD LIKE TO SUPPORT YOUR FAVORITE TOOL.
Thanks for your attention and support!
Best Regards,
[MiniGUI Team]
- OnInit
- OnRelease
- OnGotFocus
- OnLostFocus
- OnNotifyClick
- OnMouseclick
- OnMouseDrag
- OnMouseMove
- OnMove
- OnSize
- OnMaximize
- OnMinimize
- OnPaint
- OnRestore
- OnDropFiles
for the Forms.
at runtime.
Advanced samples.
the following URL:
Best Regards,
[MiniGUI Team]
