Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 19.06.
* Fixed a problem with a handling <Esc> key into the function HMG_Alert()
(introduced in the build 18.02).
Processing of a closing of a window in the Alert* family functions is
similar to the system dialogs in Windows 7.
* Fixed a problem with using of the function AScan() without <lExact> switch
into the function HMG_GetFormControls() (introduced in the build 19.04).
* Fixed a wrong using of the Registry class in the function DeleteRegistryKey().
* Added the new command
DELETE [REGISTRY] SECTION <cKey> FROM [KEY] <hKey>
instead of the mistaked command DELETE KEY <cKey> OF <oReg>.
* Correction of SetKey events processing in the GetBox control.
You can modify an action of the predefined keys in GetBox now.
* Updated the HbFImage, RDDLeto and Sqlite3 libraries.
* Added the auxiliary add-on binary archive for a correct launching of
the MiniGUI advanced samples.
BTW Above archive contains the freeware QHTM and RMChart installers which
are not available now from the official homepages.
* Updated some Basic and Advanced samples.
A setup of the build 19.06 for Borland C++ 5.5.1 is published at
the following URL:
Thanks for your attention and support!
[MiniGUI Team]
Harbour MiniGUI Extended Edition build 19.06 is published
Re: Harbour MiniGUI Extended Edition build 19.06 is published
Thanks a lot Grigory, for continuing to deliver new and useful features.
Anand
Anand
Thanks a lot Grigory!
Buen día:
Tengo un problema para descargar el archivo, el firewall me dice que esta infectado por un troyano, si lo descargo desde otro sitio donde no tengo el firewall activado se descarga, solo quiero dar el aviso y tomar precauciones.
- Trojan.jpg (26.06 KiB) Viewed 3256 times
Thanks for your report!
I believe that it's a false positive because there are many reports about the wrong alerts with Gateway AV on the Internet:
I got confirmation from the threat research team - they removed the signature and this will go into effect within 24 hours. They believe that it's a false positive.
Perfecto!
Gracias por su trabajo.
