Google Sheets with HMG
jayadevu
Post by jayadevu »
Has anybody worked with Google Sheets in HMG ? Any working example ?
Warm regards,
Jayadev
Re: Google Sheets with HMG
Jayadev (Here we meet again!)
See https://sites.google.com/a/temple.edu/ ... usformats
Export a Google Spreadsheet into Various Formats
posted Apr 28, 2010, 5:05 AM by Cynthia R. Schwarz [ updated May 24, 2010, 5:33 AM ]
You can export a spreadsheet in several different file formats, including Excel (.xls only), OpenOffice, PDF, Text, HTML*, and CSV. To export a spreadsheet, select File > Download as and select a file type. Then select Open or Save.
jayadevu
Post by jayadevu »
Hi Serge,
World is a very small place :-)
>>You can export a spreadsheet in several different file formats, including Excel (.xls only), OpenOffice, PDF, Text, HTML*, and CSV. To export a >>spreadsheet, select File > Download as and select a file type. Then select Open or Save.
I need to update a Google Sheet which is already in the Google drive and used by many users concurrently. Hence I wanted to know if there is any kind of interface with OLE available.
Warm regards,
Jayadaev
In that case I can't help you!
