Error in Virtual Grid with dynamic font
I found wrong behavior of GRID control when DynamicFont is used.
I want to use editable virtual grid with last column displayed with different font.
Everything goes OK with displaying.
When I edit cell and want to save it in array, This.CellColIndex always returns index of column dynamic font (in my sample last column, but you can test it with another)
	public aCellCoordinates := {0,0}
	private aItems := {}
	AADD (aItems, {"Carrot",        5, "A"})
	AADD (aItems, {"Cauliflower",   0, "B"})
	AADD (aItems, {"Corn",         15, "C"})
	AADD (aItems, {"Tomato",        0, "D"})
	AADD (aItems, {"Zucchini",     20, "E"})
	aControls := { NIL, {'TEXTBOX','NUMERIC'}, NIL }
	aValid	:= { {||Grid_1_Valid()}, {||Grid_1_Valid()}, {||Grid_1_Valid()} }
	aWhen	:= { {||Grid_1_When()}, {||Grid_1_When()}, {||Grid_1_When()} }
	aJustify := {  GRID_JTFY_LEFT, GRID_JTFY_RIGHT, GRID_JTFY_CENTER }
   DEFINE WINDOW Form_1 ;
      WIDTH 600 ;
      HEIGHT 400 ;
      MAIN
	DEFINE GRID Grid_1
		PARENT Form_1
		ROW 10
		COL 10
		WIDTH 550
		HEIGHT 330
		ITEMS NIL
		HEADERS {'Product','Stock','Supplier'}
		FONTNAME "ARIAL"
		FONTSIZE 12
		WIDTHS {250,150,100}
		ALLOWEDIT .T.
		CELLNAVIGATION .T.
		COLUMNCONTROLS aControls
		COLUMNVALID aValid
		COLUMNWHEN aWhen
		VIRTUAL .T.
		OnQueryData Grid_1_OnQueryData()
		ITEMCOUNT len(aItems)
	END GRID
	aFont := ARRAY FONT "Webdings" SIZE 12 BOLD ITALIC
	if MsgYesNo("Do you want to test with Dynamic Font?")
		Form_1.Grid_1.ColumnDYNAMICFONT  (3) := {|| IF ( Form_1.Grid_1.CellEx(This.CellRowIndex,2) == 0, aFont, NIL) }
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
function Grid_1_OnQueryData
	local nRow
	local nCol
	nRow := This.QueryRowIndex
	nCol := This.QueryColIndex
	if nRow>0 .and. nCol >0
		This.QueryData := aItems[nRow, nCol]
return
function Grid_1_Valid
	local nRow
	local nCol
	nRow := This.CellRowIndex
	nCol := This.CellColIndex
	MsgInfo( "Coordinates saved in VALID function: " + hb_valtoexp(aCellCoordinates)+chr(10)+;
		"Actual coordinates: "+hb_valtoexp({nRow, nCol}) )
	aItems[nRow, nCol ] := This.CellValue
 return .t.
function Grid_1_When
	aCellCoordinates := { This.CellRowIndex, This.CellColIndex }
return .T.
Re: Error in Virtual Grid with dynamic font
Yo veo que si se está grabando en el ARRAY lo que hay en el GRID...(o tal vez no entendí tu pregunta)
I see that if you are recording in the ARRAY what is in the GRID ... (or maybe I did not understand your question)
OK ya vi el problema
OK I saw the problem
Si cambias lo siguiente, funciona OK
If you change the following, it works OK
	local nRow
	local nCol
	*nRow := This.CellRowIndex
	*nCol := This.CellColIndex
	nRow := aCellCoordinates[ 1 ]
	nCol := aCellCoordinates[ 2 ]
	MSGDEBUG( aItems )
 return .t.
Of course we can use workaround, but this situation is a bug and should be repaired in sources.
I've lost a lot of time to find what's going on
Lo siento, yo nunca he modificado algún fuente de HMG...
I'm sorry, I've never modified any source of HMG ...
A quien corresponda:
To whom it May concern:
mol wrote: Fri May 10, 2019 9:22 pm Of course we can use workaround, but this situation is a bug and should be repaired in sources.
I found another strange behavior of GRID control.
When I'm editing cell with defined WHEN, when function is called for every cell in row - it causes strange flickering, etc...
I'll prepare small sample or video.
While investigating this, I found the problem is within PROCEDURE _HMG_GRIDINPLACEKBDEDIT_2(i) in h_grid.prg lines 1957-2035:
If ValType ( aColumnWhen ) == 'A'
                  nStart := _HMG_SYSDATA [ 15 ] [I]
                  nEnd := HMG_LEN ( aColumnWhen )
                  For j := nStart To nEnd
                     If ValType ( aColumnWhen [j] ) == 'B'
                        IF _HMG_SYSDATA [ 40 ] [ i ] [ 9 ] == .F.
                           aTemp := this.item( nWhenRow )
                           xTmpCellValue := aTemp [j]
                           _HMG_SYSDATA [ 201 ] := nWhenRow // QueryRowIndex
                           _HMG_SYSDATA [ 202 ] := j   // QueryColIndex
                           _HMG_SYSDATA [ 320 ] := .T.
                           IF ValType ( _HMG_SYSDATA [ 40 ] [ i ] [ 10 ] ) == 'C'
                              GetDataGridCellData ( i , .t. )
                              Eval( _HMG_SYSDATA [  6 ] [ i ]  )
                           _HMG_SYSDATA [ 320 ] := .F.
                           xTmpCellValue := _HMG_SYSDATA [ 230 ]
                        _HMG_SYSDATA [ 318 ] := xTmpCellValue
                        _HMG_SYSDATA [ 232 ] := 'GRID_WHEN'
                        lResult := Eval ( aColumnWhen [j] )
                        _HMG_SYSDATA [ 232 ] := ''
                        If lResult == .F.
                           _HMG_SYSDATA [ 15 ] [I]++
                        Else
                           Exit
                        EndIf
                     EndIf
                  Next j
Setting nEnd to HMG_LEN ( aColumnWhen ) causes testing every cell to the end of row - why?!
In my opinion it should be tested only current cell.
Marek,
I'm afraid that as long as we have no successor for Claudio, we will have to work with this kind of work-arounds...
Regretfully, but I don't see any other option...
You are right, Serge!
It's very sad.
Our hmg is going to dead.
It is dangerous to have only one leader
apais
Post by apais »
That's why I've been suggesting the merge among HMG and HMG Extended.
HMG Extended has a better development pace, and Harbour has a better forum/community.
Angel Pais
