Path length in function file() ?
dominique_devuyst
Post by dominique_devuyst »
Hello everybody,
It seems that the file() function does not accept a path longer than 56 characters?
example:
x := file ("c:\folder\subfolder\subfolder\somefile")
result --> x = .F. if length of c:\folder\subfolder\subfolder\ > 56
Windows 7 supports 260 characters, but I can not find any specification in the Harbour doc.
Somebody knows what?
Re: Path length in function file() ?
Hi Dominque,
On w7 if tested a file of +100 len
cFILE := 'P:\CDS\Allan Holdsworth-Alan Pasqua-Jimmy Haslip-Chad Wackerman\Blues for Tony Disc 1\01 Blues for Tony.WMA'
IF FILE(cFILE)
   MSGINFO('OK')
   MSGINFO('NOK')
And it gave OK!
I'll try on my w10 later.
On w10 also OK!
Are you sure to check for the right filename?
SALINETAS24
Post by SALINETAS24 »
En xp es correcto
dominique_devuyst
serge_girard wrote: Tue Apr 23, 2019 3:10 pm On w10 also OK!
Hello Serge,
Yes, I am sure. I have tested with a path of variable length by adding one character at a time and with always de same filename, len 15 characters.
file() return .T. but arrived at 56 characters the function returns .F.
I am on W7.
So, I will continue to search.
Dominique
Please, do a simple test:
PROCEDURE Main
Local cPath := hb_CWD() + "folder 1234567890\ABCDEFGH ijklmn\123 456\__________\+_+_+_+_+_+_+_+_+_+_+_+_+_+\(^)(^)(^)(^)(^)(^)(^)(^)(^)(^)\!@!@!@!@!@!@!@!@!\"
Local cFile := "test 1234567890 abc DEF.txt"
IF ! hb_DirBuild ( cPath )
	MsgStop ( "Error creating the folders." )
IF StrFile ( cPath + cFile, cPath + cFile ) < Len ( cPath + cFile )
	MsgStop ( "Error creating the file." )
	MsgInfo ( "Your file: " + cPath + cFile )
MsgDebug ( "File():", File ( cPath + cFile ), "Len ():", Len ( cPath + cFile ) )
MsgDebug ( "hb_FileExists():", hb_FileExists ( cPath + cFile ), "Len ():", Len ( cPath + cFile ) )
dominique_devuyst
edk wrote: Tue Apr 23, 2019 6:36 pm Please, do a simple test:
PROCEDURE Main
Your example works fine, thank you.
Now I found the problem :
The pathname was not the problem but . . .
filename was not trimmed and with trailing blanks len (pathname + filename) > 260 :oops:
It's better just to laugh . . .
Dominique
Sometimes it happens that an obvious mistake is difficult to notice. ;)
