Install a font from program code?
I want to install a font automatically from an HMG program (this way I must not install it manually).
Someone has done that?
Any help is welcome.
TIA.
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: Install a font from program code?
Post by dragancesu »
Maybe help https://community.spiceworks.com/topic/ ... s-remotely
One post is
Copy and paste is by far the easiest option for only 15 computers.
Here I had to install a few fonts on a couple of hundred PC's, so I followed these steps:
http://egilhansen.com/2010/09/29/how-pa ... deployment
Make sure to read comments as the program has been updated since the how-to. Its a bit of faffing around but it works.
I do it this way:
1. At first, it extracts the font file from the resources:
IF !FILE( 'saxmono.ttf' )
	STRFILE ( HMG_LoadResourceRawFile ( 'saxmono', RT_RCDATA ), 'saxmono.ttf' )
2. Next, I install the font for private use (the font is available only for my application):
AddFont ( 'saxmono.ttf' )
SET FONT TO "saxMono", 13
 FUNCTION AddFont( cfontfile )
   #define FR_PRIVATE 0x10
   #define FR_NOT_ENUM 0x20
   Return WAPI_ADDFONTRESOURCEEX( cfontfile, FR_PRIVATE + FR_NOT_ENUM, 0 )
3. When I exit the program, I uninstall the font
RemoveFont ( 'saxmono.ttf' )
 FUNCTION RemoveFont( cfontfile )
   Return WAPI_REMOVEFONTRESOURCEEX( cfontfile, FR_PRIVATE + FR_NOT_ENUM, 0 )
edk wrote: Fri Apr 19, 2019 8:55 pm I do it this way:
At first, thanks for the response.
I've forgot to take a look at hbwin :oops:
dragancesu wrote: Fri Apr 19, 2019 7:48 pm Maybe help [url]https://community.spiceworks.com/t ... s-remotely[/url]
One post is
Thanks for the response too. This is a very good alternative.
And... the first link says: "404" :(
dragancesu
Ops, wrong link, look now
dragancesu wrote: Sat Apr 20, 2019 3:17 pm Ops, wrong link, look now
Thanks. It's ok now!
mmmmm.....
Algo estoy haciendo mal, no logro que se muestre en la aplicación este tipo de font.
mmmmm .....
Something I'm doing wrong, I can not get this kind of font to show on the application.
demofont.zip
(22.92 KiB) Downloaded 194 times
