Imagen en la ultima columna GRID
AidTIC
Post by AidTIC »
Hola,
Como puedo hacer que en la ultima columna de mi grid aparezca una imagen y que no salga en la primera columna.
Gracias
Hello,
How can I make an image appear in the last column of my grid and not appear in the first column?
Thank you
   aItems := {}
   AADD (aItems, {"Carrot",        5 , 0 } )
   AADD (aItems, {"Cauliflower",   0 , 0 })
   AADD (aItems, {"Corn",         15 , 0 })
   AADD (aItems, {"Tomato",        0 , 0 })
   AADD (aItems, {"Zucchini",     20 , 0 })
   DEFINE WINDOW Form_1 ;
      WIDTH 600 ;
      HEIGHT 400 ;
      MAIN
      @ 10,10 GRID Grid_1 ;
         WIDTH 550 ;
         HEIGHT 330 ;
         HEADERS {'Product','Stock',"DEL"} ;
         WIDTHS {250,150,40};
         ITEMS aItems;
         ON CHANGE Test_Value();
         EDIT;
         CELLNAVIGATION;
   Form_1.Grid_1.ColumnJUSTIFY (2) := GRID_JTFY_RIGHT
   Form_1.Grid_1.Image (.T.) := {"_No.bmp" }
   FOR i = 1 TO Form_1.Grid_1.ItemCount
       Form_1.Grid_1.ImageIndex (i,3) := 0  // _No.bmp
   CENTER WINDOW Form_1
   ACTIVATE WINDOW Form_1
Procedure Test_Value
Skydone Solutions
www.skydone.com
Re: Imagen en la ultima columna GRID
Try:
       Form_1.Grid_1.ImageIndex (i,1) := Nil
AidTIC
Post by AidTIC »
Perdona, la tabla la genero ADD ITEM, y no le hago ir.
Sorry, the table is created by ADD ITEM, and I do not make it go.
   aItems := {}
      WIDTH 600 ;
      HEIGHT 400 ;
      MAIN ;
	  on init Test_Value()
         WIDTH 550 ;
         HEIGHT 330 ;
         EDIT;
         CELLNAVIGATION;
       For x := 1 to 100
	      ADD ITEM {  STRZERO( X , 2 ), STRZERO( x * 100 , 3 ) , 0 } TO Grid_1 OF Form_1
	   Next x
Skydone Solutions
www.skydone.com
   aItems := {}
      WIDTH 600 ;
      HEIGHT 400 ;
      MAIN ;
         WIDTH 550 ;
         HEIGHT 330 ;
         EDIT;
         CELLNAVIGATION;
       For x := 1 to 100
       		Form_1.Grid_1.ImageIndex ( Form_1.Grid_1.ItemCount , 1 ) := Nil
       		Form_1.Grid_1.ImageIndex ( Form_1.Grid_1.ItemCount , 3 ) := 0  // _No.bmp
  	   Next x
Bez tytułu.png (12.22 KiB) Viewed 2776 times
AidTIC
Post by AidTIC »
El espacio que queda en la primera columna, se puede eliminar?
Gracias
Can the space left in the first column be removed?
Thank you
Skydone Solutions
www.skydone.com
AidTIC wrote: Fri Feb 22, 2019 6:33 pm El espacio que queda en la primera columna, se puede eliminar?
Gracias
Thank you
I think that it is impossible with the current Grid's imlementation in hmg.
But you can use the powerful TSBrowse library for your need.
Please take a look for an image below
and a sample code is
// Browsing an array with TSBrowse
#include "TSBrowse.ch"
static Grid_1
   aItems := {}
   SET FONT TO "Arial", 10
      WIDTH 600 ;
      HEIGHT 400 ;
      MAIN ;
      @ 10,10 TBROWSE Grid_1 ;
         ARRAY aItems;
         WIDTH 550 ;
         HEIGHT 330 ;
         PICTURE '@K !xxxxxxxxxxxxxxxxx','@K 9999','' ;
         IMAGE "_No.bmp","_No.bmp";
         EDIT;
         CELLED;
         JUSTIFY { DT_CENTER, DT_RIGHT, DT_CENTER}
      WITH OBJECT Grid_1
         :SetAlign( 2, 1, DT_RIGHT )   // ( nCol, nLevel, nAlign )
         :SetColor( { CLR_FOCUSB }, { RGB( 51, 153, 254 ) } )
         :nLineStyle :=  LINES_NONE
         :nHeightCell += 6
         :nHeightHead += 8
      END WITH
local x
   For x := 1 to 100
      ADD ITEM {  STRZERO( X , 2 ), x * 100 , 1 } TO Grid_1 OF Form_1
   Next x
   WITH OBJECT Grid_1
      :aColumns[ 3 ]:lBitMap   := .T.
      :aColumns[ 3 ]:lEdit     := .F.
      :aColumns[ 3 ]:lIndexCol := .F.
   END WITH
Hope that useful :idea:
gfilatov wrote: Fri Feb 22, 2019 8:33 pm Hi,
Indeed. According to the Grid sources, the width of the first column is always expanded by the width of the first image + 2 pixels. Interestingly, if you specify an image with a different index, its width will not be larger than the image with index 0.
SALINETAS24
Post by SALINETAS24 »
Hola, hay un ejemplo en la libreria que igual te puede servir.
Espero que te sirva.
Sl2
Grid_ImageIndex.rar
(1.22 MiB) Downloaded 186 times
