Fingerprint Scanner?
I need to know who is creating each invoice in an HMG POS app.
There is various employees, sharing two POS touch PCs and the sales must be as fast as possible.
So, my first idea was to use a fingerprint scanner.
The problem is how to do it... I never worked with such devices.
My hope is that the device emulate a keyboard generating a numeric code specific for each person... but is only a hope... I have not idea :)
Has someone worked with these devices to give me some advice?
TIA.
Re: Fingerprint Scanner?
Post by EduardoLuis »
Hi Roberto:
I don't test it (and of course not buying a unit), but some time ago i investigate the topic, and the device returns a complex secuence of numbers; capture process reads microlines, and then generates a code for each microline.- I can't tell you how many microlines are scanned.- But what is sure is not a unique number as a barcode scanner.-
I'll investigate again this topic and reply these way what i found.-
Hopping you are well.
With regards.
Eduardo
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I don't use but see like this in caffe bars
https://www.google.rs/search?q=rfid+key ... 902#imgrc=_
or NFC from mobile phone
apais
Post by apais »
A magnetic card would suffice...
Angel Pais
Thanks to all for for the answers.
Maybe the simplest way, could be RFID (dragancesu idea).
It is cheap and the reader emulates a keyboard.
I've seen packs of 100 key fob 'numbered''. I guess that each one generates a pre-recorded (unique) ID, without need to record myself, but I'm not sure about that.
Thanks again.
dragancesu
Good solution is bar code scaner and plastic card with bar code. It's easy, computer see bar code scaner like keyboard
nelstu
Post by nelstu »
Hola yo he utilizado lector de huella
cada lector trae sus propios sdk de acuerdo el lenguaje
por ejemplo el digital person 4500 trae java, c# or c++ que yo he usado pero tuve que hacerlo con java porque no puede hacerlo funcionar con c
Si alguien lo puede hacer funcionar con minigui seria Fantastico!!!
slds
Nelson Stuardo
Hi Roberto:
Take a look a this: https://www.siasa.com/producto.php?prod=0900006
As it comes with it's sdk software, you must see how to combine it with HMG.
With Regards
Eduardo
Hola Roberto
Fijate en este link: https://www.siasa.com/producto.php?prod=0900006
Como viene con su propio soft SDK, tendrías que ver la forma de integrarlo con HMG.
Cordialmente
Eduardo
