Working on a JSON Project
Friends,
I am working on a JSON navigator/browser/viewer Project.
Even though initially I have tried and struggled to use HB_Hash functions, it became now easy for me to start the project with SQLite JSON1 Extension and hmgsqlite bridge. :)
I have completed the basic functionality of navigating through a JSON file/Text.
I am working on exporting the tables to Excel. Please suggest other features also if you want.
The whole project is uploaded along with the Exe file here.
viewtopic.php?p=55926#p55926
Re: Working on a JSON Project
Thanks Rathi,
At the moment I can't think of any extra functionality. I will let you know!
Rathi, some functions are missing ? : connect2db, miscsql, ...
It is HMG Connectivity HMGSQLite bridge. Otherwise, you can also use this code.
FUNCTION connect2db(dbname,lCreate)
local dbo1 := sqlite3_open(dbname,lCreate)
IF Empty( dbo1 )
   msginfo("Database could not be connected!")
   RETURN nil
RETURN dbo1
function sql( dbo1, qstr )
local table := {}
local currow := nil
local tablearr := {}
local rowarr := {}
local typesarr := {}
local current := ""
local i := 0
local j := 0
local type1 := ""
local stmt := nil
local cDate
if empty(dbo1)
   msgstop("Database Connection Error!")
   return tablearr
table := sqlite3_get_table(dbo1,qstr)
if sqlite3_errcode(dbo1) > 0 // error
   msgstop(sqlite3_errmsg(dbo1)+" Query is : "+qstr)
   return nil
stmt := sqlite3_prepare(dbo1,qstr)
IF ! Empty( stmt )
   for i := 1 to sqlite3_column_count( stmt )
      type1 := HMG_UPPER(alltrim(sqlite3_column_decltype( stmt,i)))
      do case
         case type1 == "INTEGER" .or. type1 == "REAL" .or. type1 == "FLOAT" .or. type1 == "DOUBLE"
            aadd(typesarr,"N")
         case type1 == "DATE" .or. type1 == "DATETIME"
            aadd(typesarr,"D")
         case type1 == "BOOL"
            aadd(typesarr,"L")
         otherwise
            aadd(typesarr,"C")
      endcase
   next i
SQLITE3_FINALIZE( stmt )
stmt := nil
if HMG_LEN(table) > 1
   asize(tablearr,0)
   for i := 2 to HMG_LEN(table)
      rowarr := table[i]
      for j := 1 to HMG_LEN(rowarr)
         do case
            case typesarr[j] == "D"
               cDate := HB_USUBSTR(rowarr[j],1,4)+HB_USUBSTR(rowarr[j],6,2)+HB_USUBSTR(rowarr[j],9,2)
               rowarr[j] := stod(cDate)
            case typesarr[j] == "N"
               rowarr[j] := val(rowarr[j])
            case typesarr[j] == "L"
               if val(rowarr[j]) == 1
                  rowarr[j] := .t.
                  rowarr[j] := .f.
         endcase
      next j
      aadd(tablearr,aclone(rowarr))
   next i
return tablearr
function miscsql(dbo1,qstr)
if empty(dbo1)
   return .f.
sqlite3_exec(dbo1,qstr)
   return .f.
return .t.
function C2SQL(Value)
local cValue := ""
local cdate := ""
if ( valtype(value) == "C" .or. valtype( value ) == "M" ) .and. HMG_LEN(alltrim(value)) > 0
   value := HB_UTF8STRTRAN(value, "'", "''" )
do case
   case Valtype(Value) == "N"
      cValue := AllTrim(Str(Value))
   case Valtype(Value) == "D"
      if !Empty(Value)
         cdate := dtos(value)
         cValue := "'"+HB_USUBSTR(cDate,1,4)+"-"+HB_USUBSTR(cDate,5,2)+"-"+HB_USUBSTR(cDate,7,2)+"'"
         cValue := "''"
   case Valtype(Value) $ "CM"
      IF Empty( Value)
         cValue="''"
         cValue := "'" + value + "'"
   case Valtype(Value) == "L"
      cValue := AllTrim(Str(iif(Value == .F., 0, 1)))
   otherwise
      cValue := "''"       // NOTE: Here we lose values we cannot convert
endcase
return cValue
Thank you Rathi, It is very much required
Copy / Paste / Search / Replace and re-export json file
Also visit Freeware tools including json viwer
http://www.mitec.cz/jsonv.html
Thank you for the link. It is so cool!
However, these free viewers are just creating a big tree of all objects. What we require is to treat the Arrays and Objects in a different way.
Wow! The possibilities of HMG are unimaginable! Now I have improved a lot with some code changes to flatten all the tables in the JSON and show them in a single window with different tab pages. :)
Try to walk through the attached sample JSON file (a real Indian GST file) with my viewer. I think you will see the difference.
HBJSON.zip
(2 MiB) Downloaded 731 times
Now it is time to format and export.
Give your suggestions also.
Great tool Rathi!
jayadevu
Post by jayadevu »
Excellent Rathinagiri.
Warm regards,
Jayadev
Anand
Post by Anand »
Great sample code for json parsing Rathinagiri Sir. Thanks for it.
Anand
Anand
Friends, this is the new executable file.
https://drive.google.com/file/d/1O0rfLx ... p=drivesdk
