Harbour MiniGUI Extended Edition build 18.07 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 18.07.
* Fixed collision of 'OnDisPLAYChange' method with AnimateBox 'Play' method.
* Added possibility to set a BackColor for text box of DATEPICKER
and TIMEPICKER at NO THEMED WinXP or earlier only.
* The Grid control supports the optional COLUMNWIDTHLIMITS clause and
corresponding ON DRAGHEADERITEMS event.
Above clause specifies the limits for the column's width which will
allowed at the dragging of a column's border via a mouse.
Syntax:
@ <row>,<col> GRID <name> [ OF <parent> ] ;
[ WIDTH <nWidth> ] [ HEIGHT <nHeight> ] ;
[ HEADERS <aHeaders> ] [ WIDTHS <aWidths> ] ;
[ ITEMS <aItems> ] [ VALUE <value> ]
[ COLUMNWIDTHLIMITS <aWidthLimits> ]
[ ON DRAGHEADERITEMS <bAction> ]
* Minor modifications for compatibility with Viktor's Harbour fork
3.4.0 and Borland/Embarcadero C++ 7.3 (32-bit).
* Updated the TSBrowse, HbXlsXml and Sqlite3 libraries.
* Added the new interesting samples and updated some Basic and
Advanced samples.
A setup of the build 18.07 for Borland C++ 5.5.1 is published at
the following URL:
And you can also download from the new mirror:
http://hmgextended.org/files/CONTRIB/hm ... -setup.exe
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
Thanks for your attention and support!
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 18.07 is published
Thanks Grirory!
BeGeS
Post by BeGeS »
Thanks, Filatov.
Anand
Post by Anand »
Thanks a lot Grigory.
Anand
Anand
Post by EduardoLuis »
Thanks Grigory, Great Job.
quartz565
Post by quartz565 »
Thank you Grigory.
Nikos.
os: Windows Server 2019 - 64
Congratulation Grigory.
Steed
Post by Steed »
thanks a lot
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
¡¡Gracias Grigory.!!
