MySQL DB Backup - HMGMySQL
If you are using HMGMySQL library to use with MariaDB/MySQL, the following code can be used to make a dump backup of whole database
function backup_db( cFname )
   local aTable := {}
   local aTables := {}
   local tables := {}
   local aData := {}
   local aRow := {}
   local cLB := chr( 10 ) + chr( 13 )
   local nHandle := 0
   local cTime := time()
   local cTempFolder := GetCurrentFolder() + '\' + 'backup_' + dtos( date() ) + substr( cTime, 1, 2 )  + substr( cTime, 4, 2 ) + substr( cTime, 7, 2 )
   local aFiles := {}
   default cFName := 'backup.sql'
   tables := sql( oDB,"show tables")
   for i := 1 to len(tables)
      aadd(aTables,alltrim(tables[i,1]))
   next i
   i := 0
   tottables := len(aTables)
   if MakeDir( cTempFolder ) <> 0
      msgstop( 'Backup Directory could not be created!' )
      return nil
   nHandle := fcreate( cTempFolder + '\' + cFName )
   aadd( aFiles, cTempFolder + '\' + cFName )
   if nHandle < 0
      msgstop( 'Backup File Could not be created!' )
      return nil
   for i := 1 to tottables
      WAIT WINDOW "Processing Table - " + aTables[ i ] + '( ' + alltrim( str( i ) ) + '/' + alltrim( str( tottables ) ) + ' )'   NOWAIT
      aTable := sql( oDB, 'show create table ' + aTables[ i ] )
      cCreateCommand := aTable[ 1, 2 ]
      fwrite( nHandle, alltrim( cCreateCommand ) + ';' + cLB )
      // try to dumpt data to file
      cTempFileName := cTempFolder + '\' + alltrim( aTables[ i ] ) + '.txt'
      aadd( aFiles, cTempFileName )
      cTempFileName := strtran( cTempFileName, '\', '/' )
      miscsql( oDB, "select * from " + aTables[ i ] + " into outfile '" + cTempFileName + "'" )
      if .not. file( cTempFileName )
         msgstop( 'Dump file not created!' )
         return nil
   next i
   wait clear
   fClose( nHandle )
   cZip := cTempFolder + '.zip'
   hb_zipFile( cZip, aFiles )
//   compress files aFiles to cZip
   if file( cZip )
      for i := 1 to hmg_len( aFiles )
         ferase( aFiles[ i ] )
      next i
      dirremove( cTempFolder )
   msginfo( 'Backup Complete - ' + cZip + ' File Created' )
return nil
Restore utility can be created with the code as below:
   define window main at 0, 0 width 260 height 200 main
      define label hostlabel
         row 10
         col 10
         width 100
         value 'Host'
      end label
      define textbox host
         row 10
         col 110
         width 120
         value 'localhost'
      end textbox
      define label userlabel
         row 40
         col 10
         width 100
         value 'UserName'
      end label
      define textbox user
         row 40
         col 110
         width 120
         value 'root'
      end textbox
      define label passlabel
         row 70
         col 10
         width 100
         value 'Password'
      end label
      define textbox pass
         row 70
         col 110
         width 120
         password .t.
      end textbox
      define label newdblabel
         row 100
         col 10
         width 100
         value 'New DB'
      end label
      define textbox newdb
         row 100
         col 110
         width 120
      end textbox
      define button restore
         row 130
         col 60
         caption 'Restore'
         action restoredb()
      end button
   end window
   main.center
   main.activate
function restoredb( cZip )
   local aFiles := {}
   local cSQLFile := ''
   default cZip := ''
   if hmg_len( alltrim( cZip ) ) == 0
      cZip := GetFile( , 'Select the File to Restore' )
   if .not. file( cZip )
      msgstop( cZip + ' File Not Found!' )
      return nil
   cCurFolder := GetCurrentFolder()
   cTempFolder := GetCurrentFolder() + '\' + '_RestoreTemp' + dtos( date() ) + substr( cTime, 1, 2 )  + substr( cTime, 4, 2 ) + substr( cTime, 7, 2 )
      msgstop( 'Restore Directory could not be created!' )
      return nil
   SetCurrentFolder( cTempFolder )
   WAIT WINDOW 'Processing the zip file...' nowait
   Uncompress File cZip
   aDirectory := Directory()
   for i := 1 to hmg_len( aDirectory )
      if HB_UTF8RAT( '.SQL', hmg_upper( aDirectory[ i, 1 ] ) ) > 0
         cSQLFile := aDirectory[ i, 1 ]
         aadd( aFiles, aDirectory[ i, 1 ] )
   next i
   if hmg_len( aFiles )== 0
      msgstop( 'Could not find any file!' )
      return nil
   if hmg_len( cSQLFile ) == 0
      msgstop( 'SQL File Not found!' )
      return nil
   cUser := main.user.value
   cHost := main.host.value
   cPass := main.pass.value
   cNewDB := main.newdb.value
   oDB := connect2db( cHost, cUser, cPass, cNewDB )
   if oDB == nil
      msgstop( 'Database could not be connected' )
      return nil
   tables := sql( oDB, "show tables" )
   if hmg_len( tables ) > 0
      msgstop( 'Database Should be new and empty!' )
      return nil
   WAIT WINDOW 'Creating Tables...' nowait
   aCreate := HB_ATOKENS( MEMOREAD( cSQLFile ),   cLB )
   for i := 1 to hmg_len( aCreate )
      if hmg_len( alltrim( aCreate[ i ] ) ) > 0
         lSuccess := .t.
         lSuccess := miscsql( oDB, alltrim( aCreate[ i ] ) )
         if .not. lSuccess
            msgstop( 'Table Creation Error!' )
            return nil
   next i
   tottables := hmg_len( aFiles )
      cFileName := aFiles[ i ]
      cTable := substr( cFileName, 1, hmg_len( cFileName ) - 4 )
      WAIT WINDOW "Processing Table - " + cTable + '( ' + alltrim( str( i ) ) + '/' + alltrim( str( tottables ) ) + ' )'   NOWAIT
      cFileNameWithPath := cTempFolder + '\' + cFileName
      cTempFileName := strtran( cFileNameWithPath, '\', '/' )
      lSuccess := miscsql( oDB, "load data infile '" + cTempFileName + "' into table " + cTable )
      if .not. lSuccess
         msgstop( cFileName + ' could not be restored!' )
         return nil
   next i
   wait clear
   msginfo( 'Database restored successfully!' )
   ferase( cSQLFile )
   next i
   SetCurrentFolder( cCurFolder )
   return nil
ecabrerizo
Re: MySQL DB Backup - HMGMySQL
Post by ecabrerizo »
Thanks !!!!
Best Regards
koke
DBs Used: DBF, mySql, mariaDB
Post by koke »
Thanks !!
,___,
[O.o]
/)__)
KoKe
ASESORMIX
Post by ASESORMIX »
Saludos.
Muchas gracias.
jairpinho
Post by jairpinho »
good afternoon, I did test with ide and appeared the errors could help like to see working
hbmk2: Linkando... HMGMYSQL.exe
.hbmk/win/mingw/Main.o:Main.c:(.data+0x2b8): undefined reference to `HB_FUN_CONNECT2DB'
.hbmk/win/mingw/Main.o:Main.c:(.data+0x2d8): undefined reference to `HB_FUN_SQL'
.hbmk/win/mingw/Main.o:Main.c:(.data+0x338): undefined reference to `HB_FUN_MISCSQL'
.hbmk/win/mingw/F_Backup.o:F_Backup.c:(.data+0x88): undefined reference to `HB_FUN_SQL'
.hbmk/win/mingw/F_Backup.o:F_Backup.c:(.data+0x188): undefined reference to `HB_FUN_MISCSQL'
.hbmk/win/mingw/F_Backup.o:F_Backup.c:(.data+0x1c8): undefined reference to `HB_FUN_HB_ZIPFILE'
hbmk2[HMGMYSQL]: Erro: Executando linkeditor. 1
gcc.exe .hbmk/win/mingw/Main.o .hbmk/win/mingw/F_Backup.o .hbmk/win/mingw/_hbmkaut_Main.o "D:/@Drive-TW/@MasterServ/@Utilitario/HMGMYSQL/_temp.o" -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage -lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oHMGMYSQL.exe -LC:/hmg.3.4.4/harbour/lib/win/mingw -LC:/hmg.3.4.4/lib
hbmk2: Dica: Adicionar op‡Æo 'hbziparc.hbc' faltando nas fun‡äes: hb_ZipFile()
hbmk2: Erro: Referenciado, faltando, mas fun‡äes desconhecida(s): CONNECT2DB(),
SQL(), MISCSQL()
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
