Harbour MiniGUI IDE 2.8.6g
English:
- Fixed: [Enter] key blocked while compiling an application.
Reported by Marek.
- Fixed: Control Order Window. Clicking 'Up' button with 'form'
is selected causes an error. Reported by Grigory Filatov.
- Fixed: Misc UCI problems.
Español:
- Solucionado: Tecla [ENTER] bloquedada durante la compilación.
Reportado por Marek.
- Solucionado: Ventana 'Orden de Controles'. Al presionar el botón
'arriba' cuando está seleccionado el 'form'
- Solucionado: Problemas varios en UCI.
Download/Descarga: http://harbourminigui.googlepages.com
Re: Harbour MiniGUI IDE 2.8.6g
Thanks a lot for the updated version Roberto.
Super! I'll test it tomorrow!
Great news - now I can do some other things during compilation huge project.
Many thanks, Roberto!
Vanguarda
Post by Vanguarda »
Hi all,
Thanks master, for this new version. I´ll test it ASAP.
Hello Master Roberto,
I tested it. It's running OK and stable. Thanks a lot. :)
Only one thing more. After installation all my extra setup for previous IDE (eg., text editor, extra libraries, include folders etc) were vanished. Is there any way to restore those extra setup (for the next update). So, that I shall do it for the next time. (Please correct me if I am wrong)
I already setup those libraries, text editors etc, as they are easy to configure. :)
I was writing about it in HMG wishes soe time ago...
Gracias Roberto,
Saludos cordiales,
Luis Vasquez
jrendon
Post by jrendon »
Gracias Master Roberto
Padawan Juan Rendón
That configuration is on \hmgide\ide.cfg IDE.
The simplest and obvious way is to backup that file prior installation.
I'm not a master in 'Inno Setup' but I wonder that there is some solution for this. I'll take a look at that.
Roberto Lopez wrote: That configuration is on \hmgide\ide.cfg IDE.
Thank you very much. Yes, this will be the best solution :)
