problem with compiling both .bat and ide
emzampi
Post by emzampi »
I use a .hbp file to compile all the program's .prg and if I use the ide program to compile with the run key the program is compiled and executed while if I use it for compiling the debug key is compiled but it does not work by mistake "loadsoucefile: file not found (stampa3.prg)" for all the prg of the program see attachments
emzampi
Re: problem with compiling both .bat and ide
Post by emzampi »
Sorry but I forgot to send you a greeting to all and thank you for your valuable help
Is your pronlem now solved or not?
emzampi
Post by emzampi »
no is not solved .. congratulations for Belgium good team deserved at least to make the final
emzampi
Post by emzampi »
Dear friends
I will try to be as clear as possible
using the command .bat (call C: \ hmg.3.4.4 \ build.bat bustafm.hbp) that contains the source codes
source \ bustafm.prg
source \ acrocud.prg
ect ...
the program is built correctly although without the -m parameter the build.log registers the following errors
Harbor 3.2.0dev (r1703241902)
Can not open datmese.prg, assumed external
Can not open addiz.prg, assumed external
Can not open aggi.prg, assumed external
Can not open cfdati.prg, assumed external
Can not open datbase.prg, assumed external
Can not open create.prg, assumed external
if I use the command .bat (call C: \ hmg.3.4.4 \ build.bat / d bustafm.hbp) in addition to errors
I get the message of hmg debugger - loadsourcefile: file not found (name of all .prg) and does not execute the .exe
almost sure I will have to insert some path or other things like that you think
I don't use IDE + debugger. Maybe somebody else can help emzampi?
I'm using IDE almost always and very often with debugger.
But, how to help? can you post small sample? Replace bodies of your functions with simple code, eg.:
MsgInfo('...')
if you don't want share it and attach here.
emzampi
Post by emzampi »
I'll put the code at your disposal, keep in mind that I'm a dilettante amateur
emzampi
Post by emzampi »
in this .zip I put the original a unique .prg file that works with both .bat
Hello,
I compiled the sources of provahmg.rar succesfully.
I changed HBP (remove ALL \source) and then it works fine: risoluzione schermo: 1920*1080 Cpnsigliata 130*768 and then modifica ...
