He logrado compilar la pxlib desde Mingw
sin problemas, pero quiero
usarlo desde hmg y estoy perdido como tanga en...
mi primera pregunta es:
sabiendo que en c
typedef struct px_doc pxdoc_y px_doc es una estructura
struct px_doc {
/* database file */
// FILE *px_fp; /* File pointer of file */
pxstream_t *px_stream; /* input stream to read file from */
char *px_name; /* Name of file */
int px_close_fp; /* set to true if file pointer must be closed, deprecated */
// int px_filemode; /* set to pxfFileRead|pxfFileWrite */
pxhead_t *px_head; /* Pointer to header of file */
void *px_data; /* Pointer to data of file (used in prim. index for
* index data, used in db files for an self build
* index) */
int px_datalen; /* length of data field in number of units */
void *px_indexdata;/* Pointer to index data */
int px_indexdatalen; /* number of index data records */
/* primary index file */
pxdoc_t *px_pindex;
/* blob file */
pxblob_t *px_blob;
/* record accounting */
int last_position; /* Position (starting at 0) where last record was put. */
int warnings; /* Turn of/off output of warnings */
/* output function */
size_t (*writeproc)(pxdoc_t *p, void *data, size_t size);
/* error handler function */
void (*errorhandler)(pxdoc_t *p, int level, const char* msg, void *data);
/* user data passed to error handler */
void *errorhandler_user_data;
/* Memory allocation functions */
void *(*malloc)(pxdoc_t *p, size_t size, const char *caller);
void *(*calloc)(pxdoc_t *p, size_t size, const char *caller);
void *(*realloc)(pxdoc_t *p, void *mem, size_t size, const char *caller);
void (*free)(pxdoc_t *p, void *mem);
/* input stream functions */
size_t (*read)(pxdoc_t *p, pxstream_t *stream, size_t numbytes, void *buffer);
int (*seek)(pxdoc_t *p, pxstream_t *stream, long offset, int whence);
long (*tell)(pxdoc_t *p, pxstream_t *stream);
size_t (*write)(pxdoc_t *p, pxstream_t *stream, size_t numbytes, void *buffer);
char *targetencoding;
char *inputencoding;
#if PX_USE_RECODE
RECODE_OUTER recode_outer;
RECODE_REQUEST out_recode_request; /* Encoding of written data */
RECODE_REQUEST in_recode_request; /* Encoding of read data */
#else
#if PX_USE_ICONV
iconv_t out_iconvcd; /* Encoding of written data */
iconv_t in_iconvcd; /* Encoding of read data */
#endif
#endif
long curblocknr; /* Number of current block in cache (0-n) */
int curblockdirty; /* Set to px_true if the block needs to be written */
unsigned char *curblock; /* Data of block in read cache */
O mas simple como llamo desde harbour a esta funcion de la lib?
PXLIB_API int PXLIB_CALL PX_open_fp(pxdoc_t *pxdoc, FILE *fp);
